Mugen MTX-2
Old 10-29-2001, 05:36 PM
  #286
Manticore's Avatar
Originally posted by Sydewynder
Novarossi
I saw shallow countersinking in the chassis in a kit so I think Mugen changed it. Don't know why as the orignal one was better.
I was told the arm material was changed so maybe the plastic shrinks differently.
I would see what your LHS can do about the 2 speed piece.
get the kawahara 2speed unit then. it is not expensive tho.
Manticore is offline
Old 10-29-2001, 11:08 PM
  #287
Michael_T's Avatar
Trader Rating: 49 (100%+)
Intresting question 4 you all.
This is my third tuned pipe for this year (novarossi 51602---RBX12---novarossi 51603)
I noticed that the outer pulley on the centre bearing block gets extremely close to the tuned pipe, which results in the tip of the tuned pipe just bordering on the 200mm mark. The minute the car flips, there goes the tuned pipe.
Anyone notice that the tuned pipe can't be brought in any further (to prevent it hitting) because the outer pulley won't allow it to be angled in any further?
Have tried all 3 manifold this year as well with the same problem (original, RB and Novarossi manifolds)
Never had a problem with denting or damaging pipes in other cars except for the MTX because of this
Michael_T is offline
Old 10-29-2001, 11:51 PM
  #288
Angle the stinger tip down at an angle.
Sydewynder is offline
Old 10-30-2001, 01:34 AM
  #289
Michael_T's Avatar
It is W Fok, any lower and it will scrape.
Old 10-30-2001, 02:31 AM
  #290
Manticore's Avatar
Get the Kyosho Manifold for V1R !! it is wide apart from the main chassis.
Old 10-30-2001, 01:10 PM
  #291
porkybmx's Avatar
Hey guys, where can I buy the throttle linkages for the MTX? Not the wire, but the small plastic pieces that attach to the servo horn. If anyone has some spare of these please email me. Thanks
porkybmx is offline
Old 10-30-2001, 03:12 PM
  #292
psycho's Avatar
porkybmx
Try www.speedtechrc.com. If you don't find it on the webpage, email Steve and he can probably help you find it.
psycho is offline
Old 10-30-2001, 05:43 PM
  #293
try out nitro house and they have a great custoner support and always have the parts you need.
SpeedRacer16 is offline
Old 10-30-2001, 06:03 PM
  #294
Manticore's Avatar
it is not necessary to get particular the MTX2 throttle linkage kit. All other made are compatible and basically they are the same thing.
Old 10-31-2001, 05:19 PM
  #295
Has anyone seen or used the relatively new wheel spacers from Mugen (part # T0124)? They're supposed to be designed for the MTX-2 to allow 28mm wheels on the front without having to mod any steering components.
tekrsq is offline
Old 10-31-2001, 09:37 PM
  #296
I'm not sure but I am pretty sure that I whatever wheels I use on the MTX-2 I have to mod all the time or that is just because I my blocks have an odd shape. Which I doubt.
Old 10-31-2001, 10:33 PM
  #297
Michael_T's Avatar
MTX-2 Pro instructions state that if you run 30mm+ wheels, then the rear arms need to be shaved off at a certain section (refer to one of my previous post)
The spacers which have been included in the Pro are about 2-3mm in thickness. Looks like they have now been included to protect the bearing from contact with the alloy hub.
Who runs 30mm+ wheels on a Tourer anyway?? I run nothing more then 24-25mm.
Old 10-31-2001, 11:11 PM
  #298
AsphaltAssasin's Avatar
Trader Rating: 36 (100%+)
I have the Pro Spec and i do run the yokomo 26mm fronts and 32mm rear on my car with out any modifications the go on no problem and they don't scrub the uprights. I race at a Very large Track and my car handles like its on rails. It goe where I put it. It stays planted.
AsphaltAssasin is offline
Old 10-31-2001, 11:19 PM
  #299
psycho's Avatar
AsphaltAssasin
What wheels are you running? I've been using ZAC 32mm in back and they rub.
psycho is offline
Old 10-31-2001, 11:27 PM
  #300
I run the Yokomo 26mm on the Front and the Yokomo 32mm rear. No rubbing and they go right on.
