Repairing Foam tires.... >
Old 04-16-2003, 09:59 AM
Regional Moderator
Darkseid's Avatar
Default Repairing Foam tires....
Hey guys, I think I'm going to take a shot at repairing a foam tire I chunked this weekend.
I got everything I need to repair it(foam to replace the chunk, access to a tire truer, etc...).
What I need to know is what adhesive do I need to use to securely place the new piece of foam on the rim???
thanx
Darkseid
Darkseid is offline
Old 04-16-2003, 10:06 AM
Corse-R's Avatar
Default Re: Repairing Foam tires....
Use what we used in the past for glueing foam tyres. Contact glue (not CA).
If you've rescued the part that chunked off in good shape, apply a coat of contact glue (¿shoe goo?) at both sides (tyre/rim) let dry for 3 or minutes and join the two parts. Let dry for 24 hours and true the tyre. If you use CA you let hard spots on the foam and make the handling and grip twitchy.
Corse-R is offline
Old 04-16-2003, 10:27 AM
Regional Moderator
Darkseid's Avatar
Contact cement? Thats what I thought, but I wanted to be sure.
I couldn't find the actual chunk that came out, but I am planning on cutting a clean spot into the sidewall(the place that got chunked), around the damaged area and using some foam from an old damaged tire of the same shore as the replacement piece.
I've heard that using this method, when you can't locate the original chunk, is just as good.
Thanks for the quick answer Corse-R
Darkseid is offline
Old 04-16-2003, 10:55 AM
Trader Rating: 2 (75%+)
I'v used Shoe Goo or Fender Mender.
Flexable and stays!!!
PUNISHER is offline
Old 04-16-2003, 11:08 AM
Regional Moderator
Darkseid's Avatar
thanks for the tips
Darkseid is offline
Old 04-16-2003, 03:48 PM
modellor's Avatar
Yeah, contact glue or Evo Brown glue are best. Dont use CA as it will just cause that part of the tire to wear differently than the rest unbalancing the car.
modellor is offline
