Mugen MTX-2
#2327
Originally posted by tekrsq
I use the split as my "overdrive" with the one-way. Since it's too much of a pain to keep switching pullies, I just tru my rear tires down. I try to keep a 3mm split between the front and rear. That does nice for me.
#2328
I'm running the Kawahara one-way with a stock sized pulley, I think it's 39t. Kawahara has an "overdrive" pulley available (I think 36t), but I haven't tried it because it's not worth it to me having to pull the entire front end apart to change back and forth depending on track conditions. The rest of my pullies are Kose aluminum and I have stock belts.
#2329
Re: Re: Re: Re: micro ss centax clutch
Originally posted by Ah10
1, it comes with low cg mount and thrust bearing, just one item number. SpeedtechRc has it in stock! click Here, just scroll down to the bottom.
2, Thrust bearing..... hum....here you will find all the information you need on thrust bearing.
3, if it grabs hard then that means the clutch is not slipping, slipping = less speed because the engine gives 100% but only may be 70% of the power transfer to the transmission!
4, you can get the kawahara centex clutch from SpeedtechRC, I just link you from point 1.
Later
#2330
Re: Re: Re: Re: Re: micro ss centax clutch
Originally posted by Pepe
Thanks Ah10, I think I'll give it a try.
Later
Later
#2331
tekrsq
standard is 36, overdrive is 34
#2332
Re: tekrsq
#2334
I have to do a lil self promoting here, so bare with me.
I started a new site with a new domain name called MRX3.com. I am in need of a logo so I started a contest and I will be giving away a Mugen Seiki Chair to the winner. What self respecting Mugen owner wouldn't want one?
Check the MRX3.com site for details of course.
#2335
Set up sheet
does any one have a set up sheet that can be edited on the pc as apose to hand writing then scanning???
#2336
I got one but you need a very expensive program from Acrobat to edit them...
#2337
#2338
Originally posted by Cartman
i have adobe acrobat reader is that it, supose i could always eh hmm aquire a copy!! any chance you could mail it me???
i have one in pdf format and you can edit and print using acrobat reader.
#2340
