Old 04-21-2007, 09:09 PM   #1
ceaz's Avatar
Default Novarossi Plus .12 3CT break-in temp?
I started breaking in my plus .12 3ct jim hott mod. I noticed the temp was hovering around 180 deg. i did richen it up a bit, but still ran around 180 deg. it is cause of the modification or it just runs hot period.. Other engines i have broken in didnt run as hot. any help is appreciated. thanks
Serpent 720
Fanatic Remote Racerz
Controlfreakz.com
Sponsored by: my checkbook
ceaz is offline   Reply With Quote
Old 04-21-2007, 10:02 PM   #2
MRX4-R03's Avatar
you wanna break in nova's above 200 deg, 180 deg is not hot enough for break in, and that p/s design is diff from the other's they are not cnc the new one's are microcasted and can withstand alot more heat.. I would break in that engine at 200-210deg's that would be perfect..
MRX4-R03 is offline   Reply With Quote
Old 04-22-2007, 06:56 AM   #3
ceaz's Avatar
thanks i will. then mrx4-r03
Serpent 720
Controlfreakz.com
Old 04-22-2007, 10:32 AM   #4
Trader Rating: 18 (100%+)
Default Novarossi 12+3 break in
I have a fairly new 12+3 theat was modified by Maxy of Maxys fuel.
When I first started it, it did run on the warm side, even though I ran it rich.
I finally completed the break in at around 210 degrees.
The engine is a monster. I have not seen another 12 that will pull on it on the back straight. It just seems to run away from all the other 12 and 12 modified engines. Great engine!
brc358 is offline   Reply With Quote
Old 04-22-2007, 04:26 PM   #5
It depends also on tuning. If you tune better than another guy (maybe he's rich or something) then obviously it's faster. I think that people put way too much emphasis on getting a high power engine. I do it too
Anyhow, I just thought I should mention something about that.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Good break in temp? aus jd 2703 Onroad Nitro Engine Zone 2 11-26-2006 03:29 AM
STS Engine Break-in Temp hkyung Onroad Nitro Engine Zone 6 12-23-2005 12:39 AM
BREAK-IN Temp??? Chris08527 Electric Off-Road 4 04-06-2005 11:07 PM
Novarossi NSR12 S5 Break In Titan Onroad Nitro Engine Zone 16 10-28-2004 09:53 PM
Novarossi .12 5port - break-in thefuzzclub Nitro On-Road 34 03-31-2003 01:26 AM
