Old 06-21-2002, 04:56 PM   #2146
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Originally posted by tekrsq
Interesting you guys are having problems with the negative diff. I hadn't thought about it because I haven't had any problems, BUT I smoothed out the edges of my bevel gears before I put them in. I had problems with the regular diffs locking because of that, and got in the habit of smoothing them out anyway.
So I guess I am right! once you smooth out the end of the shaft then it will solve the locking problem!!
Ah10 is offline   Reply With Quote
Old 06-21-2002, 05:08 PM   #2147
No mine is fine in regards to not working or locking up. I just don't like the way the car drives with that diff in it.
I smoothed out the edges of the bevel gears and even the casting nibs on the backside regardless of where I put them in.
Sydewynder is offline   Reply With Quote
Old 06-21-2002, 06:45 PM   #2148
Manticore's Avatar
Originally posted by Cartman
NO NO NO bin the oil and buy some proper stuff get some motocross air oil its far better.
agree, nobody use silicon oil on filter, silicon oil under spark will become glass particle which will kill your plug and likely your engine.
Manticore is offline   Reply With Quote
Old 06-21-2002, 11:55 PM   #2149
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: caster change
Originally posted by Raw40
Phsyco, thanks for the info on the air filter.
Nova racer, hi in one of your last posts you suggest decreasing the caster to stop the rear unloading, can you explain as I think my understanding of caster change might be wrong. I thought that increasing (more spacers in front of upper wishbone would decrease turn-in & increase centre & out of corner steering) am I wrong the reason Iím asking the question is that Iím running maximum caster on my X-ray and having the same problem with the back end feeling very loose. Don't whant to make the same mistake with the MTX2
Thanks in advance
Raw40.
Running maximum castor on the MTX (4mm) would give you more top speed steering. I think thats where Nova racer was getting at
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 06-22-2002, 02:52 AM   #2150
nova racer's Avatar
Thanks in advance
Raw40.
ok think of it this way incerasing negative caster transfers more weight to the front wheels also it you look at your car with a lot of neg caster turn the wheels all the way to the left you will notice that the chassie of the car is being pitched slightly. by the camber changenow put all the clips in the rear and look at it now the chassie should be flatter than with a lot on neg caster. now that pitch from a lot of neg caster puts extra weight on the outside front and takes weight fron the inside rear causing the inside wheel to spin in a turn ( unloading the diff). when you have that happen then you loose forward power in the rear because the outside tire sends all it's power to the inside tire. thats just the way a diff works. now you can decrease or tune the amount of diff unloading by using silicone diff oil. but the heaver the diff oil in the front the less steering that you have. but you can get a little more steering if you go a little heaver in the rear. Also i got this tip from a friend of a friend Josh Cyrul he really helped me under stand the caster thing and why is caused the inside rear tire to unload or diff out
nova racer is offline   Reply With Quote
Old 06-22-2002, 04:31 AM   #2151
Cool Re: caster change
Nova racer/ novarossi thanks for the advice, can you help Iíve just built the diffs for my sons MTX both seem to be smooth but very tight is this normal for a gear diff, will they free-up with use?.
Raw40 is offline   Reply With Quote
Old 06-22-2002, 04:41 AM   #2152
Michael_T's Avatar
Default Re: Re: caster change
30k will feel tight, which is what you want. Fill the oil up to where the cross bars meet only. As long as you don't feel the diff's binding, there ok.
Old 06-22-2002, 08:00 AM   #2153
Default diffs
In my experiance with the Mugen MBX (offroad but same diff gears) if u leave out the little orings on the gears, the diff will feel alot smoother, but u must shim the diff corretly & fill the diff up all the way to the top. Give it a go it works me in my MTX-2
lineburner is offline   Reply With Quote
Old 06-22-2002, 12:23 PM   #2154
Default Re: diffs
Thanks both for the advice on the diffs. my next problem have just finished building drive line, the rear & centre drive belts seem to be tensioned ok but the front is very loose in fact it's touching the chassis on it's lower section has anybody had the same problem.
Old 06-22-2002, 12:38 PM   #2155
Send a message via ICQ to Cartman
Default belt
its normal get a Kawahara front belt tensior fron Ted Longshaws there spot on and extend belt life too.
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-22-2002, 12:53 PM   #2156
Talking
Thanks cartman, I'll try and book into the national at Mendip as you suggested see you there
Old 06-23-2002, 11:08 AM   #2157
glo plug
Hi everyone, the saga continues started the motor for the first time today left at idle, ran fine for about three minutes at idle and then cut out. Started straight away but as soon as I removed the glo starter it cut out. Removed the plug to check it on the glow starter it's fine., put it back in the motor same problem, put a different plug in motor runs fine. Can someone explian whats up with the brand new plug?.
second part of my question, plug N0's ie 1-10 should I read higher the No hotter the plug or the other way around, and when should I use Hotter /colder plug?
Old 06-23-2002, 11:56 AM   #2158
When you break in an engine, you usually go through 3-4 plugs because the plugs foul easily due to how rich the engine has to be run. The engine dying when the ignitor is removed is a classic sign of a fouled plug.
As for the plug numbers, usually the lower the number, the hotter the plug. I know that OS, McCoy, and Novarossi based plugs are like this. Typically, if you run higher nitro %, you should use a cooler plug. HOWEVER, everything is relative to an engine's performance. Humidity, ambient temp, elevation, fuel %, etc all play an important part in performance. I would suggest running the same # plug that came with the engine until you get it tuned. Once it's broken in and tuned, evaluate performance, then make a decision whether to change the plug. If you're running 20%, you should be fine with the same # plug that came with the engine. I would only change it if you're running 10% or 30%.
tekrsq is offline   Reply With Quote
Old 06-23-2002, 12:02 PM   #2159
Ah10's Avatar
You've got PM
Old 06-23-2002, 01:08 PM   #2160
Originally posted by Ah10
You've got PM
Got it, THANKS. I sent a reply.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
