Old 12-26-2001, 10:25 PM   #901
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Hey all MTX-2 Fellows especially if you are running front oneway:
I tried something new today at the track and it works pretty good! What I did was adjust the brake to drag the car when it is idle and since we all know if you are running front oneway then cant use brake otherwise it will spun around. And I dont want to let go of the gas too early and roll in the corners so I adjust the brake alittle bit to make it drag on the car when the throttle position is closed(idle). It works pretty good I could actually let go of the gas a little bit later and the car has just a little bit of braking action through the turns and I was really suprise the turning radius is smaller, meaning closer to the board!
If you dont want the brake to engage then just play with the trigger on your radio so it doesnt drag the car at all! but I found this to be really useful and actually improve driving lines and overall speed as well!
If you guys have any comments or suggestion please do!
Ah10 is offline   Reply With Quote
Old 12-30-2001, 07:13 PM   #902
Manticore's Avatar
Arrow Calling Fast Guys !
Where have all the fast guys gone?
Manticore is offline   Reply With Quote
Old 12-30-2001, 07:20 PM   #903
Ah10's Avatar
Default Re: Calling Fast Guys !
I am getting faster and faster! do you count me?
Old 12-30-2001, 08:21 PM   #904
Manticore's Avatar
Default Re: Re: Calling Fast Guys !
Sure you are !!
Old 12-31-2001, 01:36 PM   #905
Ah10 I found out that the racer's choice diff lube is actually in a grease form something you can find in a automotive store I wonder if it's the same. Anyway is that what you got? My came is a little round canister and the stuff is red.
kyosho is offline   Reply With Quote
Old 12-31-2001, 02:13 PM   #906
Ah10's Avatar
I am not sure if it is same as the grease you can buy from automotive store! I kind of doubt it!
The one that I got is in a red canister too, but the lube itself is white! I believe the part number is 7016
Old 12-31-2001, 03:26 PM   #907
Oh really i though it was going to be in some liquid form but I did try it out and after lubing the diff up with it it seemed real stiff something that you would put in the front not the rear. So I took it out and going to put some 3k diff oil since I can get the 7016 one which I think is a lighter form of it. Probadly that why your diff don't leak cause it grease not diff oil like I thought it was. Anyways thanks for you help all along.
Old 12-31-2001, 03:58 PM   #908
Ah10's Avatar
Hum...that's weired! after I packed the gear with the Hyspin lube and assemble everything back together and the diff feel really loose like 5k diff oil!
Old 12-31-2001, 04:58 PM   #909
Ah10 I think you got the light version in other words the one I got the red stuff felt like something that should go in the front.
Old 12-31-2001, 05:00 PM   #910
Oh yeah I forgot how much did you use? I used just enough to cover the gear in other words I lightly lubed it.
Old 12-31-2001, 05:18 PM   #911
Ah10's Avatar
What I did was just lightly cover all the bevel gears with the lube the seal the unit back and now the diff should have a freely diff action!
Now after may be 2 or 3 tanks of fuel open it up then pack some more lube in there! probably the same amount you lube it in the first place. After 2 or 3 tanks and when you open it up you probably see all the lube got spined to the edge of the gear. After fill some more lube in there and you should be done with a perfect negative diff.
Old 12-31-2001, 08:02 PM   #912
Ok thanks.
Old 12-31-2001, 11:03 PM   #913
Motorman's Avatar
Ah 10
The Legend Mr, Auturo Carbonell of Serpent uses a little brake drag also and has done so for years, for exactly the reason you stated. I have tried it both ways and still don't know which I like best.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 12-31-2001, 11:38 PM   #914
Ah10's Avatar
Originally posted by Motorman
Ah 10
Oh really! is MR Auturo Carbonell one of those team driver?
Anyway I like the way the drag brake react but the only problem is you have to fine tune it every time you run you car due to temperture and track, for example, I have been running at the same track but I have to fine tune the grip dial every single time for somereason, usually when I first start the brake is too much but as the day go by need to add some more to it! may be that's what ppl call brake fade! overall it works really good!
Old 01-01-2002, 12:02 PM   #915
Ah 10
Gee I thought his name was ?Arthur? Learn something new on new years day.
Sydewynder is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
