Old 04-10-2002, 10:31 PM   #1696
psycho's Avatar
rcfiend
I think you will probably have better luck using a softer tire in back. Try running 37 or 35 in back. 45 should be good up front, but maybe 42 is you need extra grip upfront. You should be fine with 2 to 2.5 toe in for the rear.
psycho is offline   Reply With Quote
Old 04-11-2002, 12:10 AM   #1697
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by psycho
rcfiend
your setup should have something wrong if your tire shore has more then 5' difference. ideal setup is same shore rate front and back if your setup is good.
Manticore is offline   Reply With Quote
Old 04-11-2002, 06:32 AM   #1698
dtm
dtm's Avatar
Send a message via ICQ to dtm
haha...I'll take that as a compliment....I'm running 40s front and rear now!!!!
Have you tried the Arrows tires yet? they appear to be a different compound to the Fast and Ellegis we have been use to!
dtm is offline   Reply With Quote
Old 04-11-2002, 06:42 AM   #1699
nova racer's Avatar
This is were you get into diff tunning to dial out traction at one end of the car and get traction at the other end. what are you running in your diffs to get that close to ideal diff action.
nova racer is offline   Reply With Quote
Old 04-11-2002, 07:16 AM   #1700
Manticore's Avatar
i dont have a diff with my car !
Old 04-11-2002, 09:09 AM   #1701
dtm
dtm's Avatar
Front one-way. Solid rear axle!!!
Old 04-12-2002, 06:57 AM   #1702
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I ran Arrows for about 2 years. They seem alittle harder then the FAST and SPRINT tyres but don't chunk as easily. Arrow 45s up front used to last me months!!! - just got sick of gluing and truing...
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 04-12-2002, 07:30 PM   #1703
Manticore's Avatar
Default Derlin front arms from Kawahara
Old 04-12-2002, 07:37 PM   #1704
RC Nitro's Avatar
I see the extra reinforcing in the arm, but is there an advantage in the derlin vs the stock plastic?
RC Nitro is offline   Reply With Quote
Old 04-12-2002, 09:07 PM   #1705
Manticore's Avatar
the advantage of derlin is more robust to crash and less chance for deform. but they are expensive
Old 04-12-2002, 10:32 PM   #1706
dtm
dtm's Avatar
Sounds good!!!!!
Old 04-13-2002, 01:59 AM   #1707
Does anyone know how to rotate the high speed needle brass housing on a novarossi carb ? (the housing, not the needle)
I want to rotate it so it's alinging with the carb opening. Thanks.
yokomoracer is offline   Reply With Quote
Old 04-13-2002, 02:04 AM   #1708
hurhur's Avatar
u cant possibly do that...all u can do is to rotate the position of the carb. the alignment of the nipple on the high speed housing can be adjusted by loosening the high speed brass housing.
hurhur is offline   Reply With Quote
Old 04-13-2002, 03:24 AM   #1709
Send a message via ICQ to Cartman
Exclamation URGENT ADVISE ON NEGATIVE DIFF PLEASE
Ok What lube should i use?? will a good teflon grease work ok? some one told me use 5000 diff lube!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 04-13-2002, 08:25 AM   #1710
RC Nitro's Avatar
Mark
I use silicon grease. I got this from my LHS. Ah10 and recomended hyspin grease.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
