Mugen MTX-2
Old 03-25-2002, 08:41 PM
  #1531
Ah10's Avatar
Originally posted by VinDollar
I know powerline makes a 42 spur and mugen makes the 22 pinion.
Do you have any information on Powerline Stuff? Website? Thanks
Ah10 is offline
Old 03-26-2002, 02:31 AM
  #1532
Manticore's Avatar
Originally posted by Ah10
On the 22T pinion, I am using Racing Jack Harden pinion, they are tough and it doesnt show any wear on it! Mugen does make 22T 2nd gear pinion for Sting, part number H0717.
on the Spur side I am using Racing Jack Derlin spur too! it is white and suposingly much more durable!
Mugen does make 22T for MTX2 and it is gold color.
Manticore is offline
Old 03-26-2002, 03:41 AM
  #1533
RC Nitro's Avatar
ah1o
Thanks for the info on the 2 speed. I set the clutch as recomended last night and passed the info to my LHS. Only one other has this setup and he struggled with the setup last weekend. I hope to have the car finished and running weather permitting this weekend.
RC Nitro is offline
Old 03-26-2002, 08:56 AM
  #1534
Ah10's Avatar
Originally posted by RC Nitro
ah1o
You are very welcome
Ah10 is offline
Old 03-26-2002, 10:40 AM
  #1535
Talking
Thanks for the help Ah10, Motorman and Siokoy. I'll try the gearing and the tire setup that i've read about. Well I hear that 260 is hot too. But I'll try it out. For the nova based engines, how long will it last if you run it that hot? I know i killed a previous OS CVR when i ran it that hot. The sleeve and piston took the brunt of the damage, and after a couple runs, there was almost no compression. (When I was new .. newer, to the hobby)
Is the negative rear diff that much help with the front one way. The prospec has the one way and rear diff, which i'm using, and I'm hearing all these set up problems with it. Just a question from a poor college student, who'd rather eat...
Eat... Race... Eat... Race...
ah... questions...
ketchup_gsr is offline
Old 03-26-2002, 01:06 PM
  #1536
AH10:
Where can I buy Racing Jack Hardened pinions? How much are they? I know the mugen ones are like $16 for one and they wear out quickly. Kind of expensive for one pinion gear.
Kool is offline
Old 03-26-2002, 02:38 PM
  #1537
Default OK MAKE IT CLEAR!!
OKyou guys go on about 3 degress but on the Hudy board is the 3 each side or 1.5 each side 3 as total??
I'm picking alot of good tips up from you guys so keep the exellent info flowing!!
One last thing...........IS the Negative Diff ok for rubber tyre's?
Cartman is offline
Old 03-26-2002, 02:46 PM
  #1538
Default Re: Toe
I have 3 degrees of toe in on each side. That's each wheel on both sides are 3 degrees inward. I measured a TC3 on my Hudy and also has 3 degrees of toe in on each wheel.
I also think 260F is still too hot for the motor. I thought it was 240F.
Isaac is offline
Old 03-26-2002, 03:52 PM
  #1539
nova racer's Avatar
my engine temps tend to be between 240 and 280. and i get around 6to7 gal's out of each engine before its time for a rebuild. The key to long engine life is proper break in and high quality fule.
nova racer is offline
Old 03-26-2002, 04:06 PM
  #1540
anyone know where to get replacement parts for the MT 12 for the mugen? My LHS doesn't have it
Old 03-26-2002, 04:11 PM
  #1541
RAP66's Avatar
www.ace-hobbies.com
they have parts for most of the engines...
Rich
RAP66 is offline
Old 03-26-2002, 04:32 PM
  #1542
Ah10's Avatar
Originally posted by Kool
AH10:
My friend in Hong Kong got them for me! If I am not mistaken they are like $15.50 each, about the same cost as Mugen but they dont wear out! I have been using it for a while already and it still look like brand new, no sign of wear!
Ah10 is offline
Old 03-26-2002, 04:39 PM
  #1543
Ah10's Avatar
Default Re: Re: Toe
There are also a few factors too!
1. how are you temping your engine?
2. What kind of temp gun?
3. are you temping the glow plug or heat sink?
if you are temping the heat sink your reading will be higher and if you are temping the glow plug it will be more accurate also the distance between the glow plug and your temp gun.
I am using Reytek infrad temp gun and I push it against the heat sink and shot straight to the glow plug. (the body that I am using allow me to cut a big hole above the engine so I could get the temp gun as close to the head as possible!)
Ah10 is offline
Old 03-26-2002, 05:41 PM
  #1544
Sorry that i didn't get it to you sooner. Just catching up on the posting. Here's the website for powerline. My lhs push their products pretty hard.
http://www.powerlineracing.com/
VinDollar is offline
Old 03-26-2002, 05:55 PM
  #1545
Default Crystal park
Does crystal park have a website i can visit???
