Old 04-14-2007, 12:03 AM   #1
kyosho 444's Avatar
Default engine trouble
my engine on my car starts but when i brake or wait a few seconds it dies and it is hard to start (its a pull start) plz help in any way you can.
kyosho 444 is offline   Reply With Quote
Old 04-14-2007, 12:15 AM   #2
technically should be in the engine section I guess. But first off I'd say low end = too lean. Richen it out about 1/4 turn and see what happens for you.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 04-14-2007, 02:26 AM   #3
Serpentd's Avatar
Dude, turn up your idle and quit posting a new thread for EVERY question PLEASE!!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 04-14-2007, 04:47 AM   #4
vc05hdt's Avatar
Kyosho 444, what type of Kyosho do you have, FW05T, V One S 3 or older car? The factory stock motor is real easy to tune. All you have to touch is Idle speed screw, and when you get more experience the High speed needle. If the motor gets too hot it can cause hard start problem but SerpentD is on right track with idle screw adjustment in your case. If idle adjustment doesn't work too well then do as Dread recommends. Be patient and try to catch up with local racers in your area as they can also assist you with advice.
vc05hdt is offline   Reply With Quote
Engine won't Rev Up and Glow Plug Trouble tarheel23 Nitro On-Road 5 07-25-2006 08:26 PM
Trouble starting engine on a TS-12 IceD Rookie Zone 2 06-09-2005 01:51 AM
engine trouble skater-racer Electric Off-Road 1 05-21-2005 07:25 PM
engine trouble igkyoa Electric Off-Road 4 12-04-2003 07:03 PM
Engine Trouble (I think?) Plz help! Nitrus~Power Electric On-Road 1 03-15-2003 12:43 PM
