Old 11-12-2001, 07:43 PM   #436
hurhur's Avatar
dont think the top deck u saw is the one in the pic....a plastic top deck shldnt cost 60USD, most likely the one u saw is their graphite top deck.
hurhur is offline   Reply With Quote
Old 11-12-2001, 07:48 PM   #437
hurhur's Avatar
i believe he meant the NEGATIVE DIFF.
Originally posted by Manticore
as far as i know kawahara doesnt make a ball diff for MTX2 !! are you sure you have a ball diff?
Old 11-12-2001, 07:54 PM   #438
Manticore's Avatar
R/C Tech Charter Subscriber
well, he should be concious on the difference between gears and balls when he assembled the diff.
Manticore is offline   Reply With Quote
Old 11-12-2001, 08:07 PM   #439
Send a message via AIM to ryan
Sorry, I was confused too since I saw it in my HS listed as 'Torque Sensing Ball Differential' - I guess that was an err on their part. Here is a picture of the diff I've been talking about.
The 'gear side' of the diffs essentially looks just like the stock rear diff on the car. I packed it with the Mugen #30,000 that came with the kit. On the other side there are two black pieces that look very similar to the shoes we have in the Centax clutch, in a "C" shape. Supposedly, it works just like the stock rear-diff, then when it hits a certain RPM, it locks up and works like a solid-rear. I can't easily make out Kawahara's directions, as they are in Japanese, and I'm still unsure of how/if it can be tuned. There are two small holes on the outside of the 'shoe' housing - but they don't appear to be threaded so I don't know if they are for stop-screws (which weren't included in the kit anyways). Wondering if anyone is more familiar with this device.
Oh, as for the Kawahara upper deck - I could've sworn it looked exactly like the one in the picture - didn't know they made two models. It was at Castle Hobbies in San Jose California.
ryan is offline   Reply With Quote
Old 11-12-2001, 08:10 PM   #440
Manticore's Avatar
you should not use thick diff oil for the diff as this will remove rear traction on low speed and your cornering wont be smooth. the diff will progressively lock up when you accelerate your car. I just put some kind of gear protection lube in it and it just do the job.
Old 11-12-2001, 08:13 PM   #441
Hey Manticore,
So are you using this diff too? You reccommend either a thinner oil or just some gear lube then right? Thanks, I will look in to that.
Old 11-12-2001, 08:15 PM   #442
Manticore's Avatar
Hey Manticore,
besides, dont use the thick nylon washer that comes with the kawahara diff as it is too thick. use the stock gear diff metal thin washer and that will perfectly do the job.
Old 11-12-2001, 08:21 PM   #443
hurhur's Avatar
im still confused how this Kawahara thingy works.
so under full throttle, down the straights, the clutch will be engaged and the diff behaves like a solid axle?
when cornering, the clutch disengages and works like a normal diff?
so the only difference when comparing the negative diff and normal diff is only visible on the straights?
pls enlighten
Old 11-12-2001, 08:38 PM   #444
Manticore's Avatar
pls enlighten
yes
Old 11-12-2001, 08:47 PM   #445
hurhur's Avatar
any idea why 1/8 cars uses front one way with solid axle and not say one way with a normal gear diff?
i have seen Impulses with solid axle in front and a adjustable diff in the rear. Strange isnt?
Old 11-12-2001, 08:53 PM   #446
Manticore's Avatar
the 1/8 racer has way wider rear tire and the rear solid axle makes the car moves faster on corner and faster acceleration out of corner.
Old 11-12-2001, 08:59 PM   #447
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Im sure the original 1/8th cars ran diffs. Could be wrong
Michael_T is offline   Reply With Quote
Old 11-12-2001, 09:04 PM   #448
Manticore's Avatar
yes it is when the time the 1/8 still running with RWD only to get maxi rear end traction. but those fast guy from ASSO 20 years ago use solid axle for their 1/8 RWD ASSO racers.
Old 11-12-2001, 09:20 PM   #449
Manbik's Avatar
... so the only difference when comparing the negative diff and normal diff is only visible on the straights?
Well to clarify a bit, it will engage under heavy acceleration not just straights.
I have an exploded view of it on my site, click on the MTX-2 link then on Downloads.
-Manbik
http://www.jasonjenkins.com
Manbik is offline   Reply With Quote
Old 11-12-2001, 09:23 PM   #450
Manticore's Avatar
-Manbik
when you have heavy acceleration, it is on the straight. right?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
