Old 10-24-2001, 07:58 PM   #271
psycho's Avatar
Sydewynder
Cool. Thanks for the info. I like the Novak synthesized receivers, but don't like the pos Hitec radio. I guess I'll be getting rid of my 3PDF's now to get the 3PJS and the Hitec module! Sweet! No more waiting for a frequency clip.
psycho is offline   Reply With Quote
Old 10-25-2001, 02:10 AM   #272
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Charging question
Just upgraded to a NiMh 1000mAH Reciever Pack.
Is 1AMP Ok at charging this battery, with no damage? Is 1AMP too much or too little?
Michael_T is offline   Reply With Quote
Old 10-25-2001, 02:33 AM   #273
The formula for optimal charging is C/10, where C = Capacity of the cells. So for cells rated at 1000 milliamps the optimal charging rate is 100 milliamps or 0.1 amps. Most people don't follow this because it take too long (about 12 hours). On my 1000 milliamp Orion packs it said to charge at no higher than 900 milliamps or 0.9 amps. I would go no more than 500 milliamps.
I personally charge my stuff over night.
For NiMh cells you have to make sure you don't over heat it if you use a higher rate. When they start to get warm you need to stop. If you don't use a peak charger with a NiMh mode, I would check the voltage with a volt meter the first couple times to get an idea how long it takes to get full charge.
With that said and done I'm sure there will be others (Like Moon ) that will say you can charge the RX pack at that (1amp) or higher rate. Just remember the sentences above in bold.
Sydewynder is offline   Reply With Quote
Old 10-25-2001, 02:57 AM   #274
Manticore's Avatar
R/C Tech Charter Subscriber
With that said and done I'm sure there will be others that will say you can charge the RX pack at that (1amp) or higher rate. Just remember the sentences above in bold.
I am the first one to say charging your receiver pack at 1AMP
I usually charge my 700mah AAA size at home at 0.7 or 0.8 amp but if i need to recharge the pack at the track i will charge it at 1 amp.
Manticore is offline   Reply With Quote
Old 10-25-2001, 03:48 AM   #275
Michael_T's Avatar
I buying the Apex Sigma Charger, which has all the fancy options including the peak cut off feature. Anyone use this or recommend anything else about $100US ? Only using the charger for my reciever pack and 2400 Nicads on my starter.
To be safe, I'll charge them at 500mA
This would take about 1.5hours right?
My real car broke down on the way to work today - flat battery. So no more truing tyres and charging batteries all on my car when I see all the boyz at the track
Old 10-25-2001, 03:57 AM   #276
Let see
1000 MAh batt / 500 MA charger rate = 2hrs. I would say about 2.5 because of losses.
Does the Apex have a TX/RX mode?
Maybe you can charge your real car battery with the APEX? j/k
Can't you get a converter and plug it in at the track to power everything? Or the track got no AC?
Old 10-25-2001, 04:13 AM   #277
Manticore's Avatar
your charging time will be at least 2 hours.
any charger will do the job as long as it doesnt make your nimh hot after charging done.
Old 10-25-2001, 04:22 AM   #278
Michael_T's Avatar
Moon + W Fok,
My friend has the same charge. My old Nicad on my old MTX was that old it kept tripping and false peaking. The APEX was the only charger that would ever charge it. He uses it to charge his NiMh RX packs, it is a digital charger with fully adjustable settings.
Old 10-25-2001, 04:28 AM   #279
Manticore's Avatar
Moon + W Fok,
I dont think it make any difference if you use low amp to charge your battery. but if the pack is getting really old then you should replace it !
I use CE pitbull for my batteries
Old 10-27-2001, 12:18 AM   #280
Michael_T's Avatar
Default Review the new Pro
Since no one has posted here in a while, I've just about completed the MTX Pro, here are the Con's i've found (Im a critic )
-Poor quality of some parts include :
Chassis - not as countersunk as previous chassis, screws are not 100% flush
Front + Rear arms need to be filed with a small needle file or the suspension will bind (tight fitting on hinges)
2-Speed Cam Housing - Buckled. Will need to replace this, as the one with the kit is tweaked!!!
These problems were found in my kit only.
Overall, excellent car, unlucky that my 2-speed Cam housing is no good, but I guess that happens ($40 down the drain )
Will post pictures soon, and will post race details.
Old 10-27-2001, 03:36 AM   #281
Trader Rating: 15 (100%+)
thats why v-one r's have 2 shoe clutch on 2 speed no worries for me
shouldnt that be under warranty?
Kyosho Superten FW-04, O.S. 4 stroke conversion, fully optioned, shelf queen... my baby!
nitro dave is offline   Reply With Quote
Old 10-27-2001, 08:47 AM   #282
Manticore's Avatar
I have both V1R and MTX2. I dont really like the 2shoe clutch on 2speed. The finger type clutch 2speed is much consistent and easier to adjust.
Old 10-27-2001, 09:00 AM   #283
i used to own a hpi with the cam type 2 speed, compared to the v-one r the 2 shoe type is smoother and more reliable and doesnt give the "jolt" into 2nd gear
but personal preference i guess
Old 10-27-2001, 09:15 AM   #284
Manticore's Avatar
I know some people like the shoe type 2speed because of the "sound" when switching gears. as a matter of fact the "finger" type 2speed is much durable. I guess
Old 10-29-2001, 01:58 PM   #285
Novarossi
I saw shallow countersinking in the chassis in a kit so I think Mugen changed it. Don't know why as the orignal one was better.
I was told the arm material was changed so maybe the plastic shrinks differently.
I would see what your LHS can do about the 2 speed piece.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
