Old 06-06-2002, 05:38 AM   #1996
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: Tweak fixing
Originally posted by Pepe
Do you guys know where to get good directions on how to use the tweak station correctly??
thanks
there is little information about tweak station. but after all it is easy to use and it is all about shock/spring preload setting.
http://www.rcracenews.co.uk/articles/axistweak.html
Manticore is offline   Reply With Quote
Old 06-06-2002, 05:54 AM   #1997
Default Centax Clutch
Can someone tell me how to adjust the Centax clutch on the Pro-Spec. I just bought the car used and have no clue. How do I make it engage earlier/later?
rcpilot is offline   Reply With Quote
Old 06-06-2002, 05:58 AM   #1998
Manticore's Avatar
Default Re: Centax Clutch
there are plenty of information about centax at
www.rctek.com
the centax clutch that is serpent but the way to adjust is the same.
Old 06-06-2002, 06:10 AM   #1999
RC Nitro's Avatar
manticore:
I tried the droop, and dropped the ride height .5mm rear. Had to raise the front .5mm due to bumps in one area. Droop helped, but need more. rear is real loose. Not ready to run foams yet as I am campaining 2 cars at once. bit of work. Toe is at -2 already rear and -3 on camber. tires are feather edging on the inside track so I am getting level bite.
RC Nitro is offline   Reply With Quote
Old 06-06-2002, 06:27 AM   #2000
nova racer's Avatar
Originally posted by RC Nitro
manticore:
If your tires feather then you need to run a harder compound. That sign is that the tires are over heating and causing a loose condition from the tires natural oils rising to the tire surface. It does not sound right but trust me it is the truth. i have spent many a day fighting that until i got the tire tec tip from a SCCA trans am racer friend of mine. then if you set the camber to wear the tire in the center of the tire you will have maximum contact patch and silly grip
nova racer is offline   Reply With Quote
Old 06-06-2002, 07:17 AM   #2001
Manticore's Avatar
manticore:
looks like you have too little droop in the rear. try to release the droop screw in the rear. i.e. shock travel all the way. Your rear end loose is due to not enought droop.
Old 06-06-2002, 07:37 AM   #2002
nova racer's Avatar
too much droop in the rear will cause the rear to be loose upon deceleration or corner entry. because too much weight is transfered to the front tires.
Old 06-06-2002, 07:40 AM   #2003
Manticore's Avatar
Oh I see, so what is the best setting for a low traction and bumpy parking lot ? I am waiting to see insight from you, my friend !
Old 06-06-2002, 07:59 AM   #2004
nova racer's Avatar
well start with 50wt shock oil and if the car seems to bounce on the bumpy section of the track then go lighter. If the car seems slugish and doesent respond well go higher. As for droop use is to keep weight transfer in check. If your car seems to push during breaking then increase rear droop, If it is loose during breaking decreasr rear droop. If the car is loose on accleration increase front droop, if the car pushes during accleration decrease front droop. Now this is for fine tuning not to say that it replaces shock oil and spring or angle settings. now if you notice that while your cars suspention droops so far that the springs do not touch the adjustment collar then that is of no use the droop should never droop that far because it will cause the car to be harder to turn consistant laps
Old 06-06-2002, 08:01 AM   #2005
Manticore's Avatar
I hear you NovaRacer ...................
Old 06-06-2002, 08:16 AM   #2006
nova racer's Avatar
kool
Old 06-06-2002, 08:36 AM   #2007
Manticore's Avatar
NovaRacer,
My question repeated above.
However, I find a better answer to my question here
Old 06-06-2002, 02:41 PM   #2008
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
New to MTX-2
Dear All,
I've just purchased a MTX-2 Sport Package, which comes with RS12 T--bought at Elite Hobby Shop for $520. This is my second car next to the HPI RS4 RTR3. I know I've learned the hard way by spending a lot of money on hop ups for that car and in turn did not yield a good results. It just was built for handling at fast speed! Anyway, I'll be posting questions concurrently with the time I'm building my MTX-2, should I ever have some difficulties. Hope it'll be a fun experience. By the way, I've found this site from the link in HPI forum. Tomek From: Tierra Verde, FL told about it.
Regards,
eddie
eddiethefish is offline   Reply With Quote
Old 06-06-2002, 03:22 PM   #2009
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: New to MTX-2
Originally posted by eddiethefish
Dear All,
Regards,
eddie
I have a MTX-2 too! and I run my mugen at Crystal Park Raceway! may be if you need help come out there I might be able to help!
Oh I have posted some images of my ride on previous page just scroll down a bit!
Ah10 is offline   Reply With Quote
Old 06-06-2002, 03:49 PM   #2010
Smile
Dear Ah10,
Being at Crystal Park is the reason why I bought this MTX-2. I was the only one there with HPI RS4 RTR3. Even with 2-Speed, the car was very slow compare to others who had OB4, MTX-2, Impulse. Once I finish assemble my car, I'll be there. Thank you in advance. I surely will learn a lot from you.
Best regards,
eddie
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
