Old 08-27-2002, 03:03 AM   #2536
Send a message via ICQ to Cartman
Default jp engine
any one know what the red stuff is in the crank and what it does?
have you tried a S3 crank in a MT? and what does the tear drop bit do on the crank webing, talking non turbo!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 08-27-2002, 10:51 AM   #2537
Mike Mandio's Avatar
Originally posted by mobil1rac
*I see you are running the one-way,what type of rear diff oil are you using? The set-up looks like it will hook-up on almost any size track, are you running anything different between a short tight track and a huge track like hampton ohio. Do you have any good suggestions on a good gear selection that might stay up with the tc-3's and serpents. I got blown out of the water at nats due to not enough gears.We tried every combo, but nothing helped.I live in Md and there is a new track coming to town, approx 280 by 150. Same as nats, except looks a little more complex.Just looking for top end(last third of the straight)
Do you have more information on the new track?
Mike Mandio is offline   Reply With Quote
Old 08-27-2002, 04:31 PM   #2538
The track that I am speaking of will be held at the Dulles Town Cntr. in Virginia. The races will be every other weekend, but running on both sat and sun. Saturday will be a few hours of practice then three rounds of qualifying. Sunday will be practice for 1-2 hrs. then two qualifying and then the mains. They are running all gas classes thru 1/8 scale.The web site is dc-rc.pinoysites.com or you can fing it on the novarossi's web site (front page). He has to limit it to 160 entries until they get a rythm on how things are going. I have been told there are guys coming from all over the east coast to run it. He has been in contact with the local hotels and have gotten great rates for the drivers. Finally a huge track has come to the east.
Check it out!!!The pictures of the layout are on the site. Let me know what you think. Lots of gearing and motor.Just like Ohio.
mobil1rac is offline   Reply With Quote
Old 08-28-2002, 12:33 AM   #2539
FREAKAH's Avatar
Default Re: jp engine
I believe the red stuff is some kind of ceramic epoxy. It acts as a fuel/air ramp to direct it towards the back of the crank and also to reduce puddling in the crank bore when the air/fuel charge enters the crank port at high velocity. Please correct me if i'm wrong.
As for the tear drop bit, I have'nt seen the S3 crank yet so I could'nt comment on it.
FREAKAH is offline   Reply With Quote
Old 08-28-2002, 05:19 PM   #2540
Can anyone tell me where I can find Jtek mega .12 motor made by nova mega. Does anyone know anything about the motor.
Or can you tell me where I can find a pistion and button combo that has the dimple in the pistion.Locvated on the top of the pistion. Thanks for the help!!!
Old 08-28-2002, 06:36 PM   #2541
Check this out!!!!!!!
http://www.mugenracing.com/whatsnew/mtx3page.html
tekrsq is offline   Reply With Quote
Old 08-28-2002, 06:45 PM   #2542
broughamlover's Avatar
Talking hell yea
that"s what i've been looking for
broughamlover is offline   Reply With Quote
Old 08-28-2002, 07:14 PM   #2543
Regional Moderator
racer rich's Avatar
I like the idea of the laydown servo but I don't like the idea of the off-centered fuel tank. IMO the only advantage of a 3-belt driven nitro touring car is to have that fuel tank in the center of the top-deck. Otherwise you can get the same chassis balance out of a NTC3, with the huge advantages of shaft-drive. It really does not look incredibly similar to a MRX-3 either. I will be waiting to see how this baby does on the track though.
racer rich is offline   Reply With Quote
Old 08-28-2002, 07:19 PM   #2544
Manbik's Avatar
It looks very close to an MRX-3. Look at the rear, all the same adjustments are there. Notice the two speed is the MRX-3's just a smaller scale, no more of that dinky lever shifter thing.
Though it may look different all the engineering ideas are there. Very cool car!
Get back to work Rich and save a life.
Manbik is offline   Reply With Quote
Old 08-28-2002, 07:25 PM   #2545
Default avatar
hey, how can i get one of those cool moving avatars?
Old 08-29-2002, 07:34 AM   #2546
Looks like alot of fun. I've never run on a track that size. It's only two hours from Delaware, looks like a road trip.
Old 08-29-2002, 09:16 AM   #2547
ausracer's Avatar
hey racer rich the tank is in the centre of the chassis. it just looks to the side because the upper deck doesnt go as far across on the pipe side. how long do you guys think it will take for these cars to get to the hobby shops. i wish they could have included a floating body mount though, maybe an upgrade.
ausracer is offline   Reply With Quote
Old 08-29-2002, 09:20 AM   #2548
stefan's Avatar
Send a message via AIM to stefan
No, the tank is not in the middle:
stefan is offline   Reply With Quote
Old 08-29-2002, 09:44 AM   #2549
Manticore's Avatar
R/C Tech Charter Subscriber
some observation on the new car according to the computer graphic:-
- almost identical front end except front bulk head.
- use MTX2 arms (6 pcs) and knuckles
- newly design shocks (those shocks have been available at our shops here)
- longer lever point rear sway bar. different thickness sway bar would be available?
- rear shock tower has been seperated from body tower. I think the rear floating mount could be available as an option or under a seperate kit version?
- steering servo has laid down and receiver pack recessed into the main chassis. however the design of fuel tank is in doubt to keep the car in low CG when it is full?
- looks like the upper deck would be woven graphite one as the MRX-3?
anyway, this is one sweet car!
Manticore is offline   Reply With Quote
Old 08-29-2002, 10:44 AM   #2550
None of the arms are carried over from the mtx-2. Look closely at the pics and you'll see the differences. They don't appear interchangeable from left to right either. The knuckles appear the same however.
I guess its time to sell my mtx-2. But this new car looks sick. Glad I don't have to get a ntc3 next season anymore.
rcpilot is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
