Old 11-11-2002, 04:31 PM   #2701
Send a message via Skype™ to JordanC
ah sorry, i see which spring you mean.... I use the Gold spring.
JordanC is offline   Reply With Quote
Old 11-11-2002, 04:31 PM   #2702
psycho's Avatar
It does have a spring. it's between the adjustment nut and the clutch plate. I have both springs, but I'm not sure which is best for a higher powered engine.
psycho is offline   Reply With Quote
Old 11-11-2002, 04:34 PM   #2703
You will just need to test them both out. It's all going to depend on how the rest of your car is set up, grip level, and the track you are running on. It's one of those things you really need to go through some trial and error
Old 11-11-2002, 04:42 PM   #2704
psycho's Avatar
The main reason I asked is because I ran a couple races with the gold spring on my Collari Innotech 7 port turbo .12 and the adjustment nut kept backing out. I never had this problem with a standard MT12 engine. I like the fine adjustment that I got from that spring, but it got me thinking that maybe it was just too light for the high hp motors.
Old 11-11-2002, 05:29 PM   #2705
OOPS!!!! I goofed. I've got the 47t spur instead of the 49t. I got the gears mixed up with my MRX-3. Sorry.
tekrsq is offline   Reply With Quote
Old 11-11-2002, 07:49 PM   #2706
hurhur's Avatar
Default Re: Re: Gearing help!
Originally posted by tekrsq
I've got a RTU. You don't really need to run taller gears, but the engine does put considerably more torque on the bottom & mid range which will create wheel spin. It all depends on your track size, clutch, clutch settings, tires, & setup. I run 17/49, 21/43 on small to medium tracks, & 18/49, 22/43 0r 42 on large tracks without any problems. Also, I'm running the centax, 30% O'Donnells, and #6 R/B plugs.
the pinions u using are Mugen's? 42 spur toO?
hurhur is offline   Reply With Quote
Old 11-12-2002, 04:17 AM   #2707
Default Re: Re: Re: Gearing help!
The 42t spur is an aftermarket delrin gear made by Powerline ( www.powerlineracing.com ). The 22t is a Mugen gear for the Avance. It's a little narrower than the MTX/MRX gears, but it screws on the centax bell and can be shimmed for apprpriate spacing.
Old 11-12-2002, 05:44 AM   #2708
my 18/22 pinions are for the mtx2. I didn't know you could get a 42 tooth spur though...... cool!
Old 11-12-2002, 06:06 AM   #2709
I don't think you would put that down to the power of the motor.. the clutch would just slip. I sounds like you either have a thread problem, or something is badly out of balance. If it all seems ok, try putting a drop of loctite on the thread when you assemble it.
Old 02-02-2003, 11:26 PM   #2710
warlord385's Avatar
anybody know what foam tires came with the mtx-2 pro spec. Like what shore and brand????
warlord385 is offline   Reply With Quote
Old 02-02-2003, 11:36 PM   #2711
Send a message via AIM to Bryan N.
Brand is FastTires
Bryan N. is offline   Reply With Quote
Old 02-02-2003, 11:37 PM   #2712
warlord385's Avatar
Shore???
Old 02-02-2003, 11:41 PM   #2713
purple and double purple, there you go bro
Fast16Guy0504 is offline   Reply With Quote
Old 02-02-2003, 11:45 PM   #2714
warlord385's Avatar
Uhhhh??? can you give me the shore numbers Please???
Old 02-03-2003, 01:30 AM   #2715
Send a message via AIM to VinDollar Send a message via Yahoo to VinDollar
they are jaco foams and they are double purple in the front and purple in the rear. Jaco's don't have shore numbers just colors.
VinDollar is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
