Old 04-11-2003, 05:05 AM   #31
Moderator
Like I posted earlier, kyosho has kevlar option belts, not the same as comes with kit. Does the mugen centax and pinions fit? I'm pretty sure the two speed parts serpant copy. What other manufacture pinions fit the stock end bell? Do the stock pinions fit the mugen centax?
JCTC3 is offline   Reply With Quote
Old 04-11-2003, 05:17 AM   #32
mitch179's Avatar
yeah i have those option 'team kyosho' belts....
the mugen centax fits and works great ... I use Kyosho pinions on my mugen clutch bell so i couldnt say if the pinions from the kit fit... If you are going to get the mugen centax i would reccomend using the kyosho pinions with it
mitch179 is offline   Reply With Quote
Old 04-11-2003, 11:27 AM   #33
popsracer's Avatar
Default Reflex OPTION parts
mitch179;
Which Engine mounts did you use with the Mugen Centax clutch. The Standard 1 piece or the lowered mounts?
srfreeman;
For rubber tires on Asphalt:
Front shocks 45wt oil, Start with one thin Caster clip in front and adjust depending on the track layout. Zero degs Front Toe, 5mm ride height, 2mm Droop, -1 deg Camber.
Rear Shocks 40wt oil, 3-4 degs Rear toe (depending on bite), 5mm ride height, 4mm Droop, -1 deg Camber. On a very large High Speed track, I might run 2 degs Rear Toe or a very loose track, I've run as much as 5 degrees. More Rear Toe also helps rotate the Car through the turns.
All other setting are the Kit recommended settings. I only change Front Caster and Rear Toe based on Track conditions. If I run Foams, I will adjust Rear Camber to -1.5 degs for wear, but thats it.
The Reflex handles MUCH better with a little stiffer springs than the 'Blue' Kit springs.
What I really like about this Car, is it responds to minor set-up changes very well. Unlike my old HPI Nitro car, which was VERY numb to changes.
Have fun
popsracer is offline   Reply With Quote
Old 04-11-2003, 03:35 PM   #34
srfreeman's Avatar
Thanks for the setup!
What spring are you guys using? It looks like the Associated tc3 spring kit should work and has a lot of springs to tune with.
srfreeman is offline   Reply With Quote
Old 04-11-2003, 06:28 PM   #35
mitch179's Avatar
pops: i use the 1 piece mount that came with the kit and i had no problems fitting it again i really reccomend this clutch, i have had a serpent centax aswell and it sucked big time compared to the mugen centax
Old 04-11-2003, 07:27 PM   #36
popsracer's Avatar
Default Mugen Centax in a Reflex
Originally posted by mitch179
pops: i use the 1 piece mount that came with the kit and i had no problems fitting it again i really recommend this clutch, i have had a serpent centax as-well and it sucked big time compared to the mugen centax
Thanks, That is what I was hoping you would say. I really didn't like the idea of going to a smaller flywheel as I am very happy with the acceleration and idle characteristics of the standard RFX flywheel.
Thanks, again
PS: I am assuming that the Clutch parts must be purchaced seperately, or do they sell it as a complete unit?
Old 04-11-2003, 07:53 PM   #37
modellor's Avatar
Default Re: Radar clocking a Reflex
Originally posted by popsracer
I sure would hate to have that Cop point his Radar Gun at my Full size Car. Sounds like it out of calibration by +20mph. Even with the tallest gearing, there is no way YOUR Reflex is going to do 70mph. 55-60mph MAYBE, but 70! very unlikely.
It must be a Ritchy mod engine. His engines in the UK have been showing pretty impressive pace and statements have been made that they were able to outrun a 1:8th car down the straight.
That sounds scary to me since the police clocked our 1:8th cars at over 80mph on a 70m straight 10 years ago and power has increased seriously since then. But I would say that on an average 1:10th circuit here in the UK they would be only reaching the 70mph mark in the right circumstances. 60mph to me would sound about right.
modellor is offline   Reply With Quote
Old 04-12-2003, 02:16 AM   #38
mitch179's Avatar
pops: i bought the entire mugen centax package which includes the mugen fly wheel and the clutch bell and all the other bits but u dont get any pinions...
i am using all the parts that came with the mugen clutch so its all mugen
Old 04-12-2003, 02:20 AM   #39
mitch179's Avatar
oh and this may help:
Mugen centax part no: H0768 ... the packet says 'MRX/MTX racing clutch set'
Old 04-12-2003, 09:50 AM   #40
popsracer's Avatar
Default Mugen Cutch for the RFX
mitch179;
Thanks, I'm goning to start shopping today.
Old 04-12-2003, 07:55 PM   #41
td-civ's Avatar
Trader Rating: 18 (95%+)
modellor
i didnt do it at a track i did it at a mall parking lot because i needed alot of space to do it and i ran 30% gas in it just to see how fast it would go and like i said before i blow the motor up two times doing it
td-civ is offline   Reply With Quote
Old 04-12-2003, 08:41 PM   #42
td-civ's Avatar
i will soon have a vid that you guys can see and pics
Old 04-14-2003, 04:24 PM   #43
CRASH's Avatar
Trader Rating: 26 (100%+)
Would be interested to see. I guess it could be possible, after all a Superntiro went 100mph a while back. Guys from RC Car Action. Remember that? It was wild!
Later
CRASH is offline   Reply With Quote
Old 04-15-2003, 10:58 AM   #44
td-civ's Avatar
im looking to buy another reflex team only car e-mail me if know how has one to sell i only want the cari have a motor and a controler
Old 04-15-2003, 05:26 PM   #45
mitch179's Avatar
i hate to say it people but my reflex is for sale
im going to get an MTX-3, and cause im poor i cant keep this car and get an MTX-3 aswell so the reflex has gotta go... its still one rad car.. hopefully one of my friends will buy it so i can still get to drive it some time but i will still hang around this thread and help out where i can hehe....
FS - TRINITY REFLEX TEAM ED & REFLEX NT CARS MUST GO!!!!!! Big Reg Australia For Sale/Trade 7 03-09-2008 10:42 PM
Trinity Reflex 12 fuelgun R/C Items: For Sale/Trade 11 01-17-2006 09:16 PM
Trinity Reflex 12 TheTurtleMan Electric On-Road 1 01-04-2005 06:35 PM
FS/FT Trinity Reflex Cosmo R/C Items: For Sale/Trade 3 04-09-2002 05:08 AM
Anyone into the Trinity Reflex? vanntz Singapore R/C Racers 5 04-08-2002 10:10 PM
