Old 05-03-2002, 11:33 AM   #1816
RC Nitro's Avatar
Originally posted by TheBarber
i think the 2 speed was assembled wrong, because i can find the screw to adjust the clutch. i think the car is starting off in 2nd, cuz it is pretty sluggish off the line and it doesn't shift. im an electric guy so bear with me. i really want to learn as much as possible about this car, but i'm getting frustrated. thank you in advance for your help, that is if you can help.
The Barber: Nothing wrong with being an electric dude You may have to pull the 2 speed apart to check the setting. I am at work and will try this from memory. There are 2 screws in the 2 speed. One locks the unit to the shaft, goes straight in. The other is at an angle. You adjust the shift point with the angled one. On my HPI it is 3.5 turns out from fully down. You adjust the one with the spring and ball. What you are doing is adjusting the tension on the finger to control the shift point. Run the screw down for later shift and up for earlier.
RC Nitro is offline   Reply With Quote
Old 05-03-2002, 12:13 PM   #1817
TheBarber's Avatar
Send a message via AIM to TheBarber
thanx rc nitro i will take a look at that tonight when i get home. i'll let you know what i find. do recommend going to the kawahara 2 speed or is the stock one good enough. also what clutch do you recommend. thanx again for your help. this car is way too cool to give up.
TheBarber is offline   Reply With Quote
Old 05-03-2002, 01:55 PM   #1818
Default Mt-12 carbureator set up
Hey Barber, welcome aboard!!
You can find some useful tips in Ron Paris' web page, why don't you give it a look.
http://www.parisracing.com/NovaRossicarb.htm
Regarding to hte 2 speed, I have the standard one (no centax, no kawahara) for more than a year and I found it great.
Good luck
Pepe is offline   Reply With Quote
Old 05-03-2002, 07:31 PM   #1819
RC Nitro's Avatar
Your welcome. I just read the instructions. Not real helpful. I enclosed a HPI shot of the 2 speed. They are the same finger type. Do put loctite on the screws as nitro's have a tendancy to vibrate them loose The stock 2 speed is good to learn on. The Kawahara is a 2 shoe like on the 1/8 scale cars. I have a Vector and that is what they use. Great action and smooth. Cost is a bit steep at ~$80 for the kawahara model. On the clutch I prefer cyntax. Again I have this on the Vector and they work better IMO. My car is a Prospec and came with the cyntax. I would invest in that first before I got the other 2 speed. Here is an article on cyntax clutches that is done real well. Good site. Manticore posted this ~ month back. Centax clutch
Here is one on the 2 shoe 2 speed. 2 shoe 2 speed
I agree on the cool! Love the car.
Old 05-03-2002, 08:19 PM   #1820
Default clutch springs
what is the difference between the stock clutch springs anf the 1.1 mm clutch springs. any help would be appreciated...thanx
hOpUpHoLiC is offline   Reply With Quote
Old 05-04-2002, 04:31 AM   #1821
Send a message via ICQ to Cartman
Default spring referance chart
Thought this might help some of you
Soft 12 214 Green Associated
12 214 Orange HPI (L)
12.6 216 Silver Lossi
12.7 221 Yellow HPI (L)
13.3 236 Red HPI (L)
13.8 244 Green HPI (L)
14 251 Blue HPI (L)
14.5 260 Silver Associated
14.6 261 Blue Lossi
14.7 268 Pink HPI (L)
Medium 15 269 Blue Schumacher
15 269 Orange Corally
15.2 272 Green HPI (L)
16.7 298 White HPI (P)
17 304 Blue Associated
19.5 350 Gold Associated
19.6 351 Yellow HPI (P)
20 358 Purple Lossi
20 358 Red Schumacher
20 358 White Corally
22 394 Red Associated
22.1 395 Red HPI (P)
Hard 25 448 Copper Associated
25 448 Yellow Schumacher
25 448 Black Lossi
27 483 Black HPI (P)
29.9 535 Red HPI Procede
30 537 Purple Associated
32.2 577 Green HPI (P)
32.9 588 Black HPI Procede
34.2 612 Blue HPI (P)
V Hard 35 626 Yellow Associated
37.4 670 Purple HPI (P)
37.5 672 Blue HPI Procede
40 718 White Associated
Rating = lb/inch
Conversion factor gf/mm - lb/inch = 17.9
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 05-04-2002, 08:14 AM   #1822
Default cluth springs
harder springs that will make the clutch engage later
Old 05-05-2002, 01:59 AM   #1823
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: clutch springs
The 1.1mm springs will make the clutch engage later, giving it more punch off the mark and out of corners. Good luck if you ever want to take them off
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-05-2002, 04:28 AM   #1824
Default Re: spring referance chart
14 251 Blue HPI (L)
14.6 261 Blue Lossi
20 358 Purple Lossi
25 448 Black Lossi
Rating = lb/inch
What's the second number stand for? The 448,535, etc.
tekrsq is offline   Reply With Quote
Old 05-05-2002, 02:00 PM   #1825
so those springs will helpl out acceleration but will they do anything to top end...i mostly drag race so what will be a good set-up on the clutch...also my engine has been giving me trouble lately..i accidentally launched it into some dirt and air filter flew off...it didn't seem like any dirt got inside but now about 20 tanks later the engine does not run as well...should i replace the piston and sleeve?...also what is a good engine temp to run the mt-12 at?...thanx
Old 05-05-2002, 10:09 PM   #1826
raffaelli's Avatar
So my stock two speed after three years is finally starting to be inconsistant. Is the Kawa two speed worth it? Or should I just get another finger two speed? Does the Kawa two speed need any other parts?
raffaelli is offline   Reply With Quote
Old 05-06-2002, 04:20 AM   #1827
RC Nitro's Avatar
I prefer the consisity of the 2 shoe and the smooth action vs the jerky/hard shift of the finger type. Trying to remember the parts, it is monday am you know Comes with the clutch bell, shoes, shaft and bearing. You have to transfer the gears and "C" clips. For me, it was worth the $$.
Old 05-06-2002, 05:06 AM   #1828
Chris, I agree with RC Nitro. If you've got to replace the tranny anyway, go for the clutch style. It's much better than the finger style. It comes with everything you need except the spur gears.
Old 05-06-2002, 05:21 AM   #1829
raffaelli's Avatar
OK, thanks, I will pick it up today.
Old 05-06-2002, 07:11 AM   #1830
14 251 Blue HPI (L)
14.6 261 Blue Lossi
20 358 Purple Lossi
25 448 Black Lossi
Rating = lb/inch
Hey Cartman, good job!
what do the L and P mean??
thanks!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
