Old 02-06-2008, 06:51 AM   #691
jbsmith1's Avatar
Originally Posted by Zootcapri
I bet on strengthening the fore to aft while allowing side to side twist.
yes I see what you mean, off to ebay for some carbon fiber then.
(Ivan, email sent )
jbsmith1 is offline   Reply With Quote
Old 02-07-2008, 05:31 AM   #692
masterrch's Avatar
hey Zoot what are those turnbuckles from?
Rich
masterrch is offline   Reply With Quote
Old 02-07-2008, 08:28 AM   #693
Zootcapri's Avatar
I just took the threaded wire that they include in the kit to my LHS and found some Lundsford that matched the length.
Zootcapri is offline   Reply With Quote
Old 02-07-2008, 12:05 PM   #694
jbsmith1's Avatar
update re chassis flex:
Ordered some carbon fiber sheet, but, in the mean time for this sundays racing, I have put some tie rods from the top deck to front bearing carriers
Kyosho Gas powered 1/12th pan car-dsc00335gif.gif
Old 02-07-2008, 01:02 PM   #695
Zootcapri's Avatar
looks good as long as you don't over or under tighten them... very creative.
Old 02-07-2008, 01:48 PM   #696
border r/c's Avatar
so body's finished for the Winternats.
looking forward to put it on the track after hell hour (free pratice ) @ winternats
we have all the Spada parts on Stock included the Blue tuned Sirio motor
Kyosho Gas powered 1/12th pan car-dsc00225_resize.jpg   Kyosho Gas powered 1/12th pan car-dsc00223_resize.jpg
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 02-07-2008, 02:09 PM   #697
Zootcapri's Avatar
I went to the taller second gear pinion... for the larger tracks I wish there was a smaller spur gear set... the car was wound all the way up about half way down a 190' straight.. I held my breath hoping that the con rod wouldn't snap... taller gearing will be needed for larger tracks... but on the infield.... a total blast...
Old 02-07-2008, 02:32 PM   #698
border r/c's Avatar
Originally Posted by jbsmith1 View Post
pic...
I have the standard gearing on it but think i need a smaller 2nd is this already made?
Old 02-07-2008, 05:14 PM   #699
Zootcapri's Avatar
I haven't seen a smaller Spur... there is a taller pinion
Old 02-08-2008, 01:34 AM   #700
jbsmith1's Avatar
don't worry, I set the length to just float in the ball cups, no tweek.
nice looking bodies
Old 02-08-2008, 03:19 AM   #701
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I plan on picking up one of these in the next week or so, something to play with......I will be cutting my own carbon fiber parts for the car and see a couple areas that I might take a look at extending the upper deck to the front bulkheads....but is this going to add too much stiffness? also, the tank conversion will be integrated into the new parts for a more finnished look. What is the chassis thickness? I can go thinner or thicker for more tunability, and also, the front chassis brace that goes from side to side....how about the idea of 3 pieces instead of the one? Would building a cross bar and 2 upper suspension plates that have additional holes for adjusting camber work? Or just doing the upper deck extension work for that....soo many ideas, just need the car in my hands.
rcfoolz is offline   Reply With Quote
Old 02-08-2008, 06:22 AM   #702
Trader Rating: 24 (100%+)
i'm looking in on getting one too and your just the guy i was comeing
to see i just picked up a thunder tiger nitro motorcycle and
would like you to see it on cutting some carbon parts so maybe
i will see you at ronnies this weekend (getting alot faster with my nt1 thanks to you )
RANDY SMOOTH is offline   Reply With Quote
Old 02-08-2008, 07:03 AM   #703
jbsmith1's Avatar
Hi, the chassis is 2mm.
As for how much flex is right, generaly the higher the traction/grip your track has, the stiffer the chassis needs to be for consistany. The idea of a single top plate sounds good,see attatch pic for one possibility.
Kyosho Gas powered 1/12th pan car-spada%2520spare%2520chassisprototype.jpg
Old 02-08-2008, 08:59 AM   #704
Zootcapri's Avatar
watch the belt clearance. Otherwise...looks cool
Old 02-08-2008, 09:07 PM   #705
rcfoolz's Avatar
randy Smooth, I'll be at the winternats for the next 8 days.....I can cut the parts for the bike for you....they will be one off customs.....If you get a spada, let me know, I'll be looking to pick one up very soon. Something that would be awsome on ronnies track. If you want, call me...I've pm'd you my number.
Kyosho Silicone Lube for 1/12th Dampner Tubes noline Electric On-Road 4 12-20-2007 11:13 PM
wtb: rc gas powered jowel_men R/C Items: Wanted to Buy 10 05-13-2007 09:41 PM
1/18 Electric Powered bpandragon Electric Off-Road 5 04-07-2006 10:22 AM
24.7 powered RS4 Racer 2 bbb R/C Items: For Sale/Trade 2 05-25-2003 12:15 AM
which powered kit??? famous182 Nitro On-Road 2 05-07-2003 07:19 PM
