Old 04-08-2003, 10:19 PM   #1
GP40X's Avatar
Looking for info on the Integy Tire Truer
I'm getting to the point I need a tire truer. A Hudy truer is out of my budget range so I am looking at the Integy tire truer. It looks like it is in the same price range as a Team Cobra Trackside Truer but the Integy truer has a better feature set. I'm looking for information on how it compares to the Team Cobra unit. Likes, dislikes, what is the cutter head is made of, does it have a graduated scale to measure how much you cut, etc.? TIA
Bill (Nitro TC3 RTR Racer)
GP40X is offline   Reply With Quote
Old 04-09-2003, 12:09 PM   #2
Hey GP40X
I just picked one up(about a week ago)from Steve at SpeedTechRC.
http://www.speedtechrc.com/
Here's a pic rotation of it
http://secure400.automatedshops.com/...44103300056.31
There are no True graduated scale, just some lines on the dial and one on the base. The Cutter is pretty good, it cuts well but I've only used it for about 6 set of 1/12 tires and about 5 sets of 1/8 tires.
I got this one because the Airlines lost my Ofna truer, this one MOD-ed with a better motor, but the standard motor is fine. I just like to hog cut the first cut on new tires...
The Integy I got for 1/12 tires, but bought an 1/8 arbor just to have, and to try it out.
The Ofna is better if you going to cut lots of 1/8 tires, the auto movement of the cutter is really nice.
The Integy you have to move the cutter from a dial on the far side. For Sedan tires this isn't really a pain, and it works well on the Sedan tires, 1/12 is also easy to do, both cut really clean on the final, depending on what your final cut depth is. On 1/8 tires it works, but the motor can't cut the hog first cut I like to make, but none of the other truers will do this anyway, except the Cobra AC cutter, the really old one. I've cut 5 sets of 1/8 tires, so far but using the dial movement is getting to be a pain. If you true your tires as you go this won't be a problem, I just get lots of tires from friends, and stuff... I'm probably going to remove the dial crank and use an old electric screw driver for this, when I get time. But when I get all the tires cut I'l probably put the crank back on.
The newer Cobra AC motor doesn't seem to be as powerful as the older one I had, but I didn't really know the condition of the Newer truer, I was using one that someone had at the track, and running off a generator, when I did the hog cut it really ramped up the generator!!! But because its off a generator I really don't know if the motor was getting Full power... So this could be the problem...
Cobra DC(battery powered) is ok, but for me you need the micro adjuster thing(can't remember what its called), I really didn't like the place by hand using a ruler thing with the stock setup, I got one awhile back with the micro adjuster, but using a 540 or car motor was... well ok... It works, and it does a pretty good job on the finish cut(You need the snake cutter thing), for the size it can't be beat. Plus you can use any motor you have with you to run it.
Final...
For the money you can't beat the Integy... If you find your self doing alot of tires get an old electric screw driver and mount it were the crank goes.
Hope this Helps.
Have Fun!!!
Bradley J. Gotori
[email protected]
bgotori is offline   Reply With Quote
Old 04-09-2003, 04:59 PM   #3
stefan's Avatar
Send a message via AIM to stefan
Bradley,
what kind of motor did you have in your Ofna?
Mine is getting tired and I was looking for an upgrade.
Thanks.
stefan is offline   Reply With Quote
Old 04-09-2003, 05:11 PM   #4
Hey stefan
Man... that was awhile ago. i got it at an electronics surplus store, Factor sales in Burbank, Ca. It was tad bigger that the stock motor, I'm trying to remember the specs. If I do I'll let you know. That motor could pull some amps, when I was hog cutting, because it would shutdown my 35 amp power supply, but ran well with the 110 amp one also from a electronics surplus supply in Pasadena, Ca.. X-Army thing I found there for $100.
Sorry about not remember hings getting old....hahaha
Have a Good One!!!
Bradley J. Gotori
[email protected]
Old 04-10-2003, 03:33 AM   #5
FREAKAH's Avatar
Default MAX MOD
What ever happened to them?
