Old 06-22-2008, 05:01 PM   #856
blown sv's Avatar
Originally Posted by ezveedub View Post
New engine coming out. Has 2 needle slide carb. Maybe looking into this soon.
http://www.charge-rc.com/framepage1-4.htm
where did you hear that?
Ace Hobby Distributors Australia ,Team Associated, HobbyWing ,Proline Australia ,Plaig Bearings , JA Designs
blown sv is offline   Reply With Quote
Old 06-22-2008, 05:08 PM   #857
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Sorry if I meant a new engine from Kyosho/Sirio. The engine on the Charge site is a replacement option engine due out Mid July. It needs the mounts to fit in as this engine has conventional style case, unlike the Sirio with bottom mounted screws. There is also a flywheel to go with the engine it appears.
If you to the Charge website I listed above, click on Spada "NEW" on the left side tabs and you'll see the engine. Its a AMR Speed engine 09CZ
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 06-25-2008, 12:16 AM   #858
Green Machine's Avatar
Where can you purchase spada bodies???
Green Machine is offline   Reply With Quote
Old 06-25-2008, 02:14 AM   #859
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
http://www.the-border.com/product.ph...cat=310&page=1
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 06-26-2008, 12:23 AM   #860
ezveedub's Avatar
Any updates to this thread? Seems dead.
Old 06-26-2008, 07:16 AM   #861
Zootcapri's Avatar
I am hoping to run the Spada against 19T pan cars this Saturday... if I can work out engine problems...
Zootcapri is offline   Reply With Quote
Old 06-26-2008, 07:30 AM   #862
ezveedub's Avatar
Whats going on with your engine?
Old 06-26-2008, 07:46 AM   #863
Zootcapri's Avatar
With the Losi fuel tank mod I could run at race speed for 15 minutes. Now the engine just stops around 5 minutes. Then it is hard to start and will not idle. The engine revs and dies then revs and dies. It sounded like an air leak so I replaced the fuel tubing and pressure line. I even changed the fuel tank. Still does it. The carb is cast into the crankcase so there is nothing to seal there. I am thinking bearings. The car does run real strong until it shuts down. I posted the problem on the engine thread. I am getting frustrated.
Old 06-26-2008, 06:37 PM   #864
ezveedub's Avatar
Have you checked the backplate for any leaks? I assume the glowplug and compression are good.
Old 06-26-2008, 08:56 PM   #865
Zootcapri's Avatar
Backplate tight, new plug and good pinch.
I richened it some and it ran longer. I was at 2 5/8th out and that had worked before. Now I am at 2 3/8ths and well see how it runs this Saturday against the 19T's.
Old 06-26-2008, 09:07 PM   #866
wingracer's Avatar
Trader Rating: 24 (100%+)
It sounds like a vapor lock. The thing has so little mass that the heat can quickly soak into the carb and crank and boil the fuel. Easy test for it, if it quits and doesn't want to restart dump some fuel on the carb and crankcase to cool it off and it should start right up if it was vapor locked. Only cure is to run it cooler.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-26-2008, 09:26 PM   #867
ezveedub's Avatar
I'll be fiddling with my Sirio 09 in offroad this week end. I still need to finish the Spada to get it tune up and running. I really want to see the AMR Speed 09 engine to see if its a worthy upgrade engine to try, both off and onroad.
Old 06-29-2008, 09:51 PM   #868
Zootcapri's Avatar
I ran it so rich that it wouldn't shift... couldn't get the rev's. Still shut down at the 5 minute (there abouts) mark. I hope new engine bearings help... I just want the old performance back... still scratching my head over this one.
Old 07-01-2008, 07:06 PM   #869
hey rcfoolz-you still got your car up for sale?
Thanks to VISA,MC, and my wife
MY RIDE- MUGEN MTX4R, JL TUNED, JL EVO3, PICCO 2607, Twister Tires USA
cdub is offline   Reply With Quote
Old 07-02-2008, 08:23 AM   #870
JLock's Avatar
He sold that car about a month ago.
JLock is offline   Reply With Quote
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
