Old 12-19-2001, 02:00 AM   #871
SpeedTech's Avatar
Hi Guys,
We will be receiving a shipment of Kawahara MTX-2 hop-ups this week, including the Kawahara 2-speed system.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 12-19-2001, 03:50 PM   #872
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Steve, do you accept money orders?
Dan is offline   Reply With Quote
Old 12-19-2001, 04:19 PM   #873
RAP66's Avatar
Red face Clutch spring removal
I already chowdered a set of clutch shoes... How do I SAFELY remove the springs and shoes, with out killing the old clutch pieces..
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 12-19-2001, 07:38 PM   #874
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: Clutch spring removal
Rich
Stick a flat screwdriver in between the end of one of the shoes and pry that shoe open. Pull the shoe right around until you permenantly bend the spring. It should now come out. Repeat for the other two shoes (but without screwdriver!).
You may cause some minor damage to the shoes but it should be on the "back face" of the shoes and this is not too important. Unfortunately, I have yet to figure out a way of doing this without killing a set of springs!
And NO.... it is not that easy, there is usually a lot of 'F..ing' and 'Blinding' associated with the procedure!!!
dtm is offline   Reply With Quote
Old 12-19-2001, 08:52 PM   #875
Default Re: Manbik
A bud and I are going to set the chassis, after that I'm gona try it out at the college lot where RAMS races. ..................................
Come up to Delta RC with your bud. Mission College frowns on people running in their lot when RAMS isn't running. Something about insurance.
As for the springs, you need a very small flat blade screw driver to get the spring past the groove in the pilot shaft and at the same time slide it with the shoe off the pin. Works better with 2 people. One to pry and one to slide.
Sydewynder is offline   Reply With Quote
Old 12-19-2001, 11:32 PM   #876
Manbik's Avatar
Default Re: Manbik
I rebuilt then engine (well kinda), and I wasn't careful with the clutch shoes, I cracked one of them....
Yea those clutches are a pain to work on. You may want to consider the Centax clutch once you get some mileage on the car.
As far as compression... I think I had a spacer under the head. You may want to remove it if it is still there. There was another sized spacer in the box that I never used.
Manbik is offline   Reply With Quote
Old 12-20-2001, 02:04 AM   #877
Diva's Avatar
Send a message via Yahoo to Diva
Anybody running front solid axle, not one-way nor diff? How does it feel? On what condition should it be used?
Diva is offline   Reply With Quote
Old 12-20-2001, 02:53 AM   #878
Michael_T's Avatar
Send a message via MSN to Michael_T
I've run an Impluse with a solid front and rear diff. Extremely tricky to drive, and the more throttle you apply to more push your gonna get.
W Fok summed it up somewhere saying you need to steer with your throttle.
It feels like you are constantly understeering, but your not (if that make sense)
Michael_T is offline   Reply With Quote
Old 12-20-2001, 01:43 PM   #879
SpeedTech's Avatar
Hi Dan,
We can accept money orders, and we can also do COD orders as well
The Kawahara goodies should be coming in today
Steve Wang
Speed Tech R/C
www.speedtechrc.com
Old 12-21-2001, 12:31 PM   #880
RAP66's Avatar
Default MODS to stock topdeck
I saw a mod (cant remember where)... the guy had an idler bearing installed on the stock top plate like the one on the Penguin top deck. My buddy keeps throwing his front belt (a new one at that) and he cant afford a Graphite upgrade right now.
Anyone know where to get this part?? or HOW to do the mod...
For that matter pictures of the MOD...
Rich
Rich Pedro
[email protected]
www.rcracing.com
Old 12-21-2001, 03:12 PM   #881
Dan
Dan's Avatar
Steve,
Great!!
Will be doing business soon!
Old 12-21-2001, 04:39 PM   #882
SpeedTech's Avatar
Hi Guys,
We just updated our website with a ton of new hop-ups from Kawahara for the MTX-2, including the new clutch 2-speed assembly. We will receive more hop-ups end of next week for the MTX-2 including the negative rear diff. Check them out on our website, they are going really fast!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
909-869-9443
Old 12-22-2001, 12:15 AM   #883
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Does anyone using Penguin Carbon Fiber Upper Deck? any problem with fitting? I have heard from a few ppl on how poorly that thing fits on the MTX2, some said had to push the rear end towards the front end to make the CF upper deck to fit some said the holes dont even match up with the front bulkhead.
Just want to hear from you guys. FYI mine fits perfect and I like it alot but I might try 5star CF upper deck, heard the quality is much better. Any idea?
Ah10 is offline   Reply With Quote
Old 12-22-2001, 05:28 PM   #884
RAP66's Avatar
I got the Penguin deck with my MTX... and I kinda have to move the opposite direction... I have to push the deck a bit towards the rear to get the screws to line up... I have been looking at their website and I think I'm gona take a dive on a sheet of 3mm Graphite, ot's only $25 or so... and the size is large enuff that I can get a deck cut out of it.... I have a Cad program where I can tweek the position of things, to a layout I like... and print 1 to ! scale, the down side is trying to cut the stuff out. Maybe a Dremel Router, or a scroll saw would do the trick.
Hmmm the posibilities.......
Rich
Rich Pedro
[email protected]
www.rcracing.com
Old 12-22-2001, 07:11 PM   #885
Ah10's Avatar
He He I have just got myself a 5 Star carbon fiber radio tray! Will update after finish putting it on! but overall quality seems better than penguin
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
