Old 07-02-2002, 06:11 AM   #2251
Originally posted by Novarossi
Since I haven't posted a body picture in ages, here is my current one causing choas - Big enough for you Fokkie and Moonie?
Picture too dark.
Sydewynder is offline   Reply With Quote
Old 07-02-2002, 06:26 AM   #2252
antoniop's Avatar
I'm blind I'm blind ....
antoniop is offline   Reply With Quote
Old 07-02-2002, 06:56 AM   #2253
nova racer's Avatar
here
nova racer is offline   Reply With Quote
Old 07-02-2002, 08:21 AM   #2254
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally posted by Sydewynder
Picture too dark.
Sorry Fokkie, I'll take it to a studio and make sure I get the lighting right
Michael_T is offline   Reply With Quote
Old 07-02-2002, 10:23 AM   #2255
I am surprised that Sydewynder didn't tease you about the missing wheel nuts!
[/B]
Pepe is offline   Reply With Quote
Old 07-02-2002, 10:25 AM   #2256
Nice painting job BTW
Old 07-02-2002, 11:38 AM   #2257
stefan's Avatar
Send a message via AIM to stefan
Woooowwww,
invisible wheel nuts!!
stefan is offline   Reply With Quote
Old 07-02-2002, 12:10 PM   #2258
psycho's Avatar
I bet they are really lightweight too!
psycho is offline   Reply With Quote
Old 07-02-2002, 12:15 PM   #2259
Post grip/ traction roll
My son ran the MTX2 at the club meeting for the first time on Sunday, started on an old set of rubber tyres stock set-up out of the box, car handled like a dream slight amount of slide in a corner but easily controlled. Changed to a set of new foams for the last few heats & finals car handled even better : ). Only one problem added the rear anti roll bar and the car started to grip roll in some of the slower corners, any suggestions on how to cure the problem.
Set-up is as follows: -
Front end:
Ride height 6mm
Blue springs
4 X 1mm holes in pistons kit 600w oil
Lowest hole on upper shock mount
40 shore foams
4mm droop
Standard diff kit 30000w oil
Anti roll bar fitted blades vertical (max setting)
Rear end
Ride height 6mm
Blue springs
3 X 1mm holes in pistons kit 600w oil
Middle hole on upper shock mount
35 shore foams
8mm droop
Standard diff 5000w oil
he loves this car
Raw40 is offline   Reply With Quote
Old 07-02-2002, 02:23 PM   #2260
[/B]
Oh darn I missed that one. Must be the picture's too dark.
Old 07-02-2002, 02:37 PM   #2261
psycho's Avatar
Default Re: grip/ traction roll
Raw40
Try playing around with these things. Harder tires will reduce traction. I usually run 45 shore front/40 shore rear or 42 shore front/37 shore rear. Cutting the tires down will reduce side bite and reduce traction rolling problems. I usually run 62.5mm tire diameter. Also make sure to put a good bevel on the edges of the tires. Finally, try reducing the amount of droop that you are running. I would start off with 2mm front droop and 3mm rear droop and tune from there. Good luck!
Old 07-02-2002, 03:11 PM   #2262
More negative camber.
Old 07-02-2002, 03:27 PM   #2263
Post Re:- grip roll
sydewynder & psycho thanks for the info.
Old 07-03-2002, 12:59 AM   #2264
Michael_T's Avatar
Front end:
Ride height 6mm
Blue springs
40 shore foams
4mm droop
Rear end
Ride height 6mm
Blue springs
35 shore foams
8mm droop
he loves this car
Simply solution, adding the rear sway bar (or increasing the tension) adds more steering to the front of the car. You'll need to go up to a stiffer front spring Try and set and work around the car with both front/rear swaybars set to middle tension, the car will turn and handle flatter.
Old 07-03-2002, 01:02 AM   #2265
Michael_T's Avatar
Damn, thats why the car wasn't handling the other day
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
