Old 06-01-2007, 03:51 AM   #16
rcabj's Avatar
Hi guys and ASW....u r certainly right but what got me confused (i think ) is the way the kyosho manual indicates the clutch setup (if i'm not mistaken) by adding shims outside the thrust bearing only...whereas no shims is required inside the internal bearing...so when u push the bell inside it will certainly touches the clutch shoe, meaning like there is no endplay setting with kyosho's setups...right? when the motor is running the spinning flywheel will create a minimal force so the clutch bell wouldn't rub againts the shoes even without placing shims inside. there is no problem arising from such method. i have done it bothh ways and they work perfectly....not really a problem, just to get a clearer picture.. thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-01-2007, 03:59 AM   #17
rmdhawaii's Avatar
The original RRR and RRR WCE manuals did not cover setting endplay. I consider it a major oversight. The Evo manual has something, but it is grossly inadequate.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 06-01-2007, 04:00 AM   #18
rizal_eg9's Avatar
same with MTX4 manual.....
rizal_eg9 is offline   Reply With Quote
Old 06-01-2007, 04:04 AM   #19
razzor's Avatar
With the inner bearing installed you dont want too much fore and aft movement.This is the end play.Shim behind the inner clutch bearing to get as little play(.1mm) as possible.I usually add a shim at a time till the clutch bell feels resistance and then remove a shim, preferably a thin .2mm or .3mm shim.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 06-01-2007, 09:22 AM   #20
jeff1's Avatar
If you don't shim before inner bearing you will have a huge end-play setting something like 0.5mm of bell movement along engine shaft. Pick up a copy of Evo manual, now it explains how to set this
jeff1 is offline   Reply With Quote
Old 06-01-2007, 11:42 AM   #21
asw7576's Avatar
Originally Posted by razzor
With the inner bearing installed you dont want too much fore and aft movement.This is the end play. Shim behind the inner clutch bearing to get as little play(.1mm) as possible.I usually add a shim at a time till the clutch bell feels resistance and then remove a shim, preferably a thin .2mm or .3mm shim.
Don't forget to say this setup for G4S clutch bro
Old 06-01-2007, 11:50 AM   #22
razzor's Avatar
Yes on my G4S and my Serpent Impulse Pro .
Casterracing ZX1.5R
clutch play dido41 Rookie Zone 0 08-02-2006 05:33 PM
Setting up clutch tractorpull Rookie Zone 1 03-09-2006 06:02 AM
clutch 2-speed setting Dodge_Stratus Singapore R/C Racers 0 10-02-2005 11:35 PM
End-Play on a Centax 1 clutch? New_Toasted Nitro On-Road 4 09-06-2004 10:29 AM
NTC 3 Clutch setting kitracer Nitro On-Road 5 04-03-2002 10:03 PM
