Old 03-05-2008, 06:16 AM   #796
FortySix's Avatar
Send a message via MSN to FortySix
hi, what type of starter box can be use to start the spada, juz finish fixing my spada and still need to look out for a starter kit.
also searching for oversize fuel tank,what type of oversize fuel tank do u guys use. thks
below is the pic of my spada which is still waiting for a starter kit.
tribute to the chi hua hua
FortySix is offline   Reply With Quote
Old 03-05-2008, 06:25 AM   #797
FortySix's Avatar
my spada
Kyosho Gas powered 1/12th pan car-05032008-001-.jpg
Old 03-05-2008, 06:26 AM   #798
Zootcapri's Avatar
Use the tank from the Losi XXXNT
See pages 11 and 12 of this thread for instructions and photos
Zootcapri is offline   Reply With Quote
Old 03-05-2008, 11:09 AM   #799
Send a message via Skype™ to sandroon
Default [Maybe OT] Good deal
If someone need a really good deal take a look here
All spare parts included eccept for belts. All ergal and original parts. 2 engines : 1 absolutely new and 1 with 10 minutes of running. _Used only ..... in the garage!!!
Paypal accepted for non italian people. Send everywhere- bye
sandroon is offline   Reply With Quote
Old 03-05-2008, 06:40 PM   #800
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Sandroon... Your? Its ok...looks like a good deal...starting bid is about $460 USD......Looks like the person put the time into it...lots of hop-ups and parts.....A GREAT deal!
rcfoolz is offline   Reply With Quote
Old 03-05-2008, 06:42 PM   #801
rcfoolz's Avatar
I was looking the car over tonight, waiting on some tires and found that the front camber is adjustable....
Old 03-06-2008, 06:08 AM   #802
jbsmith1's Avatar
Really...about -1.5 degree's of camber would sort out the front ware I see...but only seen this done using the Honest top plates??
jbsmith1 is offline   Reply With Quote
Old 03-06-2008, 06:53 AM   #803
rcfoolz's Avatar
Look at the bottom arm...this is a wonder why they didn't do this.... Cut a piece of lexan from any body, 2 pieces the same size. Remove the 2 screws from each lower arm and use a hinge pin reamer to elongate the holes......Place the thin piece of lexan in between the builkhead and the arm when you put it back on and you have now gone from positive to negative camber.
Simple fix
Old 03-06-2008, 07:18 AM   #804
FortySix's Avatar
hi, is this kyosho mini inferno 09 starter box suitable to be use for the spada09 as i see the engine is almost the same engine, anyone using this starter box for starting the spada09 thks...urgently looking for a starter box to start my spada but not sure to get what type of starter kit, plz help thks.
Kyosho Gas powered 1/12th pan car-06.jpg
Old 03-06-2008, 02:06 PM   #805
rcfoolz's Avatar
I am using a Mugen starter box. The box that I have, I have set up for my Xray NT1, but it fits the Spada without a problem, just hang the tire a little off the side and put the other one on the box......It almost locks in if you know what I mean. I've experimented with different pins on the box for lining up different cars, and I have a setup that works for the NT1, MTX3, MTX4, RRR and just by luck the Spada.....
Old 03-07-2008, 08:52 AM   #806
R&TRacer's Avatar
Unless that wheel on the starter you pictured can be rotated 90 degrees, that box may be difficult to use on the Spada.
Kyosho makes a mat made of neoprene that sits on your starter box and is conformed to the shape of the Spada chassis. There are small cutouts in the bottom that sit on the existing pins. No surprise these holes are spaced for a Kyosho starter.
I had to recut new holes in the bottom to match my mugen box but after doing that its really easy to drop the mat on and fire up the Spada.
Here's a link showing the mat.
http://www.e-shopkyosho.com/shop/Top.do
Kyosho Gas powered 1/12th pan car-spada-starter-mat.jpg
R&TRacer is offline   Reply With Quote
Old 03-08-2008, 05:02 AM   #807
rc-car-net's Avatar
Send a message via ICQ to rc-car-net Send a message via MSN to rc-car-net
Originally Posted by jbsmith1 View Post
lol heres a brighter pic m8, the carbon arm is locked to the swing arm with a star washer, the rounded end to the arm replaces the normal washer, and m3 cap head bolt screws it all togeather, leaving just a bit of end float, its simple and not worth over engineering any further.
The Xray springs are too stiff to be used, but I'm looking for some proper micro piston shockers from something now...
James
hey james....gotta get these damper systems!!!!!! would you produce some for me too? i don't want to try out what i have to do....your system is already working quite well. so just send me a pm with price
http://www.rctech.net/forum/attachme...0&d=1202975646
where can i get all these blue parts ?! ...and the motor tunings
http://www.rctech.net/forum/attachme...3&d=1200265383
where can i get the L-Factory parts?
thanks !!
[SIZE="1"][URL="http://www.Rc-Car-Net.at"][COLOR=RoyalBlue]Rc-Car-Net[/COLOR][/URL] [COLOR=Cyan]-=-[/COLOR] [URL=http://www.RC-FORUM.at][COLOR=RoyalBlue]RC-Forum.at[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.racing-cars.com][COLOR=RoyalBlue]Schumacher USA[/COLOR][/URL] [COLOR=Cyan]-=- [/COLOR] [URL=http://www.fantomracing.com][COLOR=RoyalBlue]Fantom Racing[/COLOR][/URL]
:tire::sneaky:[/size][size="2"] ................................. :sneaky::tire:
:sneaky::tire:[URL=http://www.summerchamps.de][COLOR="DarkOrange"]GERMANY Summer Champs[/COLOR][/URL][/SIZE]:tire::sneaky:
:tire::sneaky: ................................. :sneaky::tire:
rc-car-net is offline   Reply With Quote
Old 03-09-2008, 06:29 AM   #808
FortySix's Avatar
thks to all e reply on e starter box, really helpful info.
Old 03-09-2008, 11:13 AM   #809
jbsmith1's Avatar
sorry I just hav'nt got the time to do any kits, but you may not need dampers if your track is smooth, give it a try first.
The blue alloy parts are on ebay and border online has some blue bits and the kfactory brake bits from the kyosho RRR too, I expect others will chip in with other stockists.
Old 03-10-2008, 01:53 PM   #810
jbsmith1's Avatar
update:
Tried rcfoolz camber mod, I used a 1mm shim to get flat wear.
I was worried about the angle binding the suspension, but it works a treat nice one Jim
see pic blue shim...
Kyosho Gas powered 1/12th pan car-dsc00396.gif
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
