Old 08-12-2002, 08:21 AM   #2461
Racmark's Avatar
Anybody got the news from any reliable source, maybe from Mugen themselves. So far, it has just been hear say and no one can really confirm.
I have a MTX2 and looking for another car, I'm thinking of the GTR R spec but will like to find out more of the MTX3 before making a decision.
Racmark is offline   Reply With Quote
Old 08-12-2002, 09:35 AM   #2462
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Centax clutch adjustment
Originally posted by Hard Jokur
I have no freakin Idea on how to adjust this thing.... the stock mugen centax, just keeps bangin, the clutch doesn't engage like my serpent one does (silky smooth) this one seems like a 2 speed hit....
I know it's adjustment but I dunno where to look .
and Ideas mayme I over looked sumthin
Your adjustment nut probably screwed too far in, meaning the spring is compressed too much so it revs up pretty high and when it engages it just shoot out like a rocket!
This is just a reference to go with but it might not be accurate because of the gap between the flywheel and the engine block varies..... anyway, first try to line up the adjustment nut flush with the flywheel locking nut then work your way in until you find the perfect engaging point.
Hope that help!
Ah10 is offline   Reply With Quote
Old 08-12-2002, 09:46 AM   #2463
Send a message via ICQ to Cartman
Default Re: Re: Centax clutch adjustment
Hope that help!
why dont you just set it as the mugen instructions????
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 08-12-2002, 09:59 AM   #2464
Default mtx2
mtx3
is coming just hold on !
it is said that it will debut at the chicago show from what i hear .
they may have a posted picture.
it is going to be a 200 mm mrx3 , low cg battery pack on lower
chassis in the middle and front drive belt on the side ...
isuzuguy is offline   Reply With Quote
Old 08-12-2002, 01:39 PM   #2465
RAP66's Avatar
Default Re: Re: Re: Centax clutch adjustment
WHat Directions?? all I got was a lil teeny weeny piece of paper, that shows the parts...
hehehehe
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 08-12-2002, 03:10 PM   #2466
Default Re: Re: Re: Re: Centax clutch adjustment
[QUOTE]Originally posted by Hard Jokur
hehehehe
[/QUOTE
.8 mm clutch nut from flywheel nut to adjuster and .3 mm end float using the flat shims!
Old 08-12-2002, 03:25 PM   #2467
Ah10's Avatar
Default Re: Re: Re: Re: Re: Centax clutch adjustment
[QUOTE]Originally posted by Cartman
hehehehe
[/QUOTE
That is vary from engine to engine and as well as collet thickness and if you put the washer between collet and main bearing! so the spec that you provide might no work with different ppl!
Old 08-12-2002, 07:00 PM   #2468
Racmark's Avatar
Default Re: mtx2
Originally posted by isuzuguy
mtx3
Hi! May I know when is this Chicago show and what's the name for it?
Old 08-13-2002, 01:55 AM   #2469
Default Re: Re: Re: Re: Re: Re: Centax clutch adjustment
no the settings will be the same as the nut will still sit the same palce on the flywheel!!!!
Old 08-13-2002, 02:10 AM   #2470
Ah10's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Centax clutch adjustment
The nut do sit the same place but the flywheel locking nut doesnt and that will affect the travel point, I am referring to the the end of the flywheel locking nut to the tip of the crank shaft!
Old 08-13-2002, 04:16 AM   #2471
Default Re: Re: Re: Re: Re: Re: Re: Re: Centax clutch adjustment
still will not make any differance as you measure the end of the flywheel nut to end of crank, then the adjusting nut to the end of crank, you then need a diferance of .8mm
honest i am correct trust me
Old 08-13-2002, 08:42 AM   #2472
Manbik's Avatar
Default Re: Re: mtx2
http://www.ihobbyexpo.com/public.cfm
Manbik is offline   Reply With Quote
Old 08-13-2002, 09:43 AM   #2473
Racmark's Avatar
Anyone going for the Chicago show? Please try to get info of the MTX 3 for posting! I'm sure many Mtx owners would be interested.
Thanks!
Old 08-13-2002, 09:45 AM   #2474
Ah10's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Centax clutch adjustment
Oh I see what you mean now! you measure it 0.08mm from the tip of the flywheel nut to the adjusting nut, I thought you measure it from the tip of the crank to the adjusting nut, because mine is at 8.62mm from the tip of the crank!
Old 08-13-2002, 10:03 AM   #2475
dtm
dtm's Avatar
Send a message via ICQ to dtm
Thanks!
MTX 3!! Ah well...time to clean up the MTX 2 and get rid of it on the S/H market while it is still worth some money!!!
dtm is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
