Old 05-15-2007, 04:30 PM   #16
rmdhawaii's Avatar
Originally Posted by Marcos.J
What's so funny??
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 05-15-2007, 04:42 PM   #17
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by dj apolaro
To be honest I think that stiffening the car is bad thing for traction roll issues and that is were most people go wrong. the car flips because the suspension is so hard that the chassis can not roll and instead just flips. you need more chassis roll to help the traction roll issue. IMO you can make the car soften or I like to take off a sway bar, most of the time the front. the harder tires and roll center position is also key and yes you do want to take traction away from the front to help.
I think what is trying to be said is with stiffer springs the car reacts faster and the car traction rolls violently. When you soften the car it make the chassis react more slowly and will help stop traction rolls.
Paul Rush
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-15-2007, 04:44 PM   #18
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by rmdhawaii
What's so funny??
more roll you have the more traction roll you will get , thats why in carpet foam the cars are stiff as shi%
Old 05-15-2007, 04:44 PM   #19
Super Moderator
Marcos.J's Avatar
What's so funny??
his post
Old 05-15-2007, 05:04 PM   #20
dj apolaro's Avatar
Thats is why I put IMO and trust me my help is not meant to be funny. Did not know we were talking carpet. Sorry!!!! Also More roll does not mean more traction roll. Have a nice day
dj apolaro is offline   Reply With Quote
Old 05-15-2007, 05:17 PM   #21
DJ, dont you know that NITRO ON-ROAD is almost exclusively exicuted on carpet ! LMFAO
427 COBRA is offline   Reply With Quote
Old 05-15-2007, 05:32 PM   #22
Super Moderator
Marcos.J's Avatar
he didnt state that it was asphalt either
Old 05-15-2007, 05:35 PM   #23
Super Moderator
Marcos.J's Avatar
must be all hte nitro fumes that you guys are inhailing
see you at adrenaline next month
Old 05-15-2007, 05:55 PM   #24
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
We are in a nitro onroad forum.
I have found that stiffer front springs usually make a traction rolling problem worse. I have tried stiff, stiffer, super stiff, etc. I have never tried going softer, but stiffer has never been that effective at eliminating traction rolling. Maybe I will try going softer, but the tire size has been very effective. (Something they do in carpet)
There are things to try, but I have found harder front tires with a smaller diameter (less sidewall) is the best method to get rid of traction rolling issues. If you lose too much steering, then try a softer shore tire at the smaller diameter.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-15-2007, 06:30 PM   #25
corallyman's Avatar
Trader Rating: 99 (100%+)
I also agree that going stiff to super stiff is not always the ways to go, it can be hard to know what exactly to do in all conditions as the setups on the car are not always the same so the solution is not always the same.
One thing that nobody has mentioned yet that works is if you are not at max. width yet, you can try widening the car, this works well sometimes. An example would be in 1/8th sometimes to get steering at one track you might be narrow in the front. By going to a wider width front end its harder for it to roll and also can produce a more stable car also.
Steve
corallyman is offline   Reply With Quote
Old 05-15-2007, 08:35 PM   #26
Regional Moderator
daniz24's Avatar
go with lower shock oil and softer spring, i even tried to use EP springs for front with great result.
wider front track width also helps a lot
daniz24 is offline   Reply With Quote
Old 05-15-2007, 09:10 PM   #27
asw7576's Avatar
To be honest I think that stiffening the car is bad thing for traction roll inssues and that is were most people go wrong. the car flips because the suspension is so hard that the chassis can not roll and instead just flips. you need more chassis roll to help the traction roll issue. IMO you can make the car soften or I like to take off a sway bar, most of the time the front. the harder tires and roll center postition is also key and yes you do want to take traction away fron the front to help.
That's right.
This is what I had experience with MTX3. I use harder springs before and it still traction roll on some corners. Until someday ......... I decided to use softer spring at front ( 1.6 purple mugen ), 200mm width, shave front tires to 63mm diameter, and VOILA !!! Surprisingly the traction roll become so much less frequent than before.
Old 05-15-2007, 09:40 PM   #28
Opinions are like A/Holes , everybody has one.................
Just try what some people have said from both sides of the fence and report back here at what worked for you O/K?...............
Old 05-15-2007, 10:42 PM   #29
gansei's Avatar
Default ride height setup
1) 1/10 GP front/rear general ride height setup in 5 minutes race
2) 1/10 GP front/rear general ride height setup in 30~45 minutes race.
3) to avoid traction roll, how can ride height change?
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 05-15-2007, 10:57 PM   #30
dnitro's Avatar
I've been told you can also reduce traction roll by limiting the uptravel of the suspension (droop).
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Gearing for Traction/Slipper for Traction RCRat Electric Off-Road 2 08-27-2008 03:55 AM
traction roll dor dummies eduardo_garcia Nitro On-Road 5 10-21-2007 10:55 AM
Traction Roll penmark67 Electric On-Road 9 06-27-2007 02:53 AM
Monster GT Roll Cage or Roll Bar complete or Plans? mjm R/C Items: Wanted to Buy 1 03-18-2005 05:12 PM
Traction Roll problem f2000racer Electric On-Road 8 02-15-2005 11:34 PM
