Old 05-24-2002, 02:42 PM   #1906
Default Re: HELLLLLLLLLp screws
Originally posted by warlord385
debbies rc doesn't have them. Their parts page is blank. Does anyone else know where to get these particulary hard to find parts online. 2.6x16mm screws and the 2.0x9.8 pins
thanks anyway rc nitro
The pins come in part # T0802. Have you tried Speedline, NitroHouse, or Ace Hardware Hobbies? I can usually find anything I need at one of the 3. As for the 2.6mm screws, forget it. I've called Mugen directly and asked for them and was told "we don't sell them seperately". After MUCH looking & measuring, I found some 2.8x 14 mm screws at a hardware store (by accident too) about 20 miles from me. They fit, but were VERY tight. Good Luck!!!!!!!!!!!!!!!
www.speedline-rc.com
www.nitrohouse.com
www.ace-hobbies.com
You have to call these guys. MANY parts are not listed on the sites.
tekrsq is offline   Reply With Quote
Old 05-24-2002, 02:56 PM   #1907
RAP66's Avatar
You might try MR METRIC in San Jose... they might have the screws you're looking for.
Rich
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 05-25-2002, 03:30 AM   #1908
warlord385's Avatar
Default ride height
does anyone know how to adjust ride height on the mugen mtx-2
warlord385 is offline   Reply With Quote
Old 05-25-2002, 04:52 AM   #1909
RAP66's Avatar
Default Re: ride height
Adjust the collars on the shocks to adjust ride height.
use the upstops and down stops to adjust the limits of suspension travel..... (I dont use them, some peeps do)
Rich
Rich Pedro
[email protected]
www.rcracing.com
Old 05-25-2002, 03:51 PM   #1910
Send a message via ICQ to Cartman
Default Rear Neg diff and Push (Please give opinion)
Ok got a neg diff in the rear and super grease in the front diff i am on rubber tyres i noticed i am getting more push but seem to be generating more rear grip from the Diff. the tyres seem to work better, so to get rid of push what should i do? lossen the front diff 50 or 30 wieght or put the standard back in the rear? i have 600 oil all round and blue front spring purp rear front anti roll soft and rear connected??
Whats your thoughts??
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 05-26-2002, 10:04 AM   #1911
RAP66's Avatar
Default Re: Re: HELLLLLLLLLp screws
hehee one more link!
www.microfasteners.com
Rich Pedro
[email protected]
www.rcracing.com
Old 05-26-2002, 10:52 AM   #1912
SioKoy's Avatar
Send a message via ICQ to SioKoy Send a message via Yahoo to SioKoy
Default Re: Rear Neg diff and Push (Please give opinion)
Hmmm push!!! that means your understeer.... try to position your front shocks to the highest or should i say the first hole on top! to get more front grip
SioKoy is offline   Reply With Quote
Old 05-26-2002, 02:48 PM   #1913
Default Diff
thanks SioKoy
Tried that but not alot off diferance. i thought you lot called understeer push!!
What dff set ups do you all use on rubber tyres. just wondering if my front diff is too tight the TC3 nitro lads run loose set ups here and they turn alot better than me!!
Other thing i might try is less rear toe in got 2.5mm at moment but by go to 1.5!!
Old 05-28-2002, 04:18 AM   #1914
RC Nitro's Avatar
Mark
I run 10,000 in the front diff versus the 30,000 stock and silicone in the negitive diff. Removed the 1 way, prospec kit. Right at the moment I have oversteer or loose. Back loves to visit the front on off power conditions I am running rubber tires (tyres ) Treadz3B . I will post my setup if you want.
RC Nitro is offline   Reply With Quote
Old 05-28-2002, 05:38 AM   #1915
Default RE SET UP
Yep post set up please and i will do the same
Old 05-28-2002, 08:28 AM   #1916
aftalavera's Avatar
Default Rubber Tyres Setup
Saludos,
Im having a serious oversteer problem with rubber tires.
Can anybody share their rubber tires setup?
aftalavera is offline   Reply With Quote
Old 05-28-2002, 08:46 AM   #1917
Default set up
will do whats your set up and i will post mine when i am home i have understeer and need more steering !!
Old 05-28-2002, 10:47 AM   #1918
SioKoy's Avatar
Default Re: Diff
thanks SioKoy
Ok have you tried positioning your rear shocks to the lowest hole? Try Front Shocks at the top of the hole and the rear shocks to the lowest.... Positioning your Rear shocks to the lowest hole will cause less traction so i guess you'll loose that understeer push!
Old 05-28-2002, 10:51 AM   #1919
SioKoy's Avatar
Default Re: Rubber Tyres Setup
Originally posted by aftalavera
Saludos,
I used to have the same problem. MTX-2 has this problem oversteer!
To remove oversteer.... Use front diff oil at 100T in weight then position your front shocks to the lowest hole then the front droop should be +2 and the rear +6. Rear diff use 7T in weight and position your rear shocks to the mid whole or until there's no oversteer
Old 05-28-2002, 11:08 AM   #1920
SioKoy's Avatar
The best way to setup your ride height is adjust your droop!
Use Hudy droop gauge then setup your droop to +2 in front and +6 at the rear. Shock positioning should not affect the ride height bec. it tends to pressure the springs which is not a good one.
To setup your droop:
1. Remove the shocks and your stabilizers
2. Suspension arms should be free from binding
3. Put your car at the Setup block or HUDY block or Droop Block
4. Check your chasis if there's a sway movement (If there is that means you need to replace the chasis and it means your chasis has a bent portion
5. Adjust your droop using droop gauge.
6. Set your front droop to +2 and the Rear +6
7. Install the stabilizers then check your droop again (It should be +2 front and +6 rear. If there's any changes in your droop adjust the stabilizer bars until it reaches the desired droop)
8. Install your shocks. Set the tension of the springs to the normal tension.... Setting up springs with pressure will cause no good dumping!
9. Check your droop again! it still should be the same setup +2 Front and +6 at the rear.
I hope this will help and once you've done it the right way you'll find your car with the best movement. More power on turnings and it will loose oversteer or understeer.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
