Old 06-26-2002, 06:54 PM   #2221
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Sydewynder
Did that a couple of times. Once with a very light coat of oneway grease. Once with no grease per the great Manticore and Novarossi. Still sqeals like a pig.
you have problem with the oneway when you gease. I have neer geased the oneway bearing and I have never had a problem with it.
Manticore is offline   Reply With Quote
Old 06-26-2002, 07:28 PM   #2222
Originally posted by Manticore
check your gear alignment. the axle of the gears are not parallel.
Which gears?
I noticed I need new pinions though. All worn out. Could that be it?
Sydewynder is offline   Reply With Quote
Old 06-26-2002, 07:33 PM   #2223
I never put a gease in my bearings. They make honking noises when you try to jam them in.
Ok no grease but you need to put on your old man glasses. You're skipping letters in the words you type.
Now waiting for Novarossi to give me a scolding.
Old 06-26-2002, 07:35 PM   #2224
ops sorry but your washing machine needs not to work when people push their car down the hill, isnt it?
At least it doesn't squeal like a pig. It just burps fuel all over you when you try to prime it.
Old 06-26-2002, 07:41 PM   #2225
Manticore's Avatar
Which gears?
of cuz spur and pinion alignment. which other gears you think I am talking about Dear Fokie !
Old 06-26-2002, 07:42 PM   #2226
Manticore's Avatar
ok ok, i missed letter but never miss a dot !
Old 06-26-2002, 08:04 PM   #2227
Gears are aligned dear Manti/Moony. I checked that's how I noticed the pinions are all worn out.
Old 06-27-2002, 03:33 AM   #2228
nova racer's Avatar
the greese is your problem that greese is for other 1 way bearings like front 1 way and 1 way pullies now the 2 speed 1way works well with a good quality motor oil like mobil 1 or slick50. make sure that you clean every bit of greese out if the 1 way. Motor spray works well for that and some time for the greese that is very hard to ger out i had to soak mine in tide over night and rinsed it out with hot water then sprayed it with motor spray and re oil it and it workes better than new
nova racer is offline   Reply With Quote
Old 06-27-2002, 04:25 AM   #2229
mugenman's Avatar
Send a message via ICQ to mugenman
also check to make shore the flywheel hasent come loose.
mugenman is offline   Reply With Quote
Old 06-27-2002, 04:29 AM   #2230
RC Nitro's Avatar
sydewynder: Sounds like the 1 way is having problems. My super acted like the clutch was slipping and worked great in 2nd when that 1 way died. Used the HPI greese in that. Use the Serpent 1 way lub they have for 1/8 scale. Smells and feels like kerosene. Works better than grease.
RC Nitro is offline   Reply With Quote
Old 06-27-2002, 01:25 PM   #2231
Just noticed a ?painted? spot on the shaft where the oneway bearing rides on. Anyone with a Kawahara shoe type 2 speed shaft? Can you see if yours have to dark gray/black spot?
Thanks all for the replies and suggestions.
Old 06-27-2002, 02:08 PM   #2232
antoniop's Avatar
Here are a couple of pics of my MTX2 with some hop ups
Body HPI BMW GT
Another view of the body
Kawahara Top Deck
...the other side
Kawahara Brake plate (excellent, includes bearing)
Kawahara Front belt tensioner
Hope you like the lillte bugger....
It has a Team Orion Wasp .12 RE engine (a real blast) and a inline manifold and pipe from Picco (the engine is made by Picco, so...)
Mugen Centax and a few other "little" things
antoniop is offline   Reply With Quote
Old 06-27-2002, 03:38 PM   #2233
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
[QUOTE]Originally posted by antoniop
Very Nice!!!!!!!!!
Ah10 is offline   Reply With Quote
Old 06-28-2002, 01:01 AM   #2234
Diva's Avatar
Send a message via Yahoo to Diva
Nice car. You don't run VDS, do you?
BTW, are you still running your modeltech BL?
Diva is offline   Reply With Quote
Old 06-28-2002, 04:16 AM   #2235
RC Nitro's Avatar
antoniop: Nice car. I run the Kawahara brake and deck also. Try mounting an Ofna brick pack on the chassis behind the pipe mount. Then remove the hump pack and install the radio there. Lowers CG and gets radio inboard
Sydewynder: I have the Kawahara 2 speed and no spot on the shaft on mine.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
