Ventilation in nitro bodies >
Old 04-15-2003, 06:58 PM
Canuck's Avatar
Trader Rating: 25 (100%+)
Default Ventilation in nitro bodies
I have a HPI porsche body for a Kyosho Mark II Spider nitro sedan and was wondering about ventillation holes.
I did cut a 40mm hole in the front windshield and one on the side for the exhaust tip.
Do I need to cut out a side window for more venting ? Will this mess up any possible admission to races because of the side vent ?
Any recommendations ?
Canuck is offline
Old 04-15-2003, 07:09 PM
my friend cut out his windows and now he his body look well lets just say it screwed up his body just leave it like it is and it should be fine
buggyman81 is offline
Old 04-15-2003, 07:51 PM
RedScorp's Avatar
there's no need to cut your side windows. In fact any air flow, if any through side windows would be minimal. Unless you power slide through the whole race cutting your windows won't be beneficial.
RedScorp is offline
Old 04-16-2003, 02:43 AM
Canuck's Avatar
Thank's guys !
Should I cut a whole in the rear or leave everything as is with a 40mm whole just in the front windshield ?
Canuck is offline
Old 04-16-2003, 05:38 AM
che
che's Avatar
You should cut a hole in the rear window to allow the heat to escape out the back, and clean cool air to pass through. It should be at least the same size as the front hole. Some guys even cut it out larger, almost the entire rear windshield...
che is offline
Old 04-16-2003, 04:33 PM
Canuck's Avatar
OK, I thought it was not LEGAL for racing when you cut a whole in the back !
Canuck is offline
Old 04-16-2003, 10:11 PM
RedScorp's Avatar
Well, it would be silly to make it illegal. If you can let air in you have to provide an outlet of escape otherwise it's useless.
RedScorp is offline
