Old 06-19-2002, 03:53 AM   #2101
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Sydewynder
That's just wrong.
who's wrong?
Manticore is offline   Reply With Quote
Old 06-19-2002, 04:05 AM   #2102
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
This is like a family reunion - Moon-Fokky.
What have you guys been up to?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 06-19-2002, 04:24 AM   #2103
Manticore's Avatar
Have been busying to wash away the rust !
how's your 1/8 going?
Old 06-19-2002, 06:41 AM   #2104
Michael_T's Avatar
1/8th is not going at the moment - no cash
Old 06-19-2002, 11:23 AM   #2105
Originally posted by psycho
mugen21
To explain it simply, when you reduce the diff action, you reduce steering. You also reduce the amount of unloading the diff does, so you have to play around with it to find the right balance. I would suggest you stick with the stock setup of 30K up front and 10K rear with rubber tires. That should give you a good balance of steering and reduce the diff unloading. You can use tires, different springrates, shock positions and caster to change the steering characteristics. Once you get comfortable with the setup of the car and what changes cause which effects, then try changing the diff oils. The stock setup is very good with rubber tires. You should have a very competitive car if you use the stock setup and only change the shock positions to balance out traction. The Take-Off CS27 is a good tire, but you may want to have a harder compound available for the front in case you have too much steering. Good luck!
hi Psycho, when you mention "diff Unloading" what does this mean?
Raw40 is offline   Reply With Quote
Old 06-20-2002, 06:09 AM   #2106
Post
Ok here we go, my son's new MTX-2 arrived this morning.
here come the questions:-
1. The kit has turned up with the RS12S1 motor instead of the MT12 any worries??
2. Novarossi motor instruction specify the use of oil on the foam air filter, is this right?, what oil?.
3. picked up on some advice in RC Racer mag about drilling 2x1mm holes in front shock pistons & 3x1mm holes in rear is it a good idea?
Any other advice on Mods/tips we should be carrying out during build would be greatly appreciated
Old 06-20-2002, 03:22 PM   #2107
Send a message via ICQ to Cartman
Default drilling pistons and set up
Hi there i am in the uk mugen team and we all drill the pistons as Lee said in the article.the rs engine is Ok make sure its not a turbo as far as i know they come none turbo, are you doing foam or rubber? contact me for any help or check out here
http://www.rcracechat.co.uk/
i will mail you set up sheet if you need!!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-20-2002, 03:28 PM   #2108
who's wrong?
I was on your side when I said that. Basically I meant that Novarossi was being mean about the rust........but if the truth hurts.....
Sydewynder is offline   Reply With Quote
Old 06-20-2002, 03:30 PM   #2109
Mikey
I thought you graduated to a different class and left us behind?
Old 06-20-2002, 03:32 PM   #2110
Want to buy my MRX3?
Old 06-20-2002, 03:39 PM   #2111
hi Psycho, when you mention "diff unloading" what does this mean?
I'm not psycho but here's my interpretation of diff unloading.
With open or gear diffs w/no or light oil in the diff case, the wheel that has the least traction gets the most power. If for instance, the front right wheel lifts off the ground (no traction) during a right turn, that wheel will get power and the outside (left in this case) wheel that's on the ground will get no power.
You'll also here the term "diffing out".
Old 06-20-2002, 05:25 PM   #2112
Team_Akina_1's Avatar
Send a message via AIM to Team_Akina_1
I just got a mugen one way for my mtx, do you guss think it is good with some rubber tires? Maybe hpi x patterns....
Team_Akina_1 is offline   Reply With Quote
Old 06-20-2002, 05:52 PM   #2113
psycho's Avatar
Thanx Sydewynder, that's a better explaination than I would have given!
Team_Akina_1
There's no reason you can't run a one-way with rubber tires. I wouldn't use HPI X-pattern tires, though. Try Pit-Shimizu or TakeOff 24's or 27's. If you install the one-way, you'll need to back your brake off quite a bit and remember that you lose steering when you let off the throttle. It works a lot differently than diffs and will take you some time to get used to it.
psycho is offline   Reply With Quote
Old 06-20-2002, 05:52 PM   #2114
Ah10, sydewinder, and all the others, thanks for your ideas about the leaking diff.
Ah10, what are you isung in the rear diff? that is not the stock one, isn't it? how do you like it?
Pepe is offline   Reply With Quote
Old 06-20-2002, 05:56 PM   #2115
psycho's Avatar
Raw40
The oil on the air filter is what the dirt clings to, so it is very important. Just use some oil that will wash out with soap. I usually use shock oil since I have tons. That's what Tamiya shock oil is good for! It's no good in shocks!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
