Old 09-01-2002, 06:20 PM   #2596
Originally posted by stefan
Once you got the two spur gears off, you'll see the damage with your bare eyes (if it's as bad already than mine)
The one-way bearing wore a groove in the shaft so bad, that I couldn't get it off anymore.
Try Castle Hobbies (RC Imports), they are the importer off Kawahara. They usually have spare parts.
FYI stefan. Castle Hobbies and RC Imports are 2 separate entities. Right now you'll be lucky to get anything out of Castle Hobbies..............it's sad.......
Sydewynder is offline   Reply With Quote
Old 09-01-2002, 09:10 PM   #2597
stefan's Avatar
Send a message via AIM to stefan
Default Guys,
I was lucky and got the last shaft that the local shop had in stock.
They told me that they probably wouldn't get any more.
I'm looking for a 6mm drill blan , 120 mm long.\
The shaft has only two holes and one flat spot, shouldn't be too hard.
stefan is offline   Reply With Quote
Old 09-01-2002, 11:33 PM   #2598
Default Re: Guys,
SO in other words, I need to put the stock 2 speed back on.
Old 09-02-2002, 01:35 AM   #2599
Send a message via ICQ to Cartman
what about a titanium one? got a source in the UK
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 09-02-2002, 06:18 AM   #2600
I'd go for titanium, if the cost was reasonable. You got a source?
tekrsq is offline   Reply With Quote
Old 09-02-2002, 07:31 AM   #2601
yep i have in uk will get onto it
Old 09-02-2002, 07:47 AM   #2602
stefan's Avatar
Default NO TITANIUM
I had that idea as well, but I talked to a master toolmaker and he told me that against public believe, Titanium is a rather soft metal. Very high density but not very hard surface.
You can use the original shaft if you drill a hole for the second drive pin into that flat area.
The best material will be a HSS drill blank with a rockwell hardness of over 60.
Old 09-02-2002, 09:21 AM   #2603
nova racer's Avatar
nova racer is offline   Reply With Quote
Old 09-02-2002, 11:47 AM   #2604
Interesting about the titanium. I did not know that. So why do people make titanium shafts for these cars if they won't last? I realize the weight reduction, but if I have to replace a $40 shaft every 2 months, that's not worth it to me.
I'll have to look into that.
I pulled the tranny apart today. I don't think my shaft has worn down. I can't feel any deformity (like a ridge) where the bearing rode. I measured the shaft and got 4.997mm all the way down (even where the bearing rode). The bearing race is considerably worn though. I got 5.18mm for the inside race. I wouldn't think a 5mm bearing would have that much slop in it. So I guess I'll try to get the bearing out and replace it. It appears to be a 5x11x4mm, but I'll double check when (if) I can get it out. I'm going to try to heat it up in the oven like you do engine cases.
Old 09-02-2002, 03:28 PM   #2605
stefan's Avatar
measure again, it should be a 6mm shaft, not 5mm
Old 09-02-2002, 03:30 PM   #2606
stefan's Avatar
oh, and btw, the shaft is wearing out where you 1st gear one-way rides.
If you second gear housing wobbles, it's just that cheap bearing. Replace it and it'll be ok.
Maybe my engines got too much power for that tranny, or maybe my first shaft wasn't hardened correctly.
I'll see how the new one does.
Old 09-02-2002, 04:26 PM   #2607
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
What kind of engine are you using?? I am starting to worry about my K shaft! I am currently running Novarossi RS12T S5, and the K 2speed has been through like 5 gallons of fuel from the RBX12T 5 port and both of these engines are very powerful!
Ah10 is offline   Reply With Quote
Old 09-02-2002, 04:42 PM   #2608
Every damn thing I have is broken. You're right. I measured it again, my digital calipers have it at 5mm, my dial calipers have it at 6mm. So what is the correct size of that damn bearing?
Old 09-02-2002, 06:39 PM   #2609
stefan's Avatar
The bearing size is 6x13mm.
AH 10, I'm running a tuned RB 5 port and a tuned MT12.
Sorry, the pics of my car will have to wait until tomorrow, the USB cable for the camera is in my office
Old 09-02-2002, 07:29 PM   #2610
Tommy
Titanium has poor surface wear properties. It is strong for the weight but not good on wear. This is the reason I don't buy Ti hinge pins and ball ends. A 2 speed shaft where the 1-way bearing rides on is a no no.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
