Old 04-28-2003, 02:51 AM   #61
Send a message via ICQ to V-One S
on the front for camber u rote 1 block in front.
i think u have the caster and camber mixed up
and u never gave a measurement for camber at all.
and in degrees for the caster it would b eithre 8 dgree or 10 degree depending if its a big or little block.
V-One S is offline   Reply With Quote
Old 04-28-2003, 04:14 AM   #62
rrgt_kid's Avatar
Default Re: My problem solved
Originally posted by esham
Hello everybody.. I believe that my Overster problem is solved now. What i did is setup my alignment right and then abit particular with my tires selection.
My Setup for last weekend race is:-
Car Model = Kyosho V1RR + Mugen MTX3 rear upright (M1RR - Manticore/AMGracer version)
Front
Toe out 1
Diff oil 10K
Sway Bar 45
Shock oil 40wt
Tires-Sorex Tire 40R
Medium Soft Insert
Camber 1 blok in front ( Not sure of that on degree)
Rear
Toe in 1
Diff oil 7K
No sway bar used
Shock Oil 30wt
Soft Insert
Camber
why only 1degree toe in on rear 2/3 is a minimum.
rrgt_kid is offline   Reply With Quote
Old 04-28-2003, 04:17 AM   #63
yes with his problem and not liking tail slide, i'd run 2.5 toe in on the rear.
Old 04-28-2003, 04:28 AM   #64
rrgt_kid's Avatar
i run 3 to 3.5 depends on track conditions
Old 04-28-2003, 04:30 AM   #65
I run on my S 1 toe in all the time, and it only just looses traction when i give it full power, and then its understeering.
Old 05-01-2003, 06:28 PM   #66
esham's Avatar
Default 2 Toe in - Rear
Yea... it is correct it is a mistake there - my toe in rear is 2. Understeer and Oversteer is it also can be effected by how you punching the trigger? Meaning during cornering - sharp 180 corner punching trigger frequently seem make the car about to spin but in the way sharp cornering -Oversteer
esham is offline   Reply With Quote
Old 05-02-2003, 01:59 AM   #67
Dont know what it is. But the car is just perfect for me to drive.
Give it full throttle mid corner, and it just understeers a bit there, going to try and correct it next meet.
Old 05-06-2003, 06:10 PM   #68
esham's Avatar
Red face How to reduce oversteer on exiting corner with power
Sometime now I do have problem oversteer on exiting a corner with power. What are the tweak that I should check?
Old 05-07-2003, 01:14 AM   #69
Corse-R's Avatar
Default Re: How to reduce oversteer on exiting corner with power
Add a little of Camber to the front wheels, beware it modifies too the entering into a turn.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-07-2003, 03:24 AM   #70
add some front droop.
more front droop = more under steer on power
less front droop = more over steer on power.
Old 05-07-2003, 10:20 AM   #71
popsracer's Avatar
Default Oversteering
esham;
I might add that you could have an overall traction problem and need to go to a softer compound tire. Otherwise try 'V-ONE-S's suggestion.
popsracer is offline   Reply With Quote
Old 05-07-2003, 10:17 PM   #72
esham's Avatar
Thanks guys,
Yes I will check that up this afternoon. V-OneS give a simple equation there
Old 05-08-2003, 02:30 AM   #73
if you go into the V-One S thread, on about page 96, there is a file by Squizzy Taylor there, it explains all the uses of droop and what it affects where.
Old 05-12-2003, 01:07 AM   #74
esham's Avatar
Thanks V-One S, actually it is on page 97 and it direct to this attachment by Squizzy Taylor http://www.rctech.net/forum/attachme...&postid=357223
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
Old 05-12-2003, 03:15 AM   #75
yes thats the one i meant
sorry.
*****INDI 16X908 Climate Control Charger with Thermo Control Stand - 180.00 Shipped* dgullickson R/C Items: For Sale/Trade 65 09-08-2008 09:40 PM
Oversteering mcf_1 Nitro On-Road 2 09-08-2008 09:41 AM
*****INDI 16X908 Climate Control Charger with Thermo Control Stand******* dgullickson R/C Items: For Sale/Trade 35 06-04-2008 07:12 PM
oversteering on one side only pekpekmaster Rookie Zone 7 07-07-2007 09:41 PM
oversteering problems... vti-chris Nitro On-Road 6 12-04-2006 11:28 AM
