Old 04-29-2003, 11:28 PM   #91
THeGame's Avatar
Send a message via AIM to THeGame
Default MTX-3 Clutch on the Reflex
popsracer were you talking about the 2 speed cluch or the cluch shoes ?
thanks
THeGame is offline   Reply With Quote
Old 04-30-2003, 11:31 AM   #92
Trader Rating: 49 (100%+)
Default Hopup parts. Are they worth the cost?
I am about to get a few hop-up parts for my reflex and wanted to know if they are the cost.
I already have the basic hop-ups like Alum brake lever, hex nuts, sway bar
Nt2512 Alum middle mount
Nt2129 Alum. shock tower
Nt 2155 Hardened disk brake
Kyosho Black springs (anyone know part number)
rodneybarrett is offline   Reply With Quote
Old 04-30-2003, 12:13 PM   #93
coastaltony's Avatar
Rodney
rear black springs # VZ073-4016
front black is VZ072-3017
Trinitys dual rate springs also work well.
coastaltony is offline   Reply With Quote
Old 04-30-2003, 02:57 PM   #94
THeGame's Avatar
what is wrong with the trinity springs ? what is the Black spring rate ?
Old 04-30-2003, 02:59 PM   #95
game didnt you get a centax? you did get a fully loaded reflex team version right?
jason102276 is offline   Reply With Quote
Old 04-30-2003, 02:59 PM   #96
THeGame's Avatar
Default rodneybarrett
get all four of the hardened pullys, thh shock tower and the disk brake. you should be good to go with that..
Old 04-30-2003, 06:04 PM   #97
tony montana's Avatar
Trader Rating: 66 (100%+)
Game I may be there. I would like to since I havnt been there like in a year or so.
tony montana is offline   Reply With Quote
Old 04-30-2003, 07:09 PM   #98
THeGame's Avatar
Tony looks like rain on Sat..
Old 04-30-2003, 07:22 PM   #99
td-civ's Avatar
Trader Rating: 18 (95%+)
well i got my new reflex tonight so im going to buy a motor and pipe soon and i dont know if im going to do the same set up as the other one the other one has a os max tr12 with a os header and c-vec pipe
td-civ is offline   Reply With Quote
Old 04-30-2003, 08:31 PM   #100
popsracer's Avatar
Default trinity reflex
Guys;
If you have the NON-anodized Pulleys and are having problems with them. I recommend the V1RR Reinforced Pulley Set. The Part # is VZ008-B. Tower has them in Stock.
The V1R "Black" springs just seem to make the Car more Balanced Front to Rear. For a Large Permanent Track, they may be a little soft, but still a very good starting point. For Parking Lot Tracks, they are the best.
rodneybarrett;
Trim the Back of the Stock Clutch shoes to lighten them up and engage later. This is per Trinity's recommendation.
One thing about the Centax, is you don't have to deal with those (@>%?^@!) clutch springs anymore.
popsracer is offline   Reply With Quote
Old 05-01-2003, 01:03 AM   #101
THeGame's Avatar
Default jason102276
I got the Team Only kit.. I dont like the Centax cluch at all. ITs still in the bag.
Old 05-01-2003, 06:38 AM   #102
CRASH's Avatar
Trader Rating: 26 (100%+)
Will an SG crank shaft work with the Team Only Kit Centax? Or do I still need to get the adpator for the SG crank shaft?
Thanks,
CRASH is offline   Reply With Quote
Old 05-01-2003, 09:30 AM   #103
popsracer's Avatar
Default Reflex Centax clutches
CRASH;
Will an SG crank shaft work with the Team Only Kit Centax? Or do I still need to get the adaptor for the SG crank shaft?
You only need the adapter nut when using a Standard RFX Clutch. The 'Team Only' Centax MUST be used on a SG Crank and comes with it's own special nut. (look at the instructions)
THeGame;
I didn't like the very Small diameter Flywheel on the Trinity Centax. This is why I installed the MTX-3 Centax on my Car. The Flywheel is closer to the Standard Reflex flywheel diameter, so the engine runs more consistant on small tracks and is easier to drive. (price was 1/2 the cost too)
Old 05-01-2003, 05:28 PM   #104
Game just saw the forcast doent look to good. Where did you get your team only kit and how much. Popsracer Yes I have had problems with the stock pullies and belts. Ran the car 3 times and broke a front pulley and belt, must have got a small pebble in it. So the vir pullies are a direct fit?
Old 05-02-2003, 06:51 AM   #105
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
better sell 'em while you can...
http://www2.towerhobbies.com/cgi-bin...?&I=LNEUV3&P=G
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
FS - TRINITY REFLEX TEAM ED & REFLEX NT CARS MUST GO!!!!!! Big Reg Australia For Sale/Trade 7 03-09-2008 10:42 PM
Trinity Reflex 12 fuelgun R/C Items: For Sale/Trade 11 01-17-2006 09:16 PM
Trinity Reflex 12 TheTurtleMan Electric On-Road 1 01-04-2005 06:35 PM
FS/FT Trinity Reflex Cosmo R/C Items: For Sale/Trade 3 04-09-2002 05:08 AM
Anyone into the Trinity Reflex? vanntz Singapore R/C Racers 5 04-08-2002 10:10 PM