IMHO, Max Mod made the best and most durable tire truers in the business.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 04-10-2003, 11:57 AM   #6
Hey stefan
Sorry I still can't recall the motor spec.'s...
Hey FREAKAH
I think they still around, but since I lost all my bookmarks I don't have there WebSite any more.
They have a Great Truer, but if your doing alot of tires turning that crank is a pain... I think thats why most people like the new truers, also the newer truers a lighter and alittle smaller... If you've lugged one around you know what I mean.
Have Fun!!!
Bradley J. Gotori
[email protected]
Old 04-10-2003, 12:02 PM   #7
stefan's Avatar
Bradley,
don't torture your brain, I'll find a motor, no problem
Old 04-11-2003, 05:47 PM   #8
GP40X's Avatar
bgotori
Thanks for the info. Sounds like I need the Integy truer. It will be used to keep my NitroShoes in shape so this will save me money for more tires & I can get the two speed a little sooner. WooHoo
Old 04-11-2003, 10:39 PM   #9
Hey GP40X
Just remember... I just got it, so I don't know how long it will last. But so far I've Dead-Stopped it about 20 times... No Problems, and the motor torque seems to be the same!!! I looked at the brushes, and Arm and it looks Ok too...
Also on the final... I make a 1mm cut, making 2 passes each way. Then I check the size. There all even(+-.001)... So this is good enough for me. But some guys like it closer(+-.0005)... But to each his own... If you want it closer just keep cutting without moving the dial.
You might ask about a spare cutter just incase... But so far I haven't bent it...hehehe
Have Fun!!!
Bradley J. Gotori
[email protected]
Old 04-15-2003, 02:55 PM   #10
coastaltony's Avatar
I just got the AC Team Cobra truer.
Anyone use a file or rasp to finish the edges?
coastaltony is offline   Reply With Quote
Old 04-15-2003, 06:25 PM   #11
Hey coastaltony
Yea.. I used to use one of those. Now I use a Concaved Snake skin file thing I got at a Swap meet about 3yrs ago.
Its easier if you have some sort of brace for your hand when you do this, that way there all the same radius.
Have Fun
Bradley J. Gotori
[email protected]
Old 04-15-2003, 09:36 PM   #12
theRED5's Avatar
R/C Tech Charter Subscriber
Look in the airplane section of your LHS, there's some carbide flat sanders made, I bought one about 15 years ago and it still works great...also, a bookstore that sells drafting equipment will have some cheap pencil sharpening sanders that work good. they have multiple sheets of sandpaper mounted on a paint stirring-looking thing.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 04-16-2003, 06:05 AM   #13
Thanks for the help guys
Old 05-03-2003, 05:29 PM   #14
JonB's Avatar
Send a message via AIM to JonB
I just got the truer, but I'm not exactly sure which way it's supposed to spin -- it didn't come with any instructions. Is it supposed to spin against the grain of the teeth or with them?
JonB is offline   Reply With Quote
Old 05-03-2003, 05:51 PM   #15
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
lets suppose you have teh money to spend..is the HUDY the real deal?.....I was going to get the executive......(plus that great aluminum case)....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
***Integy Tire Truer/Hudy 1/10th setup gauges/Integy Charger F/S*** HarKonnenD R/C Items: For Sale/Trade 40 09-25-2008 10:17 PM
AMB Transponders,LRP PULSAR SPORT AND COMP,INTEGY 030 DISCHARGER,INTEGY TIRE TRUER NOTFASTENOUGH R/C Items: For Sale/Trade 10 06-19-2007 04:30 AM
integy auto tire truer barand new cut one tire hpiracer0911 R/C Items: For Sale/Trade 4 01-15-2007 04:13 PM
Integy Tire truer, Arbors 1/10 and 1/12 plus carbide tire file evostyle R/C Items: For Sale/Trade 11 03-22-2005 11:58 PM
Tire truer info... 6Cuda6 Nitro On-Road 4 12-09-2004 08:44 AM
