Old 05-06-2002, 08:32 AM   #1831
RC Nitro's Avatar
Default Re: Re: spring referance chart
Originally posted by Pepe
Hey Cartman, good job!
what do the L and P mean??
thanks!
Linear & Progressive
RC Nitro is offline   Reply With Quote
Old 05-06-2002, 02:08 PM   #1832
Default RE: spring rate chart
Cartman, what's the second set of numbers mean?
tekrsq is offline   Reply With Quote
Old 05-06-2002, 02:36 PM   #1833
Send a message via ICQ to Cartman
Default Spring Chart
To be perfectly Honest...........I dont know got them from a friend I will try to find out
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 05-07-2002, 10:51 AM   #1834
raffaelli's Avatar
the second number is gf/mm. the l and p is linear or progressive. speedline has a similar spring rate chart.
raffaelli is offline   Reply With Quote
Old 05-07-2002, 01:44 PM   #1835
aftalavera's Avatar
Default What about mugen springs?
Hi there,
What about pound rating for the mugen or serpent springs? Does anybody have that info? Does anybody have the equipment to measure it?
aftalavera is offline   Reply With Quote
Old 05-07-2002, 02:02 PM   #1836
Default Mounting 26 mm tires
Hi all!!
Could someone please tell me waht I shuol exactly do in order to mount 26 mm tires in the front? I know that I have to put a 1mm shim, but I don't know how to do it. when I tried, There was a huge play in the entire dogbone which i don't think should be.
Picture will be greatly appreciated.
Later
Pepe is offline   Reply With Quote
Old 05-07-2002, 03:36 PM   #1837
Tomek's Avatar
Send a message via Yahoo to Tomek
I put 1 mm plastic spacer between outside bearing of front upright and the pin that goes through the axle shaft and holds the wheel hub. It is a thight fit but works nicely.
Tomek is offline   Reply With Quote
Old 05-08-2002, 07:17 AM   #1838
thank you Tomek, I will give it a try again.
Old 05-08-2002, 06:37 PM   #1839
stefan's Avatar
Send a message via AIM to stefan
Default Kawahara 2-speed
can somebody please enligthen me how to adjust the shiftpoint on the Kawahara 2 speed?
I got it together but I'm not quite sure which adjustment does what.
What are the set screws with the balls doing?
What are the screws with the springs doing?
Why can't I reach the screws with the springs though the clutch bell?
Many questions, but I never had an 1/8th scale with a similar tranny, so I'm a bit confused.
]Thanks
stefan is offline   Reply With Quote
Old 05-08-2002, 06:48 PM   #1840
What's gf/mm?
Old 05-08-2002, 08:06 PM   #1841
RC Nitro's Avatar
aftalavera: You could use an automotive spring compressor to measure this. All you need to know on springs is the diameter of the coils, the height of the spring and the pressure on the spring just before max bind point.
Here are the Mugan springs listed on Jason's site.
http://www.jasonjenkins.com/mtx2/charts/spring.htm]Janson Jenkins springs[/URL]
Here are the Serpent/X-Ray springs. rate is LB/in
Orange - 15 pounds
White - 20 pounds
Yellow - 25 pounds
Red - 30 pounds
Pepe _Tomek: that what the Prospec does. 1mm washer between housing and pin hole.
Tekrsq: g gram f force mm milimeter
gram force per milimeter. Remember Mugan uses metric (SI)measurements not english.
Old 05-08-2002, 08:23 PM   #1842
RC Nitro's Avatar
Default Re: Kawahara 2-speed
I will try. They are actually straight forward once you see how it works. Instrcutions leave a lot to be desired. Need better translations!
This is the adjustment. This is where you set the engage point.
Preload of the assembly
You can, you just have to rotate the bell till you do. These are at an angle.
Stefan
Here is the info I posted a while back works good. It is ~ 1/3 way down pg 54 This setup works for me and 2 others localy.
Tip paint these screws a different color so that when you look through the hole in the flywheel you know which one to adjust.
The end screws with the springs (labeled 2.6mm)run them down till they touch and then back them out 3.5 turns. The center screws with the balls(4x4mm) run down till they touch. Now with this all installed in the flywheel, adjust the 4x4 ones till the just rub and then backoff 1/4 turn. This should work for you
kawahara 2 speed
Old 05-08-2002, 08:39 PM   #1843
Manticore's Avatar
R/C Tech Charter Subscriber
]Thanks
READ HERE FOR THE ANSWER
Manticore is offline   Reply With Quote
Old 05-08-2002, 09:43 PM   #1844
stefan's Avatar
Default Thanks guys, got it.
Jason,
check your PM
Old 05-09-2002, 07:56 AM   #1845
aftalavera's Avatar
Hi there,
RC:Nitro Thanks a lot my friend....
PS. We are having a rough time competing with those NTC3
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
