Old 05-02-2007, 08:29 PM   #1
Default Kyosho fw 05 questions
I just got one, but I am not sure which version it is. 1st question is did I get a good deal? $75 rtr Next question is what would cause it to pull badly to right when accelerating? It is terrible. It makes it very hard to control when accelerating from a dead stop. Any advice would be appreciated. I will try and get some pics put up soon.
Ben
BMcCoy is offline   Reply With Quote
Old 05-02-2007, 11:07 PM   #2
pramac's Avatar
I had one of those kyosho plastic blocks inside the front diff, which is should have mind you. But after a while they get worn out and what happens is that you only get drive to one of the front wheels and that caused my car to pull one way when accelerating and braking. Just replace the block or do what I did and put the gears inside and make it a proper diff.
Gavin.
Bayside - http://www.wynnumrc.org.au
Kyosho V One RRR Evo
Novarossi Plus 12-3SCT
pramac is offline   Reply With Quote
Old 05-02-2007, 11:37 PM   #3
Trader Rating: 28 (100%+)
Does it only pull right on acceleration or all the time?
Shaft drive cars have a certain amount of tourqe steer, mine used to pull badly changing from first to second gear...
Ashley Cobb is offline   Reply With Quote
Old 05-02-2007, 11:37 PM   #4
Put in a one-way if you're running foams
Old 05-03-2007, 02:04 AM   #5
pramac's Avatar
I run at Wynnum using rubbers. Its a concrete track and quite technical so brakes for me are a must.
Gavin.
Old 05-03-2007, 02:31 AM   #6
Yeah forgot about that
Old 05-03-2007, 08:17 AM   #7
Thanks for the input guys. I will check and see what it has in the front. I am running rubber tires, and when it gets up to speed it straightens out.
Kyosho RRR Setup Questions fastrcracer Nitro On-Road 4 08-19-2008 04:05 PM
Kyosho MP-5 w/ OS VG 21 questions? xbonggoox Nitro Off-Road 0 09-09-2007 08:37 AM
Kyosho Circuit 10 Wildcat questions SPO Nitro Off-Road 1 06-06-2007 03:44 AM
Kyosho Clutch questions IronTusk Electric Off-Road 7 01-30-2006 11:48 PM
Kyosho Super 10 QUESTIONS imataquito Nitro On-Road 7 01-17-2002 09:09 PM
