Old 05-14-2007, 05:03 AM   #1
vti-chris's Avatar
Default Loosing traction in the middle of the race?
I run in 1/8th rallygame races using rubber tires.
I use softer in the rear and in the qualifying runs and in the first half of the race the car is hooked up.
In the second half of the race, say after 15-20mins i loose rear traction.
I can think of only two things that can cause this:
1. the front tires get to the right temperature and they hook up more
2. the rear tires overheat and loose traction
What do you thing is the main reason of these kind of oversteer?
What can i do to fix it?
Will traction compounds work...and in what way?
vti-chris is offline   Reply With Quote
Old 05-14-2007, 05:22 AM   #2
cdelong's Avatar
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 05-15-2007, 12:57 PM   #3
vti-chris's Avatar
Old 05-15-2007, 02:07 PM   #4
#2 is your problem most probably.try the next harder shore.also what is your rear ride height when you start losing traction?it can also be your wearing down your rear tires and dragging your chasiss.
Ahhh the smell of nitro in the morning!
Brooklyn Hobbies Team Driver
[url]www.brooklynhobbies.com[/url]
Team Trinity
[url]www.teamtrinity.com[/url]
Gary Figueroa
GFIGUEROA is offline   Reply With Quote
Old 05-15-2007, 04:41 PM   #5
Rapid Roy's Avatar
With rubber tires you need to use a hotter or harder compound. You can also try a harder insert too.
Rapid Roy is offline   Reply With Quote
Old 05-15-2007, 11:33 PM   #6
vti-chris's Avatar
The tire wear is even in all four tires.
The ride height is around 8-10mm which is plenty i suppose.
If i use harder tires in the rear ...say the same as front since i use one step harder in the front, won't i lose traction at the beginning of the race?
I'm also thinking of the shock oil heating up and making the damping softer...OR this won't cause oversteer on it's own?
Theoretically it should increase it, since it softens.
Old 05-16-2007, 02:11 PM   #7
ARE YOU DRIVING VERY AGGRESSIVELY? IF SO THAT MAY BE OVERHEATING YOUR TIRES.YOU MAY HAVE TO TONE IT DOWN A BIT.HARDER INSERT IN REAR MIGHT HELP,ALSO WHATS YOUR REAR TOE AT,TRY GOING TO LESS TOE IN THE REAR IF POSSIBLE TO REDUCE TIRE SCRUB.THAT MIGHT HELP KEEP THERE TEMPS DOWN.HOPE THIS HELPS GOODLUCK
Team Trinity
Gary Figueroa
Old 05-16-2007, 11:41 PM   #8
vti-chris's Avatar
I currently have a locked front diff with 1000wt oil in the rear.
I use 1 toe out up front and 4 toe in in the rear.
If i use less toe in in the rear i will lose it...!!
I use softer shock settings in the rear with softer springs.
The car drives great as it is for the first 15mins but then if i keep the same driving style i lose the rear end on slow turns while getting out of them.
On fast turns i'm OK!
street traction tires for bashing race truck beez Electric Off-Road 10 05-25-2008 10:23 PM
Loosing rear end off power? TimV Electric On-Road 24 06-10-2007 01:07 PM
LOOKING FOR HELP??? TRACTION NEED FOR RACE SURFACE KEITH Electric Off-Road 21 05-14-2007 05:47 PM
diff settings? i keep loosing control. Built B16A Nitro On-Road 18 01-04-2007 02:20 AM
Loosing highend speed after 3 mins. bvoltz Rookie Zone 8 01-06-2006 06:09 PM
