Old 12-09-2001, 08:01 AM   #16
xray's Avatar
Novarossi, will it fit my MTX-2??
xray is offline   Reply With Quote
Old 12-09-2001, 08:37 AM   #17
hurhur's Avatar
answering on behalf of NR, the negative diff will fit the MTX, provided u bought the one for MTX. they have one for V1R too
hurhur is offline   Reply With Quote
Old 12-09-2001, 08:47 AM   #18
xray's Avatar
Thanks, hur-hur!!
Do you know where I can find it? how much does it cost?
Old 12-09-2001, 09:50 PM   #19
Default NEG DIFF
COULD SOMEONE PLEASE PUT A PART # UP FOR THE NEG DIFF.(FOR A V ONE R) THANKS!
LURCH is offline   Reply With Quote
Old 12-11-2001, 05:05 PM   #20
Originally posted by Manticore
yes the holes are for cleansing purpose according to the instruction manual. I have a japanese speaking friend translated it for me. There is nothing that you can adjust the clutch but if you want, you need to dissemble the diff every time you need to make adjustment by cutting or putting up weight on the clutch shoes.
Thanks Ah10 & Manticore
So it would probrably be worthwhile getting an extra set of shoes so you could modify one set.
Any ideas on how you would add weight to them?
muugen is offline   Reply With Quote
Old 12-11-2001, 05:38 PM   #21
Manticore's Avatar
R/C Tech Charter Subscriber
when you have a spare set of clutch shoes you will have either lighter or heavier set of shoes. You can do it in this way. Drill hole(s) at the end of the shoes. This will reduce its weight. And if you want to add weight, put short set screws to fill the holes and this will give you extra weight then the original clutch shoes.
So far I find the standard clutch shoes works reall well and you dont really do this stupid trick.
Manticore is offline   Reply With Quote
Old 12-13-2001, 03:32 AM   #22
Hmmm Manticore is giving out stupid trick advice?
Sydewynder is offline   Reply With Quote
Old 12-17-2001, 07:17 AM   #23
Manticore's Avatar
We need to be stupid once in a while !
FUTABA 9550, EXPLODED VIEW SRBMOJO Radio and Electronics 1 08-20-2008 04:44 PM
Battery Exploded Boost231 Radio and Electronics 22 07-26-2008 12:32 AM
Always do a proper run in / exploded piston!! 40% Electric Off-Road 9 02-12-2007 10:06 PM
Need exploded view of Novamega SG_Racer Onroad Nitro Engine Zone 4 04-01-2005 10:03 AM
Kyosho USA 1 Exploded view RobK1 Monster Trucks 2 05-30-2004 04:29 PM
