Old 10-31-2001, 11:32 PM   #301
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally posted by AsphaltAssasin
I run the Yokomo 26mm on the Front and the Yokomo 32mm rear. No rubbing and they go right on.
Having said that, do u run hex adaptors?
Also, are you still able to run the 'stock' rear camber link as it extends past the rear hub.
Not sure how you managed to get them on
Michael_T is offline   Reply With Quote
Old 10-31-2001, 11:37 PM   #302
Manticore's Avatar
R/C Tech Charter Subscriber
please note that the yokomo foam tire is mounted on special offset wheels so it doesnt rub at all.
Manticore is offline   Reply With Quote
Old 10-31-2001, 11:42 PM   #303
Michael_T's Avatar
Ahhhhhhhhhhhh
That explains it then.
Let me re-phrase : Running standard offset rims
Old 10-31-2001, 11:43 PM   #304
AsphaltAssasin's Avatar
Trader Rating: 36 (100%+)
Yes I run the purple hex hubs that came in the kit. I have the stock camber links. there were no modifications needed with these tires.
Earl Barnes
JGO Paintz
AsphaltAssasin is offline   Reply With Quote
Old 11-01-2001, 04:29 AM   #305
Can you check your parts listing to see what the part number for the aluminum hexes that came with your kit?
tekrsq is offline   Reply With Quote
Old 11-01-2001, 08:45 AM   #306
Part # T0121
Earl Barnes
JGO Paintz
Old 11-01-2001, 02:24 PM   #307
Thanks!!! but that blows my theory. I thought maybe Mugen had put the T0124 hexes in the pro kits. I guess not. Now I just have to find the T0124.
Old 11-01-2001, 02:57 PM   #308
Tek
Something else for you to find out.
On the Pro there are washers (I think about 1-2mm thick) that go between the bearings and the Al hex drives. Did Mugen lengthen the axles so the wheels nuts don't fall off?
Sydewynder is offline   Reply With Quote
Old 11-01-2001, 03:40 PM   #309
Originally posted by Sydewynder
Tek
The wheel nuts are thinner so the go all the way on as opposed to the thicker ones.
Earl Barnes
JGO Paintz
Old 11-01-2001, 04:08 PM   #310
Hmmm, I guess what I need is a parts list for the "pro kit" so I can compare part numbers with the older version car. I've got the universals on my car and the axle threads appear to be about 1mm shorter than the stock axles. I can't put any spacers behind the rims unless I use the HPI slimline nuts. Then I have to worry about those pulling through the rim.
Old 11-01-2001, 04:54 PM   #311
The axles on the universals have been updated. They are about 1mm longer on the threaded part. (Don't tekrsq just buy new ones )
Look for the all black ones. The old ones have silver machined areas where the bearings sit.
I too like the flanged wheelnuts better.
Old 11-01-2001, 05:37 PM   #312
Manticore's Avatar
i need the longer thread shaft too !
Old 11-01-2001, 06:16 PM   #313
Yeah, I apparently have the old ones. They have silver on the bearing races. I wonder if we can buy just the axle part? I'd hate to have to another $60 into something I already have.
Old 11-01-2001, 06:46 PM   #314
You can buy just the axle part.
Old 11-01-2001, 07:01 PM   #315
Manticore's Avatar
Need to check if the local dealer imports it. I have the rest of the CVD except the shaft !
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
