Mugen MTX-2
#1921
Hey guys check out my MUGEN MTX-2 on a BMW M5 body with a Novarossi JP MOD engine
#1922
set up
my set up is
1.5 camber
1 small caster spacer at front
1.5 toe out
blue spring
60 wt oil with 3 1mm holes in piston
2nd hole up in front mount
200m wide
anti roll on softest
+1mm droop
super grease in front diff
rear
2 toe in each side
1.5 camber
purple springs
60 wt oil
4 1mm holes in the piston
2nd hole up on mount
200mm wide
rear roll bar soft
+6mm droop
5000 diff oil
I have understeer on power fine on inital turn in but it could be sharper. I did have the off power oversteer but got rid of that with the droop alterations. Will the shocks make THAT much differance? i still suspect my diff to be too stiff. i will try the shocks though.
1.5 camber
1.5 toe out
blue spring
200m wide
+1mm droop
rear
2 toe in each side
1.5 camber
purple springs
60 wt oil
200mm wide
rear roll bar soft
+6mm droop
5000 diff oil
#1923
Mark
Here is my setup
Front:
track width 199mm
ride height 4.5mm
camber -1.5 deg
caster 2mm
toe +1
steering throw 18 deg
droop 4mm
sway flat 0 deg
shocks: 1 hole, 600 wt, lt blue, 4.8mm preload
Rear:
track width 199mm
ride height 5.0 mm
camber -3 deg
toe +2 deg
droop 9mm
anti roll 2mm bar
Shocks: 2hole, 600 wt, lt blue, 2.8mm preload
Tires Treadz 3B Medium with medium insert
Rollout is 27.0 1st and 37.1 2nd
Stratus body protoform wing neutral
off power oversteer. Going to grey springs next then less droop.
Here is my setup
Front:
track width 199mm
ride height 4.5mm
camber -1.5 deg
caster 2mm
toe +1
droop 4mm
sway flat 0 deg
Rear:
track width 199mm
ride height 5.0 mm
camber -3 deg
toe +2 deg
droop 9mm
anti roll 2mm bar
#1924
please help with setup
hello everyone...i have a first generation MTX-2, and i was wondering if i could get some help in setting up the car...
the stock settings made the car "floaty" and unstable at high speed...i do not run foam tires...there is NO one way, nor a negative diff...the car is pretty stock, except for a large bumper and belt tensioner...
i would greatly appreciate any setup settings, to get me started in tuning this car...also, what kind of non-foam tires/inserts are you folks using?
also, is there a website (or a post) that lists exactly what kind of changes will be made in the handling when a suspension change is made to the car (e.g. making the rear camber rod long and parallel to the suspension arm will result in more rear traction, etc.)...
and what brand bodies are people using...the HPI bodies are the mos available in my area, but i notice that the rear wheel wells do not line up correctly...
THANX in advance!
THANX in advance!
#1925
Dude, my setup is listed above. Kit is a prospec with the 1 way removed. Stock droop rear is 8mm. Ride height is 4mm front, 6mm rear. I do not have the online site that has info, but a good book is @ m-powered reacing. Martin Crisp did a good job on this. He is responding to a thread on the electric forum, "faster corner like a pro". Guessing on what you have is a bit tuff. Post y our setup and then someone here can help.
Tires I listed are rubber. Treadz are preglued with inserts. Tires are a medium compound with med/firm insert on a dish rim. I h ave also run medal pros hards, suck! and sorex 32 with HPI green (firm) insert on proline gumby rims.
Bodies: I am running protoform and I have seen HPI. The rear wells do not line up. Cut prior to painting to get them close is what I do.
#1926
Re: Re: ride height
Originally posted by SioKoy
8. Install your shocks. Set the tension of the springs to the normal tension.... Setting up springs with pressure will cause no good dumping!
Thanks!
#1928
Originally posted by rcfiend
Anyone looking for a backup car. I have an MTX with an assortment of hopups, no motor, $125.00. Let me know if you're interested.
You have any good quality pictures??
#1930
I don't have any pictures yet, I can get some to you in a couple of days. The car is less than 6 months old, I just switched to the Nitro TC3.
#1932
Re: Re: Re: ride height
Originally posted by Pepe
Hey Siokoy, what would be a normanl tension for the shocks?
Thanks!
Thanks!
#1933
Re: Re: Re: Re: ride height
Put your car on a block or on a car stand Suspension arms should be at rest without any load then adjust your tensioner until it reaches the springs. Then check your car on a flat ground... or on a setup board then test the dumping. After testing try tweaking your car you'll see the difference its almost balanced in all four suspension.
#1934
Originally posted by Novarossi
Incase you guys missed it, new Centax clutch from Kawahara for MTX/V1R...
Looks good.
All I can see different is the one piece flyweights which arn't freely mounted (like the 4 piece Mugen units) and the metal flyweight holder.
Looks good.
it comes with low CG engine mount and trust bearing. i.e. all you need to built the clutch.
the flywheel is very small and light weight.
it is amazing...............
It has MTX2, V1RR version available.
#1935
Originally posted by Manticore
the clutch arrived here yesterday. very limited supply.
I declined the offer since my GPs are in semi-retirement!! Last night I took the 2143 servo off the RR to put onto the EvoII....... theres no 'easy' going back now!!!!!!
