Mugen MTX-2
#2237
droop
what droop is best to start with
and what dose it actualy do
eny help appreciated
#2238
Originally posted by Diva
Nice car. You don't run VDS, do you?
BTW, are you still running your modeltech BL?
Yeah still running the BL. It's an amazing motor. I run it whenever I can. It's faster than the Mugen!!!
Sorry, what is VDS??
#2239
Originally posted by antoniop
Hi Diva
Hi Diva
#2240
Aaahhh,
No, just touring car bodies over here. However we are allowed to use 30mm foams.
To be honest, I hate those bodies...
#2241
more spring rates
#2242
Pinion gear tool
does any one have this tool, and could explain what the pieces do?
http://www.mugenracing.com/media/B0513.jpg
Does the piece on the bottom of the picture go around the gear?
What stops the clutchbell turning? Does the clutchbell have to be removed from the engine? Is there anything better for removing pinions? Does this tool work with Centax? Thanks for all help!
#2243
Re: Pinion gear tool
Does this confuse you enough? Because I always look messy when Im trying to rip off pinions
#2245
Exhaust
Rosi i see you have a JP what do you think?
Mine started cutting and having eratic idle, any idea's, been told might be air leak or conrod!!
also has anyone had any luck repairing the soldered joints etc on pipes , or do you know how/what to use??
#2246
Re: Exhaust
The JP is a great engine, but like most modified engines, its tricky to get running right. There were a few complaints down here about a weak rod, and an air leak in the carb. My head was actually loose when I first purchased it. Do you notice any oil or leaks coming out of the engine? Seal the carb if you can, and pay special attention to any other odd things. With standard Nova engines, you can be about 5-10% off the ideal needle settings and still run ok. I've noticed with the JP's, you need to be spot on with your carb settings to have them running right. The engine also seems to run slightly hotter then most. Mine runs at about 100-110 degree Celius and uses a Number 5 Gold Nova plug using Trinty fuel.
My advise, keep tuning
#2247
Re: Re: Pinion gear tool
Originally posted by Novarossi
The pinions and flywheel go into the main holder, tighten the grub screws on each side and use the metal rod to insert in the little hole in the clutch bell(for adjusting the clutch) to stop it from spinning around. You'll then need to use the large allen key and insert the middle rod straight through the clutchbell.
I don't have this tool, just wondering if its worth getting.
Also are the side windows on your shell cut out?
#2248
Re: Exhaust
#2249
Re: Re: Re: Pinion gear tool
So the main holder + the grub screws is like a spanner for the pinions? Can't you just put the small rod in the hole in the bell and undo the pinions without taking clutch bell of the engine?
Yes the side windows are cut out. I never used to cut them out, until one day I was bored at the track, and tested the engine with bodyshell with side windows intact and then removed the side windows. The end result was same handling and 4 Degree (C) cooler engine . All the top racers here cut the side windows out (which is allowed under IFMAR rules)
#2250
Thanks Novarossi
