Old 04-15-2003, 01:54 PM   #1
MDS
Default Hitec HFS - 03MM Reciever prob
Hi any clues on how to fix my reciever, it works perfect untill you let the failsafe cut in then the steering and throttle moves eraticaly, tried another reciever (same make and model) and it works perfectly, any ideas?
thanks
MDS is offline   Reply With Quote
Old 04-15-2003, 02:33 PM   #2
popsracer's Avatar
MDS:
I currently have 4 of these Receivers and NEVER a problem with one.
Make sure your FailSafe is Hitec compatable. There are different units for different Receivers.
popsracer is offline   Reply With Quote
Old 04-15-2003, 02:53 PM   #3
MDS
Default Reciever
All my mates use the same recevier and failsafe, any idea
Old 04-15-2003, 09:04 PM   #4
popsracer's Avatar
MDS;
I would suspect either Crystal or internal danmage to the Receiver from a crash. Try a different crystal set, otherwise something is wrong with the RX. If it is brand New, I would contact Hitec directly. Good luck.
Old 04-16-2003, 03:52 AM   #5
squizzytaylor's Avatar
Default re failsafe
What brand is the failsafe? I have had a couple of venom units play up with similar effects. Both times it was a factory fault.
gt
squizzytaylor is offline   Reply With Quote
Old 04-18-2003, 06:29 AM   #6
MDS
Default Failsafe Brand
The failsafe is a Fastrax A.B.F.S Failsafe unit. It is really buggin me.
Old 04-18-2003, 08:32 PM   #7
popsracer's Avatar
Default Re: Failsafe Brand
I know that some People will not like this but, just run without the Failsafe. I've ALWAYS used a Throttle Return Spring and a Rubber Band on the barrel and never had a runaway.
If you get hit by some Idiot turning on his Radio in the pits, time to have a up close and personal conversation with that Guy.
Old 04-19-2003, 08:36 AM   #8
MDS
Default No help
cheers for your idea but it doen not help me.
FS Like new Hitec HFS-03MM RX ch 63 straightaway R/C Items: For Sale/Trade 4 06-22-2007 04:26 PM
Hitec Reciever HFS-03mm 75MHz and More To Come Big B R/C Items: For Sale/Trade 4 02-02-2007 01:58 PM
40mhz fm hitec HFS-03MM reciever xxblackheartxx2 Australia For Sale/Trade 18 06-11-2006 08:50 PM
HITEC HFS 03MM RX hectorjr R/C Items: For Sale/Trade 1 01-23-2006 06:22 PM
