Old 07-08-2003, 07:02 PM   #91
Im2lazy's Avatar
I don't know hwo you could get it, but I bought 1400 zip ties for about 10-15$ at a local car parts store. Very nice and complete... Still haven't run out after a year .
Im2lazy is offline   Reply With Quote
Old 07-14-2003, 04:00 AM   #92
esham's Avatar
Is it common to appy break on every 180° corner ? And how about the punching ?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-03-2003, 08:14 PM   #93
esham's Avatar
Talking 5th Race experience for the beginner
Yesterday August 3rd 2003 participate in a Race for 5th time.
Before race, I setup my car and change to new belt.
Front
Diff Oil 30,000
Toe Out 2
Camber 1
Spring Kyosho Yellow Medium
Shock Oil 40wt
Rear
Diff Oil 7,000 LSD
Toe In 2
Camber 2
Spring Kyosho Orange Soft
Shock Oil 30wt
Change Belt
Check all my fasterner screw - Tighten
Check set screw - apply loctice were applicable
1st Heat - 5 minutes
Driving style novice maintain at the middle and enter corner safely, no crash smooth, but abit understeer probably the front diff oil 30,000wt is abit too much for my track. Straight line ok the engine work very well, High torque and good speed ( Rody Rome 5 port modified engine ). Finish with 18 laps!. Againts the top racer finish 19 laps
2nd Heat 5 minutes
Driving style novice maintain at the middle for a while than abit aggressive on cornering. Abit slide into corner and fast accelerate out of corner. Engine very well straight line. Is a "shark" ! Finish with 19 laps/20laps.
They annonce me qualified for A Main Final
A Main Final - 15 minutes
Before the final start , test run 1,2,3,4 laps suddenly somebody crash me from behind push me to a side and knock a track tyre. Damn ! Rear Floating bend, Shock joint damage. Put it part together and then start the race. First lap, Spur gear slip, Oneway bearing intermitten on. Not finish the race give up !
Notice the crash before that make my oneway bearing housing being push in. Anyway satisfy as manage to be in A Main among experience driver. Watch out ! I'm comming close!
Old 08-03-2003, 08:22 PM   #94
B
sounds like u had a lot of fun!!
congrats on that and your great qualifying experience
B is offline   Reply With Quote
Old 12-03-2003, 08:15 PM   #95
esham's Avatar
Default The 7th race for me on Sunday
Hi all, This coming Sunday 7th December 2003 I will participate for 7th race. And I still tuning my car setup because I still not feel comfortable with my car behaviour in taking a corner.
My current setup make my car drag / slide too long into corner ( "L" corner ). It is a habit of me or maybe my style rushing into corner and aggressively full turn my radio steering in taking "L corner" as a result the car will slide into corner but this time is too long ! . Please refer to my drawing attach.. I want to setup my car as the "green car" travel and currently my car react as the "white car".
Plan adjustment
1. Tires - current setup is 42/40 , Plan to chance it to 40/37 the idea is more grip, less slide push .. perhaps its work..)
2. Rear toe in - current setup is 2° toe in, Plan to chance it to 3° the idea is to increase the slip angle, more grip and less slide push.
Emm..anymore suggestion or idea guys???
Old 12-03-2003, 08:26 PM   #96
theRED5's Avatar
R/C Tech Charter Subscriber
esham, stay with the 42 fronts and go to the 37 rears.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 12-03-2003, 08:29 PM   #97
theRED5's Avatar
and I also like the lite blue front springs with grey rears, it gives the rear a little steer to take up what front push I have.
Mugen MRx4
Old 12-03-2003, 08:33 PM   #98
KMac's Avatar
Along with the springs mentioned above, I'd also try thicker shock oil. Your car appears to be transferring weight too quickly. If you still have 40wt front and 30wt rear, I'd jump up to 60wt front/50wt rear and I believe you'll see a noticeable difference.
KMac is offline   Reply With Quote
Old 12-03-2003, 08:42 PM   #99
InitialD's Avatar
Yes, agreed.
Old 12-03-2003, 08:56 PM   #100
drfritz's Avatar
Default Re: The 7th race for me on Sunday
[QUOTE]Originally posted by esham
[B]Hi all, This coming Sunday 7th December 2003 I will participate for 7th race. And I still tuning my car setup because I still not feel comfortable with my car behaviour in taking a corner.
well instead of adjusting your set up for on corner, why not try a different line into the corner. the way you have you drawing it looks like you are piching the car into the turn, try instead running the on the right side of the lane and hitting the apexs of the corners "ak" straighting out the turn. the less you have to turn the wheel the less speed that you scrub off.
drfritz is offline   Reply With Quote
Old 12-04-2003, 02:09 AM   #101
esham's Avatar
Default Re: Re: The 7th race for me on Sunday
[QUOTE]Originally posted by drfritz
[B]
Yea.. I wish that I can do that .. actualy the track is quit narrow and the distance between the apex is quit distance apart. Yup .. understand your suggestion..thanks..
Regarding the shock oil and the spring, the way i see it is if Prof D already it on this matter .. I take it TQ
Old 12-04-2003, 05:18 AM   #102
Originally posted by theRED5
Another pro I know says he never lets off the throttle fully, he rides the trigger through a turn...thats really hard to do...
Oh, and the best advice I ever got, was squeeeeezzzzzzeee that trigger (off the turn) don't yank it back to full throttle...Slow down, you'll prolly go faster
i don't agree with you bout the first thing i quoted, i have 95% of the corners with throttle!
second: i fully agree!
-Nitrohead- is offline   Reply With Quote
Old 12-04-2003, 06:44 PM   #103
esham's Avatar
Default Caster effect
Hi just to straight up my mind about caster setting.
Is it correct concept on what I understand about caster is -
More caster will make your car to have more camber during cornering which will reduce the front tire contact to the ground and make the car less steering..? Is this thought correct?
Old 12-04-2003, 07:44 PM   #104
InitialD's Avatar
Default Re: Caster effect
For a good and clear explanation of caster, you can read this here.
However, note that how tight you set the rear diff and caster angle of the front wheels will work hand in hand. Quoted from Michael Salven himself...
With more caster the inside rear wheel will lift more, when you turn the wheels. Because of that effect you actually gain steering (or loose rear traction). On the other hand you have less front rubber touching the surface because the inside wheel will run more on it's edge.
If you gain steering or not with more caster may depend on your diff settings. If you run a tight diff or solid rear axle, you will gain steering on and off throttle, because the lifted inside rear wheel will help the car to turn. With an open diff you don't need to lift the inside wheel, in that case the car may turn better with more front rubber on the street, which means less caster.
Old 12-04-2003, 09:52 PM   #105
Default Re: Re: Caster effect
D, Ive been trying that... both combination. Both is better for on throttle and not notice any difference in off throttle. But, maybe Im just a beginner too..
For better initial turn in (off throtle), harder rear stabilizer is still better option.
Just my 2 cents.
GoldFinger is offline   Reply With Quote
Driving Style peded Electric On-Road 20 10-19-2007 07:24 PM
Driving style? tc3team Electric On-Road 20 03-26-2007 03:54 AM
Adjust Car Setup or Driving Style? LJae Electric On-Road 10 01-19-2007 09:04 PM
Driving Style. *Throttle* DaRollaRacer Nitro On-Road 38 03-20-2006 05:49 PM
EP and GP driving style xwing Electric On-Road 0 04-25-2003 06:25 AM
