Old 03-10-2008, 02:05 PM   #811
RC MARKET's Avatar
Charge
www.rcmarket.com.hk
Kyosho Gas powered 1/12th pan car-ch-cg301.jpg   Kyosho Gas powered 1/12th pan car-ch-cg302.jpg
RC MARKET is offline   Reply With Quote
Old 03-10-2008, 04:59 PM   #812
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Originally Posted by jbsmith1 View Post
update:
Tried rcfoolz camber mod, I used a 1mm shim to get flat wear.
I was worried about the angle binding the suspension, but it works a treat nice one Jim
see pic blue shim...
Your welcome.....
rcfoolz is offline   Reply With Quote
Old 03-12-2008, 01:48 PM   #813
n.e.r.d's Avatar
hi guys,
any idea where i can get the Spada Starter Box Fitting Mount online?
seems no one has them, any heads-up?
(other than Border-RC, no offence but the euro + shipping gonna flatten my wallet..)
n.e.r.d is offline   Reply With Quote
Old 03-12-2008, 02:59 PM   #814
Send a message via Skype™ to sandroon
Originally Posted by sandroon View Post
If someone need a really good deal take a look here
All spare parts included eccept for belts. All ergal and original parts. 2 engines : 1 absolutely new and 1 with 10 minutes of running. _Used only ..... in the garage!!!
Paypal accepted for non italian people. Send everywhere- bye
Price rivisited for quick sell
sandroon is offline   Reply With Quote
Old 03-23-2008, 01:27 AM   #815
FortySix's Avatar
Send a message via MSN to FortySix
hi, have been running my spada for abt 3 tank,notice that there was a big vibration in this car,is't normal or something to do with my engine setup,any way to reduce the vibration thks.
tribute to the chi hua hua
FortySix is offline   Reply With Quote
Old 03-23-2008, 10:10 AM   #816
rcfoolz's Avatar
I've noticed the same thing, but not a bad one, slight.....I think it is more of the rear axle transmitting the tire vibration through the car. Try a set of new tires and see what it does
Old 03-23-2008, 11:21 AM   #817
masterrch's Avatar
I finally got my bodies back from my painter
what do you guys think
Kyosho Gas powered 1/12th pan car-spda-012.jpg
masterrch is offline   Reply With Quote
Old 03-23-2008, 11:45 AM   #818
masterrch's Avatar
for the prior post about a starter box I use a Sportwerks cyclone
universal starter box,after a few modifactions,drilled new holes for the rear and used old chrome top starter box tabs, it works great.
Kyosho Gas powered 1/12th pan car-spda-001.jpg   Kyosho Gas powered 1/12th pan car-spda-002.jpg
Old 03-24-2008, 07:36 AM   #819
FortySix's Avatar
the vibration is quite bad that it causes all 3 of my engine mount screw to loosen n drop off, ok will try to put on a new set of tyre first, hope it could help reducing the vibration thks.
Old 03-24-2008, 08:10 AM   #820
Zootcapri's Avatar
I have had the car vibrate when held in the air and rev'd.. That was due to the springs only rear end and it would bounce when the throttle was rev'd. Went away when placed on the ground.
Zootcapri is offline   Reply With Quote
Old 03-24-2008, 11:00 PM   #821
FortySix's Avatar
my spada got a bad vibration when i let it idle on the ground and after 15sec of idling the engine will die off.
Old 03-24-2008, 11:25 PM   #822
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
so is there still no support for this car in the US? other than the obvious order from rcmarket in hk, can you even get this in the US?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-25-2008, 03:53 AM   #823
My friend was testing his Spada 09 in Hong Kong as shown on the following video clip.
http://www.youtube.com/watch?v=lKXjoW8hIaQ
Xraylover is offline   Reply With Quote
Old 03-25-2008, 11:23 AM   #824
Zootcapri's Avatar
Sounds like a defective engine... My car can sit for quite a while and is really pretty smooth. Bad crank? Bad bearings? Weird.
Old 03-27-2008, 03:38 AM   #825
FortySix's Avatar
engine is quite new, only 1 tank old, is't ok to set the needle valve at 1.5 turn from close position as my engine is set in this position, btw anyone here tried using other type of engine on spada thks.
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
