Old 10-21-2001, 02:52 AM   #241
Originally posted by Novarossi
The wheel bearing just slightly binds, the spacer/washer makes a huge difference.
The instructions show a shaded area on the top of each rear hub to cut off for 30+mm wheels. Looks like a fairly big chop, not sure if it would weaken the arm in any way.
Looking at buying the Pro W Fok?
Nah my car is pro spec and then some. lol j/k
So you're saying that the spacer goes between the outer bearing and the hex drive to take up slop? Kawada use to make aluminum (ok for you aussies aluminium ) set up that has spacers like that but also spacer that go inside the upright between the bearings. This way you can crank the wheel nut down as tight as you want and not bind the bearings.
I have some 30mm wheels that I never put on but was also told to shave the rear uprights. Do you have any pics of where?
Danks again!
Sydewynder is offline   Reply With Quote
Old 10-21-2001, 03:31 AM   #242
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Danks again!
OK Wfok, here is one of fancy Paintbrush drawings. I did the best I can to copy the picture from the instruction manual. As you can see, the shaded area is what they want you to shave off. It is extremely close to the rear camber link holes, and would weaken the rear upright.
Thank goodness I use a maximum of 27mm rears
The wording on the picture attached is worded exactly off the instruction booklet.
Enjoy
Michael_T is offline   Reply With Quote
Old 10-21-2001, 03:50 AM   #243
Enjoy
Ok thanks. This drawing is much better than the droop stop grub screw drawing.
I was told to use the inside holes for the links so I guess cutting so close to the outside ones won't matter. I will have to see.
Old 10-21-2001, 03:53 AM   #244
One more thing, I'm playing around with the Hitec Spectra module with a Novak XXtra in the 3PJS and it works. No more crystals and I have all the channels. Yippee.
Don't know if you use 75 MHz in AUS but if you do.....
Old 10-21-2001, 04:13 AM   #245
Michael_T's Avatar
75mHz is not legal here in Australia
Not only that, 29mhz (my band) PCM Futaba crystals have been out of stock here in Australia for almost 1 year now with still no word on whether they will stock them. What makes the matter worse is 29mHz is illegal in most countrys which makes importing them even harder. We have been 'sharing' PCM crystals here
And yes, according to the standard setup sheet, the inside hole is the one to use
Old 10-21-2001, 04:16 AM   #246
Manticore's Avatar
R/C Tech Charter Subscriber
great. lets stop about the breakage arguement.
the rear hex hub spacer is to widen the rear end and to accommodate wider tire.
NR: please post your setup for foam tire as I want to run foam tire at a tight but high traction track here.
Manticore is offline   Reply With Quote
Old 10-21-2001, 04:17 AM   #247
Manticore's Avatar
I think you can install another servo on your car for switching channel !!
Old 10-21-2001, 04:24 AM   #248
Michael_T's Avatar
Very funny Moon , have you been asking W Fok for some jokes lol
Old 10-21-2001, 04:53 AM   #249
Manticore's Avatar
I didnt, he is funny guy as a matter of fact !
Old 10-21-2001, 04:58 AM   #250
Michael_T's Avatar
Yeh, I heard his driving makes everyone laugh
Old 10-21-2001, 05:16 AM   #251
Aw talking behind my back now Novarossi.
I didn't start the CA in eye jokes if you remember. It was your Aussie buds thank you.
And besides Moon was talking to me about using a 3rd servo to switch channels not you (see quote) so LOL
Boy I just don't know why the Aussies do everything backwards. Use some band no one else uses so they can't get crystals??? And even the toilet water spins the wrong way.
Old 10-21-2001, 05:26 AM   #252
Manticore's Avatar
That can be explained with the climate !!!
Old 10-21-2001, 05:32 AM   #253
Michael_T's Avatar
Intresting question and wayyyyyyy off the topic
What happens in a plane, the toliet flush will spin the correct way (for you yanks) over America, will it begin to spin the 'other' way when you get closer to Australia, if so when and why?
Old 10-21-2001, 05:33 AM   #254
Manticore's Avatar
Looks like it is going to start another arguement !
Old 10-21-2001, 05:36 AM   #255
Michael_T's Avatar
A World Championship winning manuafacturer produces a touring car with no faults......hey we gotta try and argue about something
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
