Old 04-10-2002, 04:06 AM   #1666
RC Nitro's Avatar
Yokomoracer: Thanks for the info. I will rebuild the diff tomorrow and try this.
RC Nitro is offline   Reply With Quote
Old 04-10-2002, 06:42 AM   #1667
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally posted by Manticore
it is due to the failure of your 2speed oneway bearing. Dont ever clean or lube it by all mean. It doesnt require any maintenance at all. If you need to lube it, dont use heavy grease but very thin liquid base lube.
This is a common problem with the 2-speed. Use some Mugen Sticky grease on the 2-speed clutch level. Many people have different opinions....
PS- HI MOON, LONG TIME NO SPEAK!
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 04-10-2002, 06:46 AM   #1668
Manticore's Avatar
R/C Tech Charter Subscriber
yep, this could be the reason too. but this wont slow down the car but just dont shift to 2nd gear. What I did to fix the lever problem is to round the sharp edge on the lever.
Where have you been champ?
Manticore is offline   Reply With Quote
Old 04-10-2002, 09:00 AM   #1669
Smile Hola!
I just wanted to say hello everyone!!
Pepe is offline   Reply With Quote
Old 04-10-2002, 09:16 AM   #1670
Manticore's Avatar
Default Re: Hola!
Hi Hi !!
Old 04-10-2002, 09:38 AM   #1671
Post Ball bearings
Does anyone know where can I get a set of GOOD (the best) ball bearings?
Thanks!!
Old 04-10-2002, 09:44 AM   #1672
stefan's Avatar
Send a message via AIM to stefan
www.bocabearings.com
stefan is offline   Reply With Quote
Old 04-10-2002, 10:08 AM   #1673
Send a message via AIM to Adios1 Send a message via Yahoo to Adios1
Default My Mugen
Hi Guys!
Thanks for all the help with the car. I learned alot from this board. Here is a picture of my MTX-2. You can't see it from this pic, but it's all Kawahara, with the exception of the front shock tower (Penguin) . It's got the 34T Overdrive Pully in the Front One Way, and the Solid Rear Diff. Anyone have a good setup? I am running Zac Project Foams 26mm fronts and 32mm rears.
Thanks!
Angel
Adios1 is offline   Reply With Quote
Old 04-10-2002, 10:14 AM   #1674
Manticore's Avatar
Default Re: Re: Re: Re: Re: Diff Oil
1/. I would use 5K rear and 10K or 7K front.
2/. front
1' toe out; 8' caster; 2' camber; 80wt shock oil and two holes piston; sway bar is around 30' from softest position; 42 shore tire; white spring
rear
2.5' toe in; 3' camber; camberlink: bulkhead-inner/lower hub-upper/outter; 55wt shock oil and two holes piston; swaybar; 40 shore tire; grey spring;
all shocks fully laydown; front one-way with rear solid axle.
droop: front very little; rear-adjust it until shock coil spring kept in place of the spring retainer.
Here !!
Old 04-10-2002, 10:17 AM   #1675
Manticore's Avatar
Default Re: My Mugen
Originally posted by Adios1
Hi Guys!
Thanks!
Angel
I am also using penguin front tower but have chopped it down and reinforeced with custom made tower bar.
Old 04-10-2002, 10:21 AM   #1676
Default Shock tower
Manticore,
Thanks for the setup. Man, that's a great idea!! Looks cool too! I will do that tonight. I guess you don't move your front shocks around much, do you?
Thanks again!
Angel
Old 04-10-2002, 10:24 AM   #1677
dtm
dtm's Avatar
Send a message via ICQ to dtm
haha....I thought the 'ears' were part of the 'look' of the car!!!
dtm is offline   Reply With Quote
Old 04-10-2002, 10:25 AM   #1678
Manticore's Avatar
Default Re: Shock tower
Manticore,
Thanks again!
Angel
only use the full lay down position in the front!
Old 04-10-2002, 10:26 AM   #1679
Manticore's Avatar
we are talking about ear the whole night !
Old 04-10-2002, 10:27 AM   #1680
dtm
dtm's Avatar
seemed an appropriate topic.......you can only talk 'so' much on cars!!!!!!!!!
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
