Old 10-17-2002, 12:13 PM   #2686
InitialD's Avatar
Originally posted by Ah10
How big is your local track?
If it is big then go for RS12T then get a regular head button, if it is like medium size then go for RBX12, both are 3 port, or may be try the new Sirio 3 port engine!
Interesting... How is the RS12 different from the RB X12 when both are short rod and 3 port design?
In my opinion, both of their engine characteristics should not be any different.
Old 10-17-2002, 01:21 PM   #2687
Im2lazy's Avatar
My track is really tight with a straight that requires most cars to make their second gear clutch bell one tooth higher with standard gearing. Thanks Ah10
Any one with setups?
Im2lazy is offline   Reply With Quote
Old 10-18-2002, 02:08 AM   #2688
Im2lazy's Avatar
Unhappy
pleaseopleaseoplease!
Old 11-08-2002, 08:41 PM   #2689
kyle just go to hobbytat and ask bobby
mark
mcdhi is offline   Reply With Quote
Old 11-09-2002, 12:22 AM   #2690
Im2lazy's Avatar
you realise I asked this about 3 weeks ago
at least be timely .
Old 11-09-2002, 01:02 AM   #2691
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
TIMING is different!
Ah10 is offline   Reply With Quote
Old 11-09-2002, 01:04 AM   #2692
Ah10's Avatar
I would suggest you go RBX12, I had it before and I think it has more bottom and mid range, the RS12T has more topend! Hope it would help!
Oh one more thing you can play with the centex clutch engaging point to get more punch out of turns! it makes all the difference in the world and that's one of the reason why other ppl's car so punchy too!
Old 11-10-2002, 04:56 PM   #2693
Send a message via Skype™ to JordanC
I use an RS12 S3 on a track that you need to shorten from origional gearing. It makes a lot more torque than the origional RS12 and it's pretty much the quickest thing at the track!
p.s we only run 3 port .12's at our clubs
JordanC is offline   Reply With Quote
Old 11-11-2002, 10:22 AM   #2694
psycho's Avatar
Default Gearing help!
Are any of you running Richey RTU motors? I have a Richey modified MT12 and I remember reading somewhere that you need to run a higher gear ratio on those motors. Any thoughts?
psycho is offline   Reply With Quote
Old 11-11-2002, 03:12 PM   #2695
It must be a very torquey motor. It all depends on the track though!
Old 11-11-2002, 03:19 PM   #2696
Default Re: Gearing help!
I've got a RTU. You don't really need to run taller gears, but the engine does put considerably more torque on the bottom & mid range which will create wheel spin. It all depends on your track size, clutch, clutch settings, tires, & setup. I run 17/49, 21/43 on small to medium tracks, & 18/49, 22/43 0r 42 on large tracks without any problems. Also, I'm running the centax, 30% O'Donnells, and #6 R/B plugs.
tekrsq is offline   Reply With Quote
Old 11-11-2002, 04:11 PM   #2697
psycho's Avatar
Cool. Thanx guys. I had to hang up my nitro hat for a few months, and since then, Dennis stopped doing tuning to the public. I thought I read something that indicated that it would be a good idea to go taller. Maybe that was on overgeared cars like the Yok. I have a few gears to play around with, so I'll have to do some experimenting at the track. Thanks for your gearing #'s, tekrsq. Any idea what the internal transmission ratio is on the car?
Old 11-11-2002, 04:23 PM   #2698
Sounds pretty right. The S3 must be pretty similar. I run 16/47, 20/43 on short tracks, and 18/47, 22/43 on long tracks. I also run my clutch about 1.5mm down from the thread surface
Old 11-11-2002, 04:25 PM   #2699
psycho's Avatar
Whose centax are you running? If Mugen, which spring are you running? Black or gold?
Old 11-11-2002, 04:29 PM   #2700
I use the standard mugen pro-spec clutch. I has no spring in it. The flyweights just sit in the flywheel.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
