Old 07-03-2002, 06:15 AM   #2266
Send a message via AIM to Mugen Player Send a message via Yahoo to Mugen Player
Default Check this out.
There is a hobbyshop in Singapore selling Mugen KIt at low price. Just got a MTX2 Pro for only Singapore $510.
Mugen Player is offline   Reply With Quote
Old 07-03-2002, 08:13 AM   #2267
Default Re: Check this out.
Are they online ??
muugen is offline   Reply With Quote
Old 07-03-2002, 11:13 AM   #2268
Post Re:- grip roll
Thanks Novarossi, we only have the blue springs that came with the pro kit & the silver/ no colour springs that look like a different wire gauge heavier front/short & softer long/rear. Can you help as far as the colour/ spring rate progression for the Mugen springs is concerned, we do have some X-ray/ serpent springs that are the same outer dia but look like different wire gauge are these of any use?
Raw40 is offline   Reply With Quote
Old 07-03-2002, 11:50 AM   #2269
Default Re: Re:- grip roll
Raw 40,
I would try the following:
(remember to do one change at the time !!!)
- Take the rear sway bar off. My car is handling better with out it.
- Lower the height: 5mm rear 4mm front
- Use Mugen purple springs in the rear
What camber toe in/out (s) are you using??
Good luck
Pepe is offline   Reply With Quote
Old 07-03-2002, 01:12 PM   #2270
Default Re: grip/ traction roll
My son ran the MTX2 at the club meeting for the first time on Sunday, started on an old set of rubber tyres stock set-up out of the box, car handled like a dream slight amount of slide in a corner but easily controlled. Changed to a set of new foams for the last few heats & finals car handled even better : ). Only one problem added the rear anti roll bar and the car started to grip roll in some of the slower corners, any suggestions on how to cure the problem.
Set-up is as follows: -
Front end:
Ride height 6mm
Blue springs
4 X 1mm holes in pistons kit 600w oil
Lowest hole on upper shock mount
40 shore foams
4mm droop
Standard diff kit 30000w oil
Anti roll bar fitted blades vertical (max setting)
Rear end
Ride height 6mm
Blue springs
3 X 1mm holes in pistons kit 600w oil
Middle hole on upper shock mount
35 shore foams
8mm droop
Standard diff 5000w oil
he loves this car
Hi Pepe, heres the set up from my earlier post. How many different springs are available for the mugen i.e. how many different colours/ rates and what order softest to hardest. I'm running 2deg of camber all round, 1deg toe-in on front and 3deg toe-in on rear.
Thanks for you help.
Old 07-03-2002, 10:27 PM   #2271
Default mtx2 kit
Hey guys do they still sell any of the following kits?
*mtx2 chassis kit
*mtx2 engine kit
If so where can i get one(buying for spare parts).?
NISMO is offline   Reply With Quote
Old 07-03-2002, 11:46 PM   #2272
InitialD's Avatar
I have heard that the Xray/Seprent springs have the same rates as the Mugens. So chances that the springs are having the same diameter will infer that they possibly have the same rate. The hardest to softest Xray/Seprent springs are as follows;
Blue
Red
Yellow
White
Orange
Hope this helps.
Old 07-04-2002, 01:15 AM   #2273
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Spring rates can be found at www.jasonjenkins.com
Michael_T is offline   Reply With Quote
Old 07-04-2002, 03:52 PM   #2274
Default Tyre question (Sort of!)
Hi Guys,
I came across an article in a RC mag. which talked about a new liquid for removing tyres from rims.
For the life of me I cannot find the article again!!!
I've tried the boiling in water trick which sorta works.
If anbody knows the name of this liquid tyre remover product please put me out of my misery!
All the best
click, dublin is offline   Reply With Quote
Old 07-04-2002, 04:11 PM   #2275
Post Re:- tyre removal fluid
Trakside solutions is what your looking for iv'e been using it for about a year woderfull stuff leaves the rims like new the old tyres just peel off. WWW.rcracenews.co.uk/trackside:)
Old 07-04-2002, 09:47 PM   #2276
Send a message via ICQ to David
Default Re: Tyre question (Sort of!)
Originally posted by click, dublin
Hi Guys,
All the best
acetone work also
but if you have cheap rims they will melt too..
David is offline   Reply With Quote
Old 07-05-2002, 09:52 AM   #2277
Default Re: Re: grip/ traction roll
Did it work?
Old 07-06-2002, 01:30 AM   #2278
Send a message via ICQ to Cartman
Default Engine wear
ok i have a JP engine and i posted it was cutting and poor idle i have done a stip and the rod is loose on the crank pin, tried a new rod and still the same though not as bad!
what could cause this?? i have only done 4 nationals (curently 3rd ) and two club meetings old???
and can you post a link to jp i cant find it
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 07-06-2002, 04:16 AM   #2279
Post Re :- grip roll
Hi Pepe, we haven't had time to get down to the track yet, hopefully we'll be able to get down there next week, I'll let you know how things go.
Old 07-06-2002, 05:21 AM   #2280
http://www.jpracing.com/
SHARP is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
