Old 12-06-2001, 02:56 AM   #781
xray's Avatar
Novarossi, I have no problem using my serpent starter box with my MTX-2.
When I bought the starter box, they give you 5 type of plastic adaptor: 3 for the front and 2 for the rear.
xray is offline   Reply With Quote
Old 12-06-2001, 04:43 AM   #782
xray's Avatar
Any news on the new MTX-3??
Old 12-06-2001, 12:09 PM   #783
RAP66's Avatar
Default Setup help.... for Castle & Rams
ok... I have the car apart....
What is a good baseline setup for Castle Hobbies & RAMS??
I'm hoping to find a baseline where I can just drop the car down and go... then fine tune with tires. These tracks are temporary parking lot tracks, (I believe) they use VHT.
I need info on F/R diff oils, F/R shock oil, linkage and shock positions and spirngs...
And finally what about the front sway bar... The guy I bought the car from sent it with the car, but still in the baggy. Should I install it?? Or leave it off and just use the rear sway....
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 12-06-2001, 12:20 PM   #784
psycho's Avatar
Hard Jokur
Castle's not racing again until Feb. Dunno about Rams. You should start with the stock setup that's in the instruction and tune from there. The f/r swaybars work well at Castle. I run the front about 10 degrees from the softest position and have the rear flush with the collars. If you plan to run rubber tires, try Yokomo Sprint mediums all around with medium inserts in back and firm up front. If you run foams, swing by Castle and pick up the ZAC Project tires. Try 42's up front and 35's in back.
Good luck!
psycho is offline   Reply With Quote
Old 12-06-2001, 12:41 PM   #785
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Setup help.... for Castle & Rams
[QUOTE]Originally posted by Hard Jokur
Hard Jokur
Manticore told me sway bar is a must for small and tight track.
As for shock oil, I am runing 60wt all around with Light blue springs, it seems like it works good on track as well as parking lot.
Camber linkage, you want to match it up with the lower A-arm as close as possible and as parallel as posible to eliminate camber changes when rear susp is moving up and down.
hope this help
Ah10 is offline   Reply With Quote
Old 12-06-2001, 10:57 PM   #786
What would happen if I stuck a solid in the front with a gear rear diff?
How about a solid front with the negative diff?
And the solid front with a solid rear?
Sydewynder is offline   Reply With Quote
Old 12-06-2001, 11:56 PM   #787
SpeedTech's Avatar
Hi Guys,
Just want to drop a quick note in here that we are having our Christmas Super Sale going on right now!!! For details, check out our website first page. We are also giving away a car kit for FREE this month.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 12-06-2001, 11:58 PM   #788
Manticore's Avatar
dear Fok,
no one is going to test it out for you !! you need to trial and test them out yourself !
Manticore is offline   Reply With Quote
Old 12-07-2001, 12:09 AM   #789
Originally posted by Manticore
dear Fok,
dear ticore,
Thanks! I know no one will help me test it. I was asking for some theoretical insight as to what a solid front is suppose to do with those 3 combinations. Sheese people get grumpy in their old age.
Old 12-07-2001, 12:33 AM   #790
Pek
Default Kawahara Alloy vs. Graphite
What do you guys prefer to stiffin up the chassis and reduce some weight.
Anyone run at SVM Speedway in Sun valley? if so whats a good starting setup.
http://www.svmspeedway.com/racepage.htm
Pek is offline   Reply With Quote
Old 12-07-2001, 12:37 AM   #791
Manticore's Avatar
dear ticore,
Old 12-07-2001, 12:40 AM   #792
Manticore's Avatar
Default Re: Kawahara Alloy vs. Graphite
It is a great track !!
Old 12-07-2001, 12:41 AM   #793
Alloy upperdeck?
Graphite lower chassis?
Neither. Graphite upperdeck to stiffen and reduce some weight.
Old 12-07-2001, 12:45 AM   #794
So what's the answer?
I noticed Novarossi looked at this thread and didn't comment either. You guys are a lot of help!
Old 12-07-2001, 12:47 AM   #795
solid front / gear rear - wiiiiickid ( little understeer )
solid front / negative rear - extra wiiiiickid
solid rear / solid front - spins on its own axia ( looks wiiiiickid )
( just guessing on the negative thing cos I don't have one )
muugen is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
