Old 06-04-2002, 12:47 AM   #1966
Trader Rating: 22 (100%+)
Default droop ?
So on the droop are you saying I should just screw the setscrews out and let the shocks act as a travel limiter? It kinda sucks, they only set up the track every other week so I have to wait two weeks to try it. Thanks for the tips.
mugen21 is offline   Reply With Quote
Old 06-04-2002, 01:18 AM   #1967
FREAKAH's Avatar
No.
Let me put it this way. At ride height, screw the droop screws down until they just touch the chassis. That way the arms/tires should'nt drop down when you lift the chassis up with your finger.
I think it's 5mm droop when set with a droop gauge like Yokomo's an AE's(I dont have either).
FREAKAH is offline   Reply With Quote
Old 06-04-2002, 01:54 AM   #1968
bhleric's Avatar
mugen21:
try increase the chamber to 3deg ~ 3.5deg
decrease you toe. i used 2deg for toe. best in turning in and exit from cornering.
these are the 1st level setting up (or basic set up adjustment).
when you are happy with the 1st level setup, then only go on the secondary setup adjustment to fine tune the car setup to suit your drive style.
bhleric is offline   Reply With Quote
Old 06-04-2002, 01:58 AM   #1969
FREAKAH's Avatar
Wow!! That seems like too much camber for a rubber set-up(even for a foam set-up).
Old 06-04-2002, 02:16 AM   #1970
bhleric's Avatar
supplement to previous post.
: 1.5deg chamber to fr
: 3~3.5deg chamber to rear. (not all 4 tyres, sorry lah)
toe out 1d Fr
toe in 2d Rear
Ride height 4mm Fr, 5mm Rear
1.7 Red colour serpent spring Fr & Rear
front shock pos: 2 holes from bottom
Rear shock pos: 2 holes from bottom
Rubber tyre used.
i think that's what i can think of, in the office right now, can access to my setup sheet.
Old 06-04-2002, 06:22 AM   #1971
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: setup ?
Originally posted by mugen21
New to onroad and to the board, I went through and read the entire forum and gained alot of useful info and then forgot it by time I got done reading everything. Anyways I raced my MTX2 for the first time last weekend and I need some setup help. I run at a parking lot race on rubber tires and the car has some problems. I played with tires most of the day and got it where it felt ok, but I know it needs some attention to the overall setup. Here is where I have it now.
Front
Camber -1.5
toe out 1degree
shock oil 600 stock pistons
2nd hole from top
blue springs
ride height 5mm
caster big shim towards rear
downstop 4mm
diff 50,000
Rear
Camber 1.5
toe in 4 degrees
shock oil 600
top hole on tower
tried blue springs, purple springs and assc. green springs (real soft)
ride height 6mm
downstop 8mm (I think)
diff 30,000
the problem I am having is the car is real loose in the back, even on a real tight turn If I am going real slow it will try to swing the rear around. I know the car is off a little I need to get a Hudy because it has more oversteer to the right then it does to the left. I just wanted to know If anyone has a rubber tire setup that will keep the rear from trying to sway ends. Some of the setup is from another guy I race with and I went with his reccomendations as far as the diffs go, I race 1/8 scale offroad and one way I can get rid of a loose rear is drop down the oil in the rear diff or even put a light grease in it. I was curious If I went to 10,000 or even 5k or 3k in the rear If that would help. Like I said I am new to onroad and I am pretty lost when It comes to the suspension. On a good note I did qualify 4th and had 3rd locked up in the main till the front upright (the same one I cracked earlier in the day) popped out of the pivot balls after a slight brush with the boards.... ok maybe it wasn't a slight brush. Sorry for such a long post I really had fun with the car and just want to try and get it setup a little better before I run again. TIA Michael.
What tyres do most guys run on the track, and try them. It could be just you need to drop down to softer tyres in the rear. Also 4 degree toe is too much - this indicates that you need a softer rear setup. There is a fine line when toe works and too much toe doesn't resulting in slip. Is the 1.5degree camber measured on a setup board (eg Hudy - elevated camber) or is it driving camber? If it is 1.5 elevated, add another degree or two - keep adding camber until your rear tyre wear is even or slightly conned inside.
If all this fails, true a stiffer front spring or harder front tyres, it could be your front end having too much grip and swinging the backend around.
Keep the diff's as your last resort, I run One-way front and 50k rear on all tracks and it handles well.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 06-04-2002, 07:27 AM   #1972
Default rear turnbuckle
Hey guys, does someone remember how long are the rear turnbuckles? I want to order from lunsford but I don't remember the size.
HELP please!!!
Pepe is offline   Reply With Quote
Old 06-04-2002, 07:34 AM   #1973
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: rear turnbuckle
HELP please!!!
the lunsford turnbuckles are 15mm and I need to cut down one side of the ball cap to make the camber link shorter.
Manticore is offline   Reply With Quote
Old 06-04-2002, 09:27 AM   #1974
Hey Manticore,
If they are the same exact size, why do we need to cut the ball cup?
Thanks!!
Old 06-04-2002, 10:16 AM   #1975
dtm
dtm's Avatar
Send a message via ICQ to dtm
Hey Manticore,
Thanks!!
The adjusting 'square' on the lunsford is longer than the gap that you want between the ball cups...so you have to cut the ball cups to achieve the correct total length.
dtm is offline   Reply With Quote
Old 06-04-2002, 11:02 AM   #1976
Thank you guys
Old 06-04-2002, 11:02 AM   #1977
Manticore's Avatar
I use the camber link position as followings:
shock tower: inner/lower
hub side: inner/upper
the 15mm together with the shorter link required to cut down one of the ball cap.
dtm is right in the way.
p.s. I run on foam tire.
Old 06-04-2002, 02:13 PM   #1978
Did you try using the outer holes in both sides? What is the effect in doing so?
Old 06-04-2002, 04:07 PM   #1979
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
if you use outer holes in both sides, then you will make the camber link length as close as lower A-arm! if that's the case your camber angle will change less then if you were to use inner holes when springs are compressed
Ah10 is offline   Reply With Quote
Old 06-04-2002, 05:41 PM   #1980
Default Tires
Novarossi,
I tried different tires that others reccomended and they all felt the same. I was running takeoff 27's all the way around and then I went Treadz 26mm rear's that were actually harder then the fronts and it felt about the same. I bought some real soft Sorex tires for the rear that I never got around to trying. So with the car sitting on the table I should have about 3 degrees of camber? Thanks for the tips I am going to change it up and take it up to a parking lot and make my own track out of some cones and see how it does.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
