Old 07-07-2002, 02:34 AM   #2281
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: Engine wear
Originally posted by Cartman
ok i have a JP engine and i posted it was cutting and poor idle i have done a stip and the rod is loose on the crank pin, tried a new rod and still the same though not as bad!
what could cause this?? i have only done 4 nationals (curently 3rd ) and two club meetings old???
and can you post a link to jp i cant find it
Cartman, as I said above, it sounds like you have an airleak, check the carb and head.
Michael_T is offline   Reply With Quote
Old 07-07-2002, 03:22 AM   #2282
Send a message via ICQ to Cartman
Default Re: Re: Engine wear
the crank pin and the rod badly worn this is the fault, I did find a pin hole in the fuel pipe so it must have been running lean, I now need a piston/liner/crank for my JP
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 07-07-2002, 05:50 AM   #2283
nova racer's Avatar
Default Re: Re: Re: Engine wear
the crank should be fine and you can just get a plain nova rod and piston and sleeve just copy the work that was done to the sleeve. or try somethung different like gen 2 rtu sleeve. well i think that it was gen 2 well it is a pic from rcca
nova racer is offline   Reply With Quote
Old 07-07-2002, 08:28 AM   #2284
Default Re: Re: Re: Re: Engine wear
have measured the crank pin and its tappered and oval so it is dead!!
going to let osrocket treat the liner
Old 07-07-2002, 03:10 PM   #2285
Jaco has a new line of foam tires and they are 30mm wide. There has to be a way to fit these tires on the front. If not I wish there was. I know about the rear arm conversion by Kawahara. I thought they had a front steering knuckle conversion also. Guys with NTC3's had these things on full width and I had to cut mine down to about 24-25mm front and back. The Mugen was still good but I had some push. With a one way no less.
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 07-07-2002, 11:20 PM   #2286
Manbik's Avatar
Hi fellas, just to let you know... I will be removing the MTX-2 pages on my site in a month or so. Even though I posted on the front page that I don't maintain that site, I still get a lot of E-mails about it.
Any information that carries over to the MRX-3 will move over to the MRX-3 pages (Spring charts, etc). Anything specific to the MTX-2 will be removed all together so you may want to come over and download anything that you may need in the next few weeks.
*edit*
If anyone has or knows of a good quality MTX-2 site, I will link that site on the sole remaining page when I am done.
Manbik is offline   Reply With Quote
Old 07-08-2002, 03:26 AM   #2287
*edit*
Why Mr Jenkins?
Sydewynder is offline   Reply With Quote
Old 07-08-2002, 04:19 AM   #2288
*edit*
Can't you leave it there??
Old 07-08-2002, 04:20 AM   #2289
Default worn cranks
does anyone repair the crank pin if its worn??
Old 07-08-2002, 04:43 AM   #2290
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: worn cranks
buy a new one !
Manticore is offline   Reply With Quote
Old 07-08-2002, 05:19 AM   #2291
Default Alluminium pulleys
Does anybody have alluminium pulleys on their MTX-2? Do they still get wrecked if a small stone gets caught in them? Are the mugen pulleys OK or are there other brands?
I am sure AH10 has them as they are a hop-up item!
SHARP is offline   Reply With Quote
Old 07-08-2002, 05:31 AM   #2292
Default Re: Re: worn cranks
Originally posted by Manticore
buy a new one !
im too tight and its a JP whats the red stuff in the middle?
Old 07-08-2002, 06:13 AM   #2293
Any info?
Old 07-08-2002, 06:21 AM   #2294
RC Nitro's Avatar
SHARP: I use the Kawahara in mine and have no problems with stones like I use to with the stock plastic.
RC Nitro is offline   Reply With Quote
Old 07-08-2002, 06:28 AM   #2295
Any info?
Isaac, I think it is better for you to use 26 mm in the front. If you use 1mm washer in the front you won't need to trim the tires.
Where in MD do you race?
Later
Pepe is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
