Old 05-04-2007, 10:50 AM   #1
Problem with serpent engine monoblocks
Hi, i have a Serpent 960 and the LCG chassis+monoblock set.
The problem is that the pinions can't be perfectly aligned with the spur gears (they are too far back). The first gear spur is about 1mm further out than the pinions and i can't position the engine further out.
When browsing the serpent forums i noticed there are 2 monoblocks, the picco/mega one (#903194) and a general one (#903201). Apparently the LCG set comes with the Picco one. Is this the problem ? Or is it supposed to be this way (weird) ?
I can't be the only one with this problem... i think
Storm_PT is offline   Reply With Quote
Old 05-04-2007, 10:54 AM   #2
Just remembered, i tried with the engine blocks that came with the car and the problem is the same, so maybe its supposed to work that way. Or the problem is the chassis ?
Old 05-04-2007, 11:10 AM   #3
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
What motor is being used?
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 05-04-2007, 11:48 AM   #4
Previously i had a Novamega SX-21 Evo5 KHM in it. Now i have a LC21 AAC (Sirio based) and the problem is the same.
Old 05-05-2007, 07:50 PM   #5
SRAD's Avatar
I have a 960 also and have had this problem since day one. I have both Sirio and Nova Rossi and they both won't line up no matter what I do. I have tried filing the engine mount holes in the chassis as well as the engine mounts(both stock and monoblock) and neither have resolved this problem. Really disappointed with Serpent on a few things with this car.
SRAD is offline   Reply With Quote
Old 05-05-2007, 09:07 PM   #6
Taylorm's Avatar
-i have a 960 and pinions/spurs line up perfectly....i can move my motor 1-2 mm further out than needed.........maybe chassis machined wrong?
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 05-05-2007, 11:03 PM   #7
captian's Avatar
be easy guys i used this on the car and it fix it for me
serpent part 1017 hex flanged
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 05-05-2007, 11:03 PM   #8
captian's Avatar
this part works with no mods done serpent part 1017 hex flanged
Old 05-05-2007, 11:07 PM   #9
captian's Avatar
srad its a great car get the screws for the engine mount and have fun
Old 05-06-2007, 02:11 PM   #10
Hmm, but aren't "Screws engine mount + flange (4) (#1017)" the same as the screws that come with the monoblock "Mono block M21 LCG (#903194)" (just a different color) ?
If yes, then i'm already using those screws.
Old 05-06-2007, 06:12 PM   #11
captian's Avatar
here's a pic http://www.serpent.com/product/1017/
Old 05-06-2007, 06:19 PM   #12
captian's Avatar
yes you are right sorry i use the silver ones and did not have a problem with either engine mount .
Old 05-06-2007, 06:37 PM   #13
Mine match up well with the LCG Chassis and Novarossi motor. It can also be in the clutch build. If I remember correctly, the new directions omit the 0.5mm washer behind the flywheel/crank brass engine cone. The question I would ask is how many spacers do you use between the thrust bearing and end cap (technical term) :-) If it's quite a few, then how close would it line up if you didn't need so many? That shim between the motor bearing and cone before the flywheel helps take the additional spacers out between thrust bearing and "end cap"... Which may help you line up your pinion and spur.
www.RCAmerica.com - XRAY - HUDY - Max - JACO - KO PROPO
Darint is offline   Reply With Quote
Old 05-07-2007, 07:40 AM   #14
Actually i thought it might be a problem with my clutch too. I'll redo it and then post back the results.
Old 05-09-2007, 10:17 AM   #15
Hmm, apparently it can be pretty much fixed by putting a 0.5mm shim before the cone. Unfortunately i have a broken thrust bearing so the real test will have to wait till i replace it.
Serpent Vector assembly problem Orfeous Nitro On-Road 4 12-20-2006 01:14 AM
problem with NR engine eduardo_garcia Onroad Nitro Engine Zone 0 11-06-2006 01:10 PM
.21 engine problem plz help downunder23 Electric Off-Road 6 08-13-2006 09:29 PM
NEW Serpent 710 problem??? vti-chris Nitro On-Road 6 01-03-2006 11:07 AM
Serpent Impulse moving problem! Chntwnserpent Nitro On-Road 6 10-28-2002 05:10 AM
